    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 628.9k Views 113 Watching
    • B
      brianroy2 Newcomers
      Hi Samuel using a Mac Air Running Sequoia 15.1.1 when I am trying to convert a STEP file I am getting this error message
      samuel_tS 1 Reply Last reply
      • samuel_tS
        samuel_t @brianroy2
        @brianroy2
        Hi, thanks for your bug report.
        I would be interested to have a copy of this STEP file (in private if you prefer) to confirm or not if this issue is macOS-specific 🤔
        How did you install Universal Importer, using the Extension Manager or another method?
        Could you please open the Terminal app on your Mac, paste the two commands below (one after the other), and send me their output?
        xattr "/Users/brianroy/Library/Application Support/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Mayo/Mac/mayo-conv"
        "/Users/brianroy/Library/Application Support/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Mayo/Mac/mayo-conv" --system-info
          Hello
          ça faisait longtemps! 🙂 SketchUp Make 2017
          J'ai fait marché le plugin avec des modèles FBX réalisés avec le Free Tripo AI!
          En Retopologie basse résolution Game Asset (3000) pas de problème!
          A la résolution du dessus, (Low 5000) je n'ai pas la proposition de réduction des polygones dans Universal Importer!
          Et donc mon écran reste noir! Et cela échoue!
          Y a-t-il un nombre maximum en entrée ?
          Merci d'avance des conseils! 🙂
          mon modèle :
          https://www.tripo3d.ai/app/model/d122e434-c32d-4bac-adaa-1d47968dd18f
          Le modèle donné par Tripo
          Mon propre modèle
          • samuel_tS
            samuel_t @pilou
            @pilou Hello, how have you been since then?
            I haven't set any hard limits in the Universal Importer plugin code... However, depending on your machine's specifications (especially the amount of system RAM), the import may be slow or even fail.
            Or maybe the second retopology generates an invalid model.
            Can you please send me the files directly in both resolutions? Because I don't wish to spend Tripo credits 😅
              @samuel_t
              Med resolution (who don't works)
              https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_a8a4796d-366a-45ec-b815-09b229a99bbd__2_.fbx
              Low resolution who works
              https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_c35581b0-d804-4224-990b-b31022f0afd8.fbx
              Maybe the textures...
              https://moiscript.weebly.com/uploads/3/9/3/8/3938813/uir-source.fbx
              But maybe sure on my latop 12 years old there is only 8G Hard Memory! 🙂
              • U
                Uhlala Newcomers
                Hi, I have the same message as romanencom with Universal Importer 1.2.6
                Any idea? Thanks.
                • U
                  Uhlala Newcomers @romanencom
                  @romanencodem Hi, I have the same issue with Universal Importer 1.2.6
                  • B
                    BGUERRE
                    hello
                    thank you to provide universal importer to the SU community.
                    Unfortunately, i did try to dowload .obj file, but get the following error message
                    OBJ fil is about 16 MO and he was generating by 3D Snap an IOS app.
                    Any suggestion ?.
                    thank you
                    Bruno
                    • samuel_tS
                      samuel_t @BGUERRE
                      @BGUERRE Hello,
                      You're welcome!
                      Seems there's an issue in .MTL file paired with .OBJ file.
                      Can you please upload them and send me both (in private if you prefer)?
                      • Rich O BrienR Rich O Brien referenced this topic on
                      • K
                        kevgrn114 Newcomers
                        Hi, Just found your Universal plugin today, I've been wanting something like that for a long time!! It seem to work fine for me exporting dxf files from lightburn except that anything that is a curve is chopped up into dashed lines. Squares come in fine but circles or curves get the dash effect. Any thoughts? Thanks
                        • T
                          titiinorbita
                          This post is deleted!
                            artemisglt
                            hello! and thank you for the great plug in! I am trying to import an obj file of this bed in sketchup.
                            link text
                            I select the option to claim missing textures and select the obj file. In which order do I select the textures?
                            The model has a diffuse map, two normal maps and a displacement map. If I select the diffuse map and the two normal maps, I get an error..
                            Any ideas?
                            panixiaP 1 Reply Last reply
                            • panixiaP
                              panixia @artemisglt
                              @artemisglt You just select the diffuse map and call it a day.
                              (you can add the other maps after the import if you really need them)
                              A 1 Reply Last reply
                                artemisglt @panixia
                                @panixia if i press claim missing textures, then import the obj object, I select the diffuse map and then it asks me to select again another missing texture. if i click the normal map, it asks me for a third texture and if select all three I receive an error. if i select the diffuse map every time again I receive an error.. any ideas?
                                • panixiaP
                                  panixia @artemisglt
                                  @artemisglt does it happen with a specific model or with all models?
                                    artemisglt @panixia
                                    @panixia it happens with all the models, that is why I asked to see what I am doing wrong. I send the link to the initial model, I referred to, if you can have a look.
                                      mblally Newcomers
                                      Hello, thank you for the community plugin, but I'm getting this error message when I try to import. It looks like you had someone else with a similar error about a year ago. Any solution?
                                      • 19
                                      • 20
                                      • 21
                                      • 22
                                      • 23
                                      • 23 / 23
