    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • samuel_tS
      samuel_t @brianroy2
      @brianroy2
      Hi, thanks for your bug report.
      I would be interested to have a copy of this STEP file (in private if you prefer) to confirm or not if this issue is macOS-specific 🤔
      How did you install Universal Importer, using the Extension Manager or another method?
      Could you please open the Terminal app on your Mac, paste the two commands below (one after the other), and send me their output?
      xattr "/Users/brianroy/Library/Application Support/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Mayo/Mac/mayo-conv"
      "/Users/brianroy/Library/Application Support/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Mayo/Mac/mayo-conv" --system-info
        Hello
        ça faisait longtemps! 🙂 SketchUp Make 2017
        J'ai fait marché le plugin avec des modèles FBX réalisés avec le Free Tripo AI!
        En Retopologie basse résolution Game Asset (3000) pas de problème!
        A la résolution du dessus, (Low 5000) je n'ai pas la proposition de réduction des polygones dans Universal Importer!
        Et donc mon écran reste noir! Et cela échoue!
        Y a-t-il un nombre maximum en entrée ?
        Merci d'avance des conseils! 🙂
        mon modèle :
        https://www.tripo3d.ai/app/model/d122e434-c32d-4bac-adaa-1d47968dd18f
        Le modèle donné par Tripo
        Mon propre modèle
        samuel_tS 1 Reply Last reply
        • samuel_tS
          samuel_t @pilou
          @pilou Hello, how have you been since then?
          I haven't set any hard limits in the Universal Importer plugin code... However, depending on your machine's specifications (especially the amount of system RAM), the import may be slow or even fail.
          Or maybe the second retopology generates an invalid model.
          Can you please send me the files directly in both resolutions? Because I don't wish to spend Tripo credits 😅
            @samuel_t
            Med resolution (who don't works)
            https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_a8a4796d-366a-45ec-b815-09b229a99bbd__2_.fbx
            Low resolution who works
            https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_c35581b0-d804-4224-990b-b31022f0afd8.fbx
            Maybe the textures...
            https://moiscript.weebly.com/uploads/3/9/3/8/3938813/uir-source.fbx
            But maybe sure on my latop 12 years old there is only 8G Hard Memory! 🙂
            • U
              Uhlala Newcomers
              Hi, I have the same message as romanencom with Universal Importer 1.2.6
              Any idea? Thanks.
              • U
                Uhlala Newcomers @romanencom
                @romanencodem Hi, I have the same issue with Universal Importer 1.2.6
                • B
                  BGUERRE
                  hello
                  thank you to provide universal importer to the SU community.
                  Unfortunately, i did try to dowload .obj file, but get the following error message
                  OBJ fil is about 16 MO and he was generating by 3D Snap an IOS app.
                  Any suggestion ?.
                  thank you
                  Bruno
                  • samuel_tS
                    samuel_t @BGUERRE
                    @BGUERRE Hello,
                    You're welcome!
                    Seems there's an issue in .MTL file paired with .OBJ file.
                    Can you please upload them and send me both (in private if you prefer)?
                    • Rich O BrienR Rich O Brien referenced this topic on
                    • K
                      kevgrn114 Newcomers
                      Hi, Just found your Universal plugin today, I've been wanting something like that for a long time!! It seem to work fine for me exporting dxf files from lightburn except that anything that is a curve is chopped up into dashed lines. Squares come in fine but circles or curves get the dash effect. Any thoughts? Thanks
                      • T
                        titiinorbita
                        This post is deleted!
                          artemisglt
                          hello! and thank you for the great plug in! I am trying to import an obj file of this bed in sketchup.
                          link text
                          I select the option to claim missing textures and select the obj file. In which order do I select the textures?
                          The model has a diffuse map, two normal maps and a displacement map. If I select the diffuse map and the two normal maps, I get an error..
                          Any ideas?
                          panixiaP 1 Reply Last reply
                          • panixiaP
                            panixia @artemisglt
                            @artemisglt You just select the diffuse map and call it a day.
                            (you can add the other maps after the import if you really need them)
                            A 1 Reply Last reply
                              artemisglt @panixia
                              @panixia if i press claim missing textures, then import the obj object, I select the diffuse map and then it asks me to select again another missing texture. if i click the normal map, it asks me for a third texture and if select all three I receive an error. if i select the diffuse map every time again I receive an error.. any ideas?
                              • panixiaP
                                panixia @artemisglt
                                @artemisglt does it happen with a specific model or with all models?
                                  artemisglt @panixia
                                  @panixia it happens with all the models, that is why I asked to see what I am doing wrong. I send the link to the initial model, I referred to, if you can have a look.
                                    mblally Newcomers
                                    Hello, thank you for the community plugin, but I'm getting this error message when I try to import. It looks like you had someone else with a similar error about a year ago. Any solution?
                                    • samuel_tS
                                      samuel_t @mblally
                                      @mblally Hello. You're welcome! This issue will be fixed in the next plugin version.
                                        sashapepperspray
                                        when will that update be? any estimates?
                                        • samuel_tS
                                          samuel_t @sashapepperspray
                                          @sashapepperspray Most probably today or tomorrow.
                                          • samuel_tS
                                            samuel_t
                                            Hello everyone! I'm happy to announce the availability of Universal Importer v1.2.7 🙂
                                            What's new?
                                            • CAD hierarchy can be preserved. This option is enabled by default; you can turn it off in the plugin menu.
                                              Below is a STEP file imported with this option enabled.
                                            • The CAD files import on Mac. Here's another STEP file imported on macOS Golden Gate (27).
                                            • IGES colors are imported, thanks to OpenCascade and Mayo.
                                            • Thanks to Assimp contributors, you shouldn't see anymore these errors:
                                              Failed to load [3MF] file: At least one mesh must be there
                                              Failed to load file: GLTF: Draco mesh compression not supported
                                            • 3MF models with textures are supported. Note however texture mapping issues may occur.
                                            • A "Soften Coplanar Faces" option is available. Enabled by default; it can be turned off in the plugin menu.
                                            • You can import a model from the root of a drive where your documents are stored, thanks to the contribution of Eegee.
                                            Download latest Universal Importer plugin from SketchUcation PluginStore.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 23 / 23
