    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 612.1k Views 113 Watching
    • U
      Uhlala Newcomers
      Hi, I have the same message as romanencom with Universal Importer 1.2.6
      Any idea? Thanks.
      • U
        Uhlala Newcomers @romanencom
        @romanencodem Hi, I have the same issue with Universal Importer 1.2.6
        • B
          BGUERRE
          hello
          thank you to provide universal importer to the SU community.
          Unfortunately, i did try to dowload .obj file, but get the following error message
          OBJ fil is about 16 MO and he was generating by 3D Snap an IOS app.
          Any suggestion ?.
          thank you
          Bruno
          samuel_tS 1 Reply Last reply
          • samuel_tS
            samuel_t @BGUERRE
            @BGUERRE Hello,
            You're welcome!
            Seems there's an issue in .MTL file paired with .OBJ file.
            Can you please upload them and send me both (in private if you prefer)?
            • Rich O BrienR Rich O Brien referenced this topic on
            • K
              kevgrn114 Newcomers
              Hi, Just found your Universal plugin today, I've been wanting something like that for a long time!! It seem to work fine for me exporting dxf files from lightburn except that anything that is a curve is chopped up into dashed lines. Squares come in fine but circles or curves get the dash effect. Any thoughts? Thanks
              • T
                titiinorbita
                This post is deleted!
                  artemisglt
                  hello! and thank you for the great plug in! I am trying to import an obj file of this bed in sketchup.
                  link text
                  I select the option to claim missing textures and select the obj file. In which order do I select the textures?
                  The model has a diffuse map, two normal maps and a displacement map. If I select the diffuse map and the two normal maps, I get an error..
                  Any ideas?
                  panixiaP 1 Reply Last reply
                  • panixiaP
                    panixia @artemisglt
                    @artemisglt You just select the diffuse map and call it a day.
                    (you can add the other maps after the import if you really need them)
                    A 1 Reply Last reply
                      artemisglt @panixia
                      @panixia if i press claim missing textures, then import the obj object, I select the diffuse map and then it asks me to select again another missing texture. if i click the normal map, it asks me for a third texture and if select all three I receive an error. if i select the diffuse map every time again I receive an error.. any ideas?
                      • panixiaP
                        panixia @artemisglt
                        @artemisglt does it happen with a specific model or with all models?
                          artemisglt @panixia
                          @panixia it happens with all the models, that is why I asked to see what I am doing wrong. I send the link to the initial model, I referred to, if you can have a look.
                            mblally Newcomers
                            Hello, thank you for the community plugin, but I'm getting this error message when I try to import. It looks like you had someone else with a similar error about a year ago. Any solution?
                            • 19
                            • 20
                            • 21
                            • 22
                            • 23
                            • 23 / 23
