    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 628.9k Views 113 Watching
      sashapepperspray @samuel_t
      @samuel_t I am the administrator, and I have windows 11
      samuel_tS 1 Reply Last reply
      • samuel_tS
        samuel_t @sashapepperspray
        @sashapepperspray
        Can you please confirm that the latest Visual C++ Redistributable x64 is installed on your Windows? Here is a reference screenshot:
        Hypothesis: You have a security software that blocks the Assimp executable (assimp.exe) when it tries to access the file system πŸ€”
          @samuel_t I have the laset visual c++ installed. Do you know how I could fix this security problem?
          • samuel_tS
            @sashapepperspray
            The security software is just a clue, I don't know if that's the issue.
            Using the Windows File Explorer, can you please access this folder:
            C:\Users\tenen\AppData\Roaming\SketchUp\SketchUp 2024\SketchUp\Plugins\universal_importer\Applications\Assimp\Win
            Run assimp.exe and then report to this thread any errors you see.
              @samuel_t nothing happens, a screen pops up for half a second, but disappears, and that is it.
              • C
                cuagn
                Hello,
                I've installed Universal Importer 1.2.6 llast July in order to use it with SketchUp Make 2017 (I'm not a PRO, just for Hobby).
                I try to use it today and I face this error, even after a reinstall of UI 1.2.6
                alt text
                I'm running
                Windows 11 Professionnel
                  shagrat @samuel_t
                  Hi, I'm having a similar issue with this extension, I just get an error message (below) when I try to import a step file. This is the first time I've tried using this extension.
                  Any help would be greatly appreciated. I have a whole bunch of components to import from a customer (I'm designing an assembly machine for him).
                  Really hope you can help as it takes forever to draw them from scratch.
                  Many thanks.
                  TIGT 1 Reply Last reply
                    TIG Moderator @shagrat
                    @shagrat
                    I'm sure samuel will chip in...
                    In the meanwhile...
                    The error message refers to v1.2.4 - there is a newer version v1.2.6
                    Also the error message relates to the import of an STP file as an OBJ file - you say in your text it was a STeP file [AP203/214 an 242 are supported]
                    It will help samuel if you clarify exactly what file-type you are trying to import and how you are doing it...
                    Meanwhile install the newest version of the extension...
                      shagrat @TIG
                      @TIG I've downloaded the latest version and get the following message:
                      The file I'm trying to import is this:
                      Hope someone can help as I have 40 of these components to import (or I have to draw them from scratch in SketchUp ☹
                      Cheers
                      TIGT samuel_tS 2 Replies Last reply
                        @shagrat
                        At least you're getting new errors !!
                        Hopefully @samuel_t can comment asap...
                        • V
                          vadhome
                          Hi! The extension does not work on MacOS Ventura M2 . How to install it correctly?!error.jpg
                            sashapepperspray @sashapepperspray
                            @sashapepperspray
                            I have installed an older version of the plugin (1.1.9) and I now can do poligon reduction, but I can't import, I get the following error messageScreenshot 2024-11-21 201114.png Screenshot 2024-11-21 201155.png
                            do you have any ideas?
                            • E
                              esthery Newcomers
                              getting this error.. any solution?
                              • samuel_tS
                                samuel_t @shagrat
                                @shagrat Sorry, I didn't see your posts. I think it's too late now...
                                This issue could be related to importing a model from a remote server (here \\fileserver).
                                • samuel_tS
                                  samuel_t @vadhome
                                  @vadhome Hi! Someone else reported an issue importing CAD files (such as STEP) on macOS with Universal Importer. I plan to rent a Mac to investigate...
                                  • samuel_tS
                                    @sashapepperspray, @esthery Can you please send me (in private if you prefer) the source model you're trying to import?
                                      @samuel_t Any model I try doesn't work, but here is onejuggler.obj
                                      • MikeG73M
                                        MikeG73
                                        The importer does not seem to except .blend files either
                                        Cheers!
                                        • samuel_tS
                                          @sashapepperspray Thanks for the example model file! I successfully imported it with Universal Importer v1.2.6.
                                          Something goes wrong on your system... πŸ˜• You can try once again to reinstall the Microsoft Visual C++ library.
                                          • samuel_tS
                                            samuel_t @MikeG73
                                            @MikeG73 I'm not sure to understand you.
                                            Universal Importer isn't compatible with recent .blend files but this may change in the future πŸ™‚
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
