    Alfa Romeo 4c.
    30 Posts 7 Posters 2.4k Views 7 Watching
      Ta mate, still learning how to best get at the machinery tbh. Rayscaper seems to be closer to Maxwell than Twiglet but great results are possible with both. Maxwell may, MAY, be turning a corner from what I have heard but seems to be having a crisis of direction. Expecting a lot more AI if there is a new build.
      The model here had a few issues on conversion but tbh, a good model makes renders easier. Lots of groups that can be converted to components and miorrored means memory can be more eficiently optimised.
      Mike AmosM 1 Reply Last reply
      Reply Quote 2
        Mike Amos @Mike Amos
        Issues with lights and adding them etc continue but still early days yet and much to attend to in future builds . No doubt all will be well in time.
        tuna1957T 1 Reply Last reply
        Reply Quote 2
        • pixelcruncherP
          Nice Render!
          I'm working hard to get that next update out! This one is taking a bit more time than expected. Sometimes, I go into the deep end with making changes to the software, and then it takes a while to stabilize it. But I'm taking all those bug reports very seriously.
          Cheers!
          Thomas
            Mike Amos @pixelcruncher
            @pixelcruncher
            Rather like the Whisky/Whiskey tour I am on a grand adventure. Twists in the road and potholes too but wtf? Folk are paying ten times aqs much for a tenth of the entertainment. Muppets.
            Stay well mate and remember we need you to be whole during this roadmap. You need to remember the prime directive is. Be kind to yourself.
            It WILL happen so Pole, pole, as the say at the base of Kilimanjaro.
            • tuna1957T
              tuna1957 @Mike Amos
              @Mike-Amos Looking forward to more. 👍
                Apologies for being on the slow go.
                Reply Quote 2
                  This TwiLight or Rayscaper?
                  Do you see that ring around the right light? If this is Rayscaper I would steer clear of changing sizes of point lights as they cause weird artifacts when their size intersects geometry.
                  I believe Thomas is working on a new release with some improvements and addressing the opacity bug.
                  Great scene to level up your material and lighting presentation!
                    He is definitely on the right path, I did notice the 'ring of light' (Sorry poor taste alert).
                    I did not change any light sizes BUT, the light is inside a component so THAT may be the issue.
                      Well, I have checked that light issue and it is NOT the reversing light. Removal from the component and plcacing it outside the model leaves the ring of light extant. Possibly an artifact of the hdri.
                      I shall rotate the model and see where that leaves things.
                        OH well, drawing board. Only thing left I can think of is a ghost componant.
                        Reply Quote 3
                          A bit more head scratching, some textures have 'vanished'. Hey ho.
                          Reply Quote 2
                          • Bryan KB
                            Still excellent work!
                              Thanks mate.
                                Updated with the latest build of Rayscaper out of Beta.
                                • KrassK
                                  Krass
                                  Good work,
                                  but I don’t quite understand the reflections on the glazing (the lack of realistic reflections).
                                  Did you use the "metallic paint" effect flakes from Rayscaper? Is it the car paint preset?
                                  Did you use an HDRI map, like one from a photographer’s studio?
                                  Krass
                                  • KrassK
                                    Krass
                                    Hello,
                                    I’m experimenting with a car render, but I’m finding it tricky to get convincing reflections on the windows... I’ve been using an HDRI map.
                                    Krass
                                      Mike Amos @Krass
                                      What do you mean "Realistic" reflections?
                                      Metalic, flakes to 0.2mm and car paint selected.
                                      No HDRI, I have a closed studio with Rayscaper lights picking out the silhouette from different angles.
                                      As far as reflections on different glass in your model goes, sometimes there is none. Take a look at cars parked in the street.
                                      • KrassK
                                        Krass
                                        Real-world glazing reflects elements of its surroundings much more intensely. In my interior renderings using Rayscaper, simply adding glass—whether for large windows or for framed pieces on the wall—often doesn't quite feel sufficient.
                                        For framed items, I sometimes opt to apply an ultra-glossy material directly to the image itself, rather than placing a pane of actual glass over the print or drawing.
                                        Krass
                                          All of that, standard, tbh. My background has no HDRI and no image. Therefor the subject is all. Also, the door glass has been "Wound" down as door glass can be. No reflection from either element.
                                          We all use different methods, nothing wrong with that.
                                            The only light sources in this image are ON and OF the car/subject. The enclosure is what I am calling a render-biome.
