    Alfa Romeo 4c.
    30 Posts 7 Posters 2.4k Views 7 Watching
      Mike Amos @Mike Amos
      Issues with lights and adding them etc continue but still early days yet and much to attend to in future builds . No doubt all will be well in time.
      tuna1957T 1 Reply Last reply
      Reply Quote 2
      • pixelcruncherP
        Nice Render!
        I'm working hard to get that next update out! This one is taking a bit more time than expected. Sometimes, I go into the deep end with making changes to the software, and then it takes a while to stabilize it. But I'm taking all those bug reports very seriously.
        Cheers!
        Thomas
        Mike AmosM 1 Reply Last reply
          Mike Amos @pixelcruncher
          @pixelcruncher
          Rather like the Whisky/Whiskey tour I am on a grand adventure. Twists in the road and potholes too but wtf? Folk are paying ten times aqs much for a tenth of the entertainment. Muppets.
          Stay well mate and remember we need you to be whole during this roadmap. You need to remember the prime directive is. Be kind to yourself.
          It WILL happen so Pole, pole, as the say at the base of Kilimanjaro.
          • tuna1957T
            tuna1957 @Mike Amos
            @Mike-Amos Looking forward to more. 👍
              Apologies for being on the slow go.
              Reply Quote 2
                This TwiLight or Rayscaper?
                Do you see that ring around the right light? If this is Rayscaper I would steer clear of changing sizes of point lights as they cause weird artifacts when their size intersects geometry.
                I believe Thomas is working on a new release with some improvements and addressing the opacity bug.
                Great scene to level up your material and lighting presentation!
                  He is definitely on the right path, I did notice the 'ring of light' (Sorry poor taste alert).
                  I did not change any light sizes BUT, the light is inside a component so THAT may be the issue.
                    Well, I have checked that light issue and it is NOT the reversing light. Removal from the component and plcacing it outside the model leaves the ring of light extant. Possibly an artifact of the hdri.
                    I shall rotate the model and see where that leaves things.
                      OH well, drawing board. Only thing left I can think of is a ghost componant.
                      Reply Quote 3
                        A bit more head scratching, some textures have 'vanished'. Hey ho.
                        Reply Quote 2
                        • Bryan KB
                          Still excellent work!
                            Thanks mate.
                              Updated with the latest build of Rayscaper out of Beta.
                              • KrassK
                                Krass
                                Good work,
                                but I don’t quite understand the reflections on the glazing (the lack of realistic reflections).
                                Did you use the "metallic paint" effect flakes from Rayscaper? Is it the car paint preset?
                                Did you use an HDRI map, like one from a photographer’s studio?
                                Krass
                                • KrassK
                                  Krass
                                  Hello,
                                  I’m experimenting with a car render, but I’m finding it tricky to get convincing reflections on the windows... I’ve been using an HDRI map.
                                  Krass
                                    Mike Amos @Krass
                                    What do you mean "Realistic" reflections?
                                    Metalic, flakes to 0.2mm and car paint selected.
                                    No HDRI, I have a closed studio with Rayscaper lights picking out the silhouette from different angles.
                                    As far as reflections on different glass in your model goes, sometimes there is none. Take a look at cars parked in the street.
                                    • KrassK
                                      Krass
                                      Real-world glazing reflects elements of its surroundings much more intensely. In my interior renderings using Rayscaper, simply adding glass—whether for large windows or for framed pieces on the wall—often doesn't quite feel sufficient.
                                      For framed items, I sometimes opt to apply an ultra-glossy material directly to the image itself, rather than placing a pane of actual glass over the print or drawing.
                                      Krass
                                        All of that, standard, tbh. My background has no HDRI and no image. Therefor the subject is all. Also, the door glass has been "Wound" down as door glass can be. No reflection from either element.
                                        We all use different methods, nothing wrong with that.
                                          The only light sources in this image are ON and OF the car/subject. The enclosure is what I am calling a render-biome.
                                          • 2 / 2
