    Alfa Romeo 4c.
    23 Posts 6 Posters 2.0k Views 6 Watching
      An automotive TDF, a little lacking in finesse a la Lotus Elise and Porsche Boster but massively emotive and a true Alfa Romeo.
      This is still being built up render and scene wise so not the finished article but progress is erratic due to events outside of Sketchup.
      • L
        Nice work, I wish I had your organic modelling skills
          Not mine sadly, comes from turbosquid, https://www.turbosquid.com/3d-models/alfa-romeo-4c-960-1631922
          Initial is blender but it has an Autodesk fbx v ersion. Still needs cleaning for Sketchup use but each panel has 2 layers so these can be 'split' and cleaned up with Artisan/sub-d.
          I am trying to get the engine/transmission/chassis details added for a garage scene. Not convinced I can get this to cooperate tbh. File size.
          Mike AmosM 1 Reply Last reply
            Mike Amos @Mike Amos
            Some time to move things along a little. Not happy with some texture responses but time will tell.
              What render app is this?
                Rayscaper.
                  OK, there's a bug with PNGs with transparency that cause glowing fringes.
                  Thomas is aware so expect a fix soon for that glow
                  Reply Quote 2
                    Not fretting about anything, still learning so plenty of time yet.
                      Moving on a little, lights are now vanishing from the mopdel at a rate of knots.
                      Apparently adding a new user profile in win doze might do the trick, looking into doing that without win doze nanny complaining abut the same email address being used.
                      • L
                        NIce work mate and it looks like Rayscaper is maturing wellπŸ‘ πŸ‘ πŸ‘
                          Ta mate, still learning how to best get at the machinery tbh. Rayscaper seems to be closer to Maxwell than Twiglet but great results are possible with both. Maxwell may, MAY, be turning a corner from what I have heard but seems to be having a crisis of direction. Expecting a lot more AI if there is a new build.
                          The model here had a few issues on conversion but tbh, a good model makes renders easier. Lots of groups that can be converted to components and miorrored means memory can be more eficiently optimised.
                          Reply Quote 2
                            Issues with lights and adding them etc continue but still early days yet and much to attend to in future builds . No doubt all will be well in time.
                            tuna1957T 1 Reply Last reply
                            Reply Quote 2
                            • pixelcruncherP
                              Nice Render!
                              I'm working hard to get that next update out! This one is taking a bit more time than expected. Sometimes, I go into the deep end with making changes to the software, and then it takes a while to stabilize it. But I'm taking all those bug reports very seriously.
                              Cheers!
                              Thomas
                                Mike Amos @pixelcruncher
                                @pixelcruncher
                                Rather like the Whisky/Whiskey tour I am on a grand adventure. Twists in the road and potholes too but wtf? Folk are paying ten times aqs much for a tenth of the entertainment. Muppets.
                                Stay well mate and remember we need you to be whole during this roadmap. You need to remember the prime directive is. Be kind to yourself.
                                It WILL happen so Pole, pole, as the say at the base of Kilimanjaro.
                                • tuna1957T
                                  tuna1957 @Mike Amos
                                  @Mike-Amos Looking forward to more. πŸ‘
                                    Apologies for being on the slow go.
                                    Reply Quote 2
                                      This TwiLight or Rayscaper?
                                      Do you see that ring around the right light? If this is Rayscaper I would steer clear of changing sizes of point lights as they cause weird artifacts when their size intersects geometry.
                                      I believe Thomas is working on a new release with some improvements and addressing the opacity bug.
                                      Great scene to level up your material and lighting presentation!
                                        He is definitely on the right path, I did notice the 'ring of light' (Sorry poor taste alert).
                                        I did not change any light sizes BUT, the light is inside a component so THAT may be the issue.
                                          Well, I have checked that light issue and it is NOT the reversing light. Removal from the component and plcacing it outside the model leaves the ring of light extant. Possibly an artifact of the hdri.
                                          I shall rotate the model and see where that leaves things.
                                            OH well, drawing board. Only thing left I can think of is a ghost componant.
                                            Reply Quote 3
