    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 628.9k Views 113 Watching
      sashapepperspray @samuel_t
      @samuel_t It happens anytime I try any model, and also when I try importing models, I get this error
      samuel_tS 1 Reply Last reply
      • samuel_tS
        samuel_t @sashapepperspray
        @sashapepperspray Do you have Windows 10 or Windows 11? Are you Administrator of your OS?
        S S 2 Replies Last reply
          @samuel_t I am the administrator, and I have windows 11
          • samuel_tS
            @sashapepperspray
            Can you please confirm that the latest Visual C++ Redistributable x64 is installed on your Windows? Here is a reference screenshot:
            Hypothesis: You have a security software that blocks the Assimp executable (assimp.exe) when it tries to access the file system 🤔
              @samuel_t I have the laset visual c++ installed. Do you know how I could fix this security problem?
              • samuel_tS
                @sashapepperspray
                The security software is just a clue, I don't know if that's the issue.
                Using the Windows File Explorer, can you please access this folder:
                C:\Users\tenen\AppData\Roaming\SketchUp\SketchUp 2024\SketchUp\Plugins\universal_importer\Applications\Assimp\Win
                Run assimp.exe and then report to this thread any errors you see.
                  @samuel_t nothing happens, a screen pops up for half a second, but disappears, and that is it.
                  • C
                    cuagn
                    Hello,
                    I've installed Universal Importer 1.2.6 llast July in order to use it with SketchUp Make 2017 (I'm not a PRO, just for Hobby).
                    I try to use it today and I face this error, even after a reinstall of UI 1.2.6
                    alt text
                    I'm running
                    Windows 11 Professionnel
                      shagrat @samuel_t
                      Hi, I'm having a similar issue with this extension, I just get an error message (below) when I try to import a step file. This is the first time I've tried using this extension.
                      Any help would be greatly appreciated. I have a whole bunch of components to import from a customer (I'm designing an assembly machine for him).
                      Really hope you can help as it takes forever to draw them from scratch.
                      Many thanks.
                      TIGT 1 Reply Last reply
                        TIG Moderator @shagrat
                        @shagrat
                        I'm sure samuel will chip in...
                        In the meanwhile...
                        The error message refers to v1.2.4 - there is a newer version v1.2.6
                        Also the error message relates to the import of an STP file as an OBJ file - you say in your text it was a STeP file [AP203/214 an 242 are supported]
                        It will help samuel if you clarify exactly what file-type you are trying to import and how you are doing it...
                        Meanwhile install the newest version of the extension...
                          shagrat @TIG
                          @TIG I've downloaded the latest version and get the following message:
                          The file I'm trying to import is this:
                          Hope someone can help as I have 40 of these components to import (or I have to draw them from scratch in SketchUp ☹
                          Cheers
                          TIGT samuel_tS 2 Replies Last reply
                            @shagrat
                            At least you're getting new errors !!
                            Hopefully @samuel_t can comment asap...
                            • V
                              vadhome
                              Hi! The extension does not work on MacOS Ventura M2 . How to install it correctly?!error.jpg
                                sashapepperspray @sashapepperspray
                                @sashapepperspray
                                I have installed an older version of the plugin (1.1.9) and I now can do poligon reduction, but I can't import, I get the following error messageScreenshot 2024-11-21 201114.png Screenshot 2024-11-21 201155.png
                                do you have any ideas?
                                • E
                                  esthery Newcomers
                                  getting this error.. any solution?
                                  • samuel_tS
                                    samuel_t @shagrat
                                    @shagrat Sorry, I didn't see your posts. I think it's too late now...
                                    This issue could be related to importing a model from a remote server (here \\fileserver).
                                    • samuel_tS
                                      samuel_t @vadhome
                                      @vadhome Hi! Someone else reported an issue importing CAD files (such as STEP) on macOS with Universal Importer. I plan to rent a Mac to investigate...
                                      • samuel_tS
                                        @sashapepperspray, @esthery Can you please send me (in private if you prefer) the source model you're trying to import?
                                          @samuel_t Any model I try doesn't work, but here is onejuggler.obj
                                          • MikeG73M
                                            MikeG73
                                            The importer does not seem to except .blend files either
                                            Cheers!
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
