    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 577.2k Views 112 Watching
    • samuel_tS Offline
      samuel_t @sashapepperspray
      @sashapepperspray Do you have Windows 10 or Windows 11? Are you Administrator of your OS?
      S S 2 Replies Last reply Reply Quote 0
        sashapepperspray @samuel_t
        @samuel_t I am the administrator, and I have windows 11
        samuel_tS 1 Reply Last reply Reply Quote 0
        • samuel_tS Offline
          @sashapepperspray
          Can you please confirm that the latest Visual C++ Redistributable x64 is installed on your Windows? Here is a reference screenshot:
          Hypothesis: You have a security software that blocks the Assimp executable (assimp.exe) when it tries to access the file system πŸ€”
            @samuel_t I have the laset visual c++ installed. Do you know how I could fix this security problem?
            • samuel_tS Offline
              @sashapepperspray
              The security software is just a clue, I don't know if that's the issue.
              Using the Windows File Explorer, can you please access this folder:
              C:\Users\tenen\AppData\Roaming\SketchUp\SketchUp 2024\SketchUp\Plugins\universal_importer\Applications\Assimp\Win
              Run assimp.exe and then report to this thread any errors you see.
                @samuel_t nothing happens, a screen pops up for half a second, but disappears, and that is it.
                  cuagn
                  Hello,
                  I've installed Universal Importer 1.2.6 llast July in order to use it with SketchUp Make 2017 (I'm not a PRO, just for Hobby).
                  I try to use it today and I face this error, even after a reinstall of UI 1.2.6
                  alt text
                  I'm running
                  Windows 11 Professionnel
                    shagrat @samuel_t
                    Hi, I'm having a similar issue with this extension, I just get an error message (below) when I try to import a step file. This is the first time I've tried using this extension.
                    Any help would be greatly appreciated. I have a whole bunch of components to import from a customer (I'm designing an assembly machine for him).
                    Really hope you can help as it takes forever to draw them from scratch.
                    Many thanks.
                    TIGT 1 Reply Last reply Reply Quote 0
                      TIG Moderator @shagrat
                      @shagrat
                      I'm sure samuel will chip in...
                      In the meanwhile...
                      The error message refers to v1.2.4 - there is a newer version v1.2.6
                      Also the error message relates to the import of an STP file as an OBJ file - you say in your text it was a STeP file [AP203/214 an 242 are supported]
                      It will help samuel if you clarify exactly what file-type you are trying to import and how you are doing it...
                      Meanwhile install the newest version of the extension...
                        shagrat @TIG
                        @TIG I've downloaded the latest version and get the following message:
                        The file I'm trying to import is this:
                        Hope someone can help as I have 40 of these components to import (or I have to draw them from scratch in SketchUp ☹
                        Cheers
                        TIGT samuel_tS 2 Replies Last reply Reply Quote 0
                          @shagrat
                          At least you're getting new errors !!
                          Hopefully @samuel_t can comment asap...
                          • V Offline
                            vadhome
                            Hi! The extension does not work on MacOS Ventura M2 . How to install it correctly?!error.jpg
                              sashapepperspray @sashapepperspray
                              @sashapepperspray
                              I have installed an older version of the plugin (1.1.9) and I now can do poligon reduction, but I can't import, I get the following error messageScreenshot 2024-11-21 201114.png Screenshot 2024-11-21 201155.png
                              do you have any ideas?
                              • E Offline
                                esthery Newcomers
                                getting this error.. any solution?
                                • samuel_tS Offline
                                  samuel_t @shagrat
                                  @shagrat Sorry, I didn't see your posts. I think it's too late now...
                                  This issue could be related to importing a model from a remote server (here \\fileserver).
                                  • samuel_tS Offline
                                    samuel_t @vadhome
                                    @vadhome Hi! Someone else reported an issue importing CAD files (such as STEP) on macOS with Universal Importer. I plan to rent a Mac to investigate...
                                    • samuel_tS Offline
                                      @sashapepperspray, @esthery Can you please send me (in private if you prefer) the source model you're trying to import?
                                        @samuel_t Any model I try doesn't work, but here is onejuggler.obj
                                        • MikeG73M Offline
                                          MikeG73
                                          The importer does not seem to except .blend files either
                                          Cheers!
                                          • samuel_tS Offline
                                            @sashapepperspray Thanks for the example model file! I successfully imported it with Universal Importer v1.2.6.
                                            Something goes wrong on your system... πŸ˜• You can try once again to reinstall the Microsoft Visual C++ library.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
