    Sketchucation Tools 5.0...
    178 Posts 30 Posters 77.8k Views 28 Watching
    • I
      i5963c Extension Creator
      Something that I noted after installing version 5.0.1: everytime I launch Sketchup, the toolbar with the 3 icons reappears in the viewport. I don't want this behaviour, when I need the Sketchucation plugin, I will use the menu entries. I never saw this behaviour with earlier versions. I have already switched OFF the selection box for the toolbar settings in the View menu (many times) but at every relaunch / start of the application, the toolbar is shown again (and the selection box in the settings is switched ON again...)
      I TIGT 2 Replies Last reply
      • I
        i5963c Extension Creator @i5963c
        One more finding: The 'Shortcutter' is also empty (see screenshot of the dialog). Wasn't the case in earlier versions.
        Dave RD 1 Reply Last reply
          Dave R @i5963c
          @i5963c what operating system? What version of SketchUp?
          This is what I see in the Shortcutter with the current version of Sketchucation Tools.
          • I
            OS = Windows 11, SU = Make 2017
              Sketchucation Tools 5.0.2 released
              • Bugfixing and improvements
              • SketchUp 2026 compatibility
                TIG Moderator @i5963c
                @i5963c
                The reason the toolbar appears is, because there are updates available - hence the red marker on the first button - not present otherwise.
                If you open the ExtensionStore dialog and choose to install the updates, then close the toolbar, when you restart SketchUp the toolbar stays off, until you next activate it.
                If you don't want the updates simply dock the toolbar in the side bar with others, it's unobtrusive...
                gullfoG 1 Reply Last reply
                Reply Quote 2
                • alexpacio2013A
                  alexpacio2013
                  @TIG Nothing to do, I installed FredoLib5 02 and now SketchUp 2024, 2025, and 2026 all freeze. I don’t know what to do anymore — the programs close automatically right after startup without showing any message. I have no idea what to do, and it’s essential for me, especially Lord of the Toolbars, because of my issues — I simply can’t do without it anymore. If I delete the FredoLib5 folder, SketchUp starts again, but of course without all the plugins connected to Fredo. I also tried installing an older version (15.4e), but it still won’t start. Help.
                    Download the SketchUp installers: https://www.sketchup.com/download/all
                    Right click the installer and choose Run as Admin
                    When prompted choose Repair
                    See if that alleviates any issues.
                    If not move your Plugins folder to your Desktop and start SketchUp so it creates a new Plugins folder
                    Begin by install Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
                    See if there are issues starting SketchUp. If not you can rule out this as a cause.
                    Begin installing other extensions and seeing when the issue begins.
                    There may some clash or some corrupt file, basically anything, because everyone's setup is unique to them.
                    I have never seen a FredoLib5 folder. I do see a Fredo6_!LibFredo6 folder.
                    So you just need to take some time to figure out what could be causing a clash that stops SketchUp launching. The Plugins folder is a sensitive place and an errant file or out of sequence setup will lead to issues.
                    I think the first thing to rule out is some system related issue. Moving your Plugins temporarily to a neutral location will rule out a system issue.
                    Then it's a case or recreating your setup and seeing when the clash happens.
                    With every new SketchUp version I treat it as a new start. I never drag old stuff into places. I use our own Bundles system to re-install extensions for older versions.
                    • gullfoG
                      gullfo @TIG
                      @TIG said in Sketchucation Tools 5.0.2:
                      ONE ISSUE - a lot of the "updates" are way older than the ones i have installed... not sure if maybe the extension developer does not have their plugins in the correct database/format/link etc but i've got plugins 2-3 years old when all of them on my system are current...
                      e.g. i installed the latest LibFredo and it still shows up in the list of updates (active update button) with the same rev identifier...
                      anyways, i docked it in my toolbar, but i think the main complaint for most people, i don't want to dock it, i want to only select it in the extensions menu...
                      Glenn
                      http://www.runnel.com
                      • G
                        Gábor
                        @gullfo Have you installed the latest LibFredo with SketchucationTools or manually by downloading it from the website? If the second option, then the Tools doesn't know about it being installed, and indicates a need for the update. After you update it with the Tools, you should not be prompted for an update again.
                        • gullfoG
                          gullfo
                          manually like always. then all the other plugins which i installed before - i'm reluctant to install from the updater since many have the dates they're showing as very old compared to what i know is installed... might need some standard means of scanning known plugins and their respective update versions to compare? anyways i docked it and it's a non-issue for me, simply reporting observations at this point. cheers!
                          Glenn
                          • EdsonE
                            Edson
                            I installed 5.0.2 but it is not loading. See attached.
                            http://www.mahfuz.arq.br
                            TIGT 1 Reply Last reply
                              There is no calls to a "DMLanguageHandler" directly associated with SketchUcation, so that's a mystery.
                              I'm wondering if it's part of the compiled @fredo6 licensing files ?
                              Or something else might be causing an issue which then clashes ?
                              I fact I can find nothing in any Plugins I use needing this [PC].
                              You are on a MAC running which SUp version ?
                              Under investigation....
                              • fredo6F
                                None of my plugins uses DMLanguageHandler either.
                                Edson: Could you look at your SU2025 setup and see where this could come from.
                                Can you also install Sketchucation 5.0.2 manually (by unzipping the rbz file into your Plugin directory).
                                  DMLanguageHandler is a file used by Dale Martens in the likes of Profile Builder, Artisan etc
                                  • gullfoG
                                    gullfo
                                    it's this line:
                                    Sketchup.require(File.join(File.dirname(__FILE__), 'DM_ProfileBuilder3/langhandler'))
                                    in the DM_ProfileBuilder3.rb
                                    it's likely that the profile builder folder did not get copied. when i "migrated" my 2025 plugins to 2026, it missed 4 folders from the "required" lines. once the folders were copied over, it all works.
                                    note on my system the DM_ProfileBuilder3 folder copied, it was other plugin folders which did not.
                                    Glenn
                                    • EdsonE
                                      Edson
                                      I am not being able to post here
                                        Rich O Brien Moderator @Edson
                                        @Edson said in Sketchucation Tools 5.0.2:
                                        You just did?
                                          ARQALBINO Newcomers
                                          Hi, i can´t load my plugin FredoPic2Shape, i want to try up first, i really like Fredo Plugins on SketchUp 2021
                                            Rich O Brien Moderator @ARQALBINO
                                            @ARQALBINO said in Sketchucation Tools 5.0.2:
                                            It requires Libfredo to function.
                                            • 3 / 9
