    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 612.1k Views 113 Watching
      sashapepperspray
      I have just updated the plugin and tried using it, and I get the following error:
      Universal Importer Error: Command failed: cd /d "C:/Users/tenen/AppData/Local/Temp/Universal Importer" && "C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Assimp/Win/assimp.exe" export "export.dae" "export.obj" -tri
      I tried going to a previous version of sketchup, where I have an older version of the plugin, and I have the same error
      Do you know what this error is, and how I could fix it?
      S 1 Reply Last reply
        sashapepperspray @sashapepperspray
        This is the complete error:
        C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/universal_importer/assimp.rb:106:in `convert_model'
        Universal Importer Version: 1.2.6
        I have tried uninstalling and reinstalling microsoft visual runtime, and I still have the problem.
        @samuel_t do you have any ideas about this? thank you
        samuel_tS 1 Reply Last reply
        • samuel_tS
          samuel_t @sashapepperspray
          @sashapepperspray This error message indicates that the bug occurs when a polygon reduction is requested, in the SU viewport, with the plugin toolbar... but I don't know why.
          Have you succeeded in this operation with other 3D models? Or this operation fails everytime, whatever the 3D model?
            sashapepperspray @samuel_t
            @samuel_t It happens anytime I try any model, and also when I try importing models, I get this error
            • samuel_tS
              @sashapepperspray Do you have Windows 10 or Windows 11? Are you Administrator of your OS?
              S S 2 Replies Last reply
                @samuel_t I am the administrator, and I have windows 11
                • samuel_tS
                  @sashapepperspray
                  Can you please confirm that the latest Visual C++ Redistributable x64 is installed on your Windows? Here is a reference screenshot:
                  Hypothesis: You have a security software that blocks the Assimp executable (assimp.exe) when it tries to access the file system 🤔
                    @samuel_t I have the laset visual c++ installed. Do you know how I could fix this security problem?
                    • samuel_tS
                      @sashapepperspray
                      The security software is just a clue, I don't know if that's the issue.
                      Using the Windows File Explorer, can you please access this folder:
                      C:\Users\tenen\AppData\Roaming\SketchUp\SketchUp 2024\SketchUp\Plugins\universal_importer\Applications\Assimp\Win
                      Run assimp.exe and then report to this thread any errors you see.
                        @samuel_t nothing happens, a screen pops up for half a second, but disappears, and that is it.
                        • C
                          cuagn
                          Hello,
                          I've installed Universal Importer 1.2.6 llast July in order to use it with SketchUp Make 2017 (I'm not a PRO, just for Hobby).
                          I try to use it today and I face this error, even after a reinstall of UI 1.2.6
                          alt text
                          I'm running
                          Windows 11 Professionnel
                            shagrat @samuel_t
                            Hi, I'm having a similar issue with this extension, I just get an error message (below) when I try to import a step file. This is the first time I've tried using this extension.
                            Any help would be greatly appreciated. I have a whole bunch of components to import from a customer (I'm designing an assembly machine for him).
                            Really hope you can help as it takes forever to draw them from scratch.
                            Many thanks.
                            TIGT 1 Reply Last reply
                              TIG Moderator @shagrat
                              @shagrat
                              I'm sure samuel will chip in...
                              In the meanwhile...
                              The error message refers to v1.2.4 - there is a newer version v1.2.6
                              Also the error message relates to the import of an STP file as an OBJ file - you say in your text it was a STeP file [AP203/214 an 242 are supported]
                              It will help samuel if you clarify exactly what file-type you are trying to import and how you are doing it...
                              Meanwhile install the newest version of the extension...
                                shagrat @TIG
                                @TIG I've downloaded the latest version and get the following message:
                                The file I'm trying to import is this:
                                Hope someone can help as I have 40 of these components to import (or I have to draw them from scratch in SketchUp ☹
                                Cheers
                                TIGT samuel_tS 2 Replies Last reply
                                  @shagrat
                                  At least you're getting new errors !!
                                  Hopefully @samuel_t can comment asap...
                                  • V
                                    vadhome
                                    Hi! The extension does not work on MacOS Ventura M2 . How to install it correctly?!error.jpg
                                      @sashapepperspray
                                      I have installed an older version of the plugin (1.1.9) and I now can do poligon reduction, but I can't import, I get the following error messageScreenshot 2024-11-21 201114.png Screenshot 2024-11-21 201155.png
                                      do you have any ideas?
                                      • E
                                        esthery Newcomers
                                        getting this error.. any solution?
                                        • samuel_tS
                                          samuel_t @shagrat
                                          @shagrat Sorry, I didn't see your posts. I think it's too late now...
                                          This issue could be related to importing a model from a remote server (here \\fileserver).
                                          • samuel_tS
                                            samuel_t @vadhome
                                            @vadhome Hi! Someone else reported an issue importing CAD files (such as STEP) on macOS with Universal Importer. I plan to rent a Mac to investigate...
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
