    Sketchucation Tools 5.0...
    175 Posts 29 Posters 59.7k Views 27 Watching
      Sketchucation Tools 5.0.2 released
      • Bugfixing and improvements
      • SketchUp 2026 compatibility
        TIG Moderator @i5963c
        @i5963c
        The reason the toolbar appears is, because there are updates available - hence the red marker on the first button - not present otherwise.
        If you open the ExtensionStore dialog and choose to install the updates, then close the toolbar, when you restart SketchUp the toolbar stays off, until you next activate it.
        If you don't want the updates simply dock the toolbar in the side bar with others, it's unobtrusive...
        gullfoG 1 Reply Last reply Reply Quote 2
        • alexpacio2013A Offline
          alexpacio2013
          @TIG Nothing to do, I installed FredoLib5 02 and now SketchUp 2024, 2025, and 2026 all freeze. I don’t know what to do anymore — the programs close automatically right after startup without showing any message. I have no idea what to do, and it’s essential for me, especially Lord of the Toolbars, because of my issues — I simply can’t do without it anymore. If I delete the FredoLib5 folder, SketchUp starts again, but of course without all the plugins connected to Fredo. I also tried installing an older version (15.4e), but it still won’t start. Help.
            Download the SketchUp installers: https://www.sketchup.com/download/all
            Right click the installer and choose Run as Admin
            When prompted choose Repair
            See if that alleviates any issues.
            If not move your Plugins folder to your Desktop and start SketchUp so it creates a new Plugins folder
            Begin by install Sketchucation Tools: https://sketchucation.com/plugin/696-sketchucationtools
            See if there are issues starting SketchUp. If not you can rule out this as a cause.
            Begin installing other extensions and seeing when the issue begins.
            There may some clash or some corrupt file, basically anything, because everyone's setup is unique to them.
            I have never seen a FredoLib5 folder. I do see a Fredo6_!LibFredo6 folder.
            So you just need to take some time to figure out what could be causing a clash that stops SketchUp launching. The Plugins folder is a sensitive place and an errant file or out of sequence setup will lead to issues.
            I think the first thing to rule out is some system related issue. Moving your Plugins temporarily to a neutral location will rule out a system issue.
            Then it's a case or recreating your setup and seeing when the clash happens.
            With every new SketchUp version I treat it as a new start. I never drag old stuff into places. I use our own Bundles system to re-install extensions for older versions.
            • gullfoG Offline
              gullfo @TIG
              @TIG said in Sketchucation Tools 5.0.2:
              ONE ISSUE - a lot of the "updates" are way older than the ones i have installed... not sure if maybe the extension developer does not have their plugins in the correct database/format/link etc but i've got plugins 2-3 years old when all of them on my system are current...
              e.g. i installed the latest LibFredo and it still shows up in the list of updates (active update button) with the same rev identifier...
              anyways, i docked it in my toolbar, but i think the main complaint for most people, i don't want to dock it, i want to only select it in the extensions menu...
              Glenn
              http://www.runnel.com
                Gábor
                @gullfo Have you installed the latest LibFredo with SketchucationTools or manually by downloading it from the website? If the second option, then the Tools doesn't know about it being installed, and indicates a need for the update. After you update it with the Tools, you should not be prompted for an update again.
                • gullfoG Offline
                  gullfo
                  manually like always. then all the other plugins which i installed before - i'm reluctant to install from the updater since many have the dates they're showing as very old compared to what i know is installed... might need some standard means of scanning known plugins and their respective update versions to compare? anyways i docked it and it's a non-issue for me, simply reporting observations at this point. cheers!
                  Glenn
                  • EdsonE Offline
                    Edson
                    I installed 5.0.2 but it is not loading. See attached.
                    http://www.mahfuz.arq.br
                    TIGT 1 Reply Last reply Reply Quote 1
                      There is no calls to a "DMLanguageHandler" directly associated with SketchUcation, so that's a mystery.
                      I'm wondering if it's part of the compiled @fredo6 licensing files ?
                      Or something else might be causing an issue which then clashes ?
                      I fact I can find nothing in any Plugins I use needing this [PC].
                      You are on a MAC running which SUp version ?
                      Under investigation....
                      • fredo6F Offline
                        None of my plugins uses DMLanguageHandler either.
                        Edson: Could you look at your SU2025 setup and see where this could come from.
                        Can you also install Sketchucation 5.0.2 manually (by unzipping the rbz file into your Plugin directory).
                          DMLanguageHandler is a file used by Dale Martens in the likes of Profile Builder, Artisan etc
                          • gullfoG Offline
                            gullfo
                            it's this line:
                            Sketchup.require(File.join(File.dirname(__FILE__), 'DM_ProfileBuilder3/langhandler'))
                            in the DM_ProfileBuilder3.rb
                            it's likely that the profile builder folder did not get copied. when i "migrated" my 2025 plugins to 2026, it missed 4 folders from the "required" lines. once the folders were copied over, it all works.
                            note on my system the DM_ProfileBuilder3 folder copied, it was other plugin folders which did not.
                            Glenn
                            TIGT 1 Reply Last reply Reply Quote 0
                            • EdsonE Offline
                              Edson
                              I am not being able to post here
                                Rich O Brien Moderator @Edson
                                @Edson said in Sketchucation Tools 5.0.2:
                                You just did?
                                  ARQALBINO Newcomers
                                  Hi, i can´t load my plugin FredoPic2Shape, i want to try up first, i really like Fredo Plugins on SketchUp 2021
                                    Rich O Brien Moderator @ARQALBINO
                                    @ARQALBINO said in Sketchucation Tools 5.0.2:
                                    It requires Libfredo to function.
                                      TIG Moderator @Edson
                                      @Edson
                                      Can you please cause the error dialog again, this time click the bottom-left button to 'Copy All Errors' to your clipboard.
                                      Then paste the full error report into a reply here.
                                      It should tell us if DM's code is somehow messing up our files' loading...
                                        TIG Moderator @gullfo
                                        @gullfo
                                        So this file/folder copying was an error with the v2026 extension-migration tool by SketchUp, not copying all DM's files over and causing an error ??
                                        It has nothing to do with the SketchUcation extension - except in so far that it breaks it and stops it loading !!
                                        gullfoG 1 Reply Last reply Reply Quote 0
                                          Macho3001
                                          Hi Dear Rich, Tig ! Firstly, many many thanks for helping us users out at Sketchucation !!
                                          I have an error cropping up on my system after installing the latest SketchUcationTools_v5.0.2.rbz update, from the link provided by your good self.
                                          I was updating LibFredo6 to the latest version, and thereafter I just installed SketchUcationTools_v5.0.2.rbz on my SU2018 Pro system. It made my previous installation disappear, and after restarting Sketchup it now gives the following error on startup, while many of my purchased Fredo plugins (like Thrupaint etc) have stopped working which now ask me to install sketchucation extensionstore v3.1. Can you please help...? Screenshots of the load errors are attached herein below.... Will be deeply obliged if you could help: -
                                          Nitin
                                          3DADS
                                          'Leadership, by Design'
                                          3rd Dimension, Architecture Design Studio
                                          • gullfoG Offline
                                            gullfo @TIG
                                            @TIG yes that is my observation. the missing folders from the 2026 install-first-run migration process cause the errors in the sketchucation startup.
                                            Glenn
                                            • 4 / 9
