    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 460.6k Views 109 Watching
    • samuel_tS Offline
      samuel_t @sashapepperspray
      @sashapepperspray
      Can you please confirm that the latest Visual C++ Redistributable x64 is installed on your Windows? Here is a reference screenshot:
      Hypothesis: You have a security software that blocks the Assimp executable (assimp.exe) when it tries to access the file system πŸ€”
      S 1 Reply Last reply Reply Quote 0
        sashapepperspray @samuel_t
        @samuel_t I have the laset visual c++ installed. Do you know how I could fix this security problem?
        samuel_tS 1 Reply Last reply Reply Quote 0
        • samuel_tS Offline
          @sashapepperspray
          The security software is just a clue, I don't know if that's the issue.
          Using the Windows File Explorer, can you please access this folder:
          C:\Users\tenen\AppData\Roaming\SketchUp\SketchUp 2024\SketchUp\Plugins\universal_importer\Applications\Assimp\Win
          Run assimp.exe and then report to this thread any errors you see.
            @samuel_t nothing happens, a screen pops up for half a second, but disappears, and that is it.
              cuagn
              Hello,
              I've installed Universal Importer 1.2.6 llast July in order to use it with SketchUp Make 2017 (I'm not a PRO, just for Hobby).
              I try to use it today and I face this error, even after a reinstall of UI 1.2.6
              alt text
              I'm running
              Windows 11 Professionnel
                shagrat @samuel_t
                Hi, I'm having a similar issue with this extension, I just get an error message (below) when I try to import a step file. This is the first time I've tried using this extension.
                Any help would be greatly appreciated. I have a whole bunch of components to import from a customer (I'm designing an assembly machine for him).
                Really hope you can help as it takes forever to draw them from scratch.
                Many thanks.
                TIGT 1 Reply Last reply Reply Quote 0
                  TIG Moderator @shagrat
                  @shagrat
                  I'm sure samuel will chip in...
                  In the meanwhile...
                  The error message refers to v1.2.4 - there is a newer version v1.2.6
                  Also the error message relates to the import of an STP file as an OBJ file - you say in your text it was a STeP file [AP203/214 an 242 are supported]
                  It will help samuel if you clarify exactly what file-type you are trying to import and how you are doing it...
                  Meanwhile install the newest version of the extension...
                    shagrat @TIG
                    @TIG I've downloaded the latest version and get the following message:
                    The file I'm trying to import is this:
                    Hope someone can help as I have 40 of these components to import (or I have to draw them from scratch in SketchUp ☹
                    Cheers
                    TIGT samuel_tS 2 Replies Last reply Reply Quote 0
                      @shagrat
                      At least you're getting new errors !!
                      Hopefully @samuel_t can comment asap...
                      • V Offline
                        vadhome
                        Hi! The extension does not work on MacOS Ventura M2 . How to install it correctly?!error.jpg
                          sashapepperspray @sashapepperspray
                          @sashapepperspray
                          I have installed an older version of the plugin (1.1.9) and I now can do poligon reduction, but I can't import, I get the following error messageScreenshot 2024-11-21 201114.png Screenshot 2024-11-21 201155.png
                          do you have any ideas?
                          • E Offline
                            esthery Newcomers
                            getting this error.. any solution?
                            • samuel_tS Offline
                              samuel_t @shagrat
                              @shagrat Sorry, I didn't see your posts. I think it's too late now...
                              This issue could be related to importing a model from a remote server (here \\fileserver).
                              • samuel_tS Offline
                                samuel_t @vadhome
                                @vadhome Hi! Someone else reported an issue importing CAD files (such as STEP) on macOS with Universal Importer. I plan to rent a Mac to investigate...
                                • samuel_tS Offline
                                  @sashapepperspray, @esthery Can you please send me (in private if you prefer) the source model you're trying to import?
                                    @samuel_t Any model I try doesn't work, but here is onejuggler.obj
                                    • MikeG73M Offline
                                      MikeG73
                                      The importer does not seem to except .blend files either
                                      Cheers!
                                      • samuel_tS Offline
                                        @sashapepperspray Thanks for the example model file! I successfully imported it with Universal Importer v1.2.6.
                                        Something goes wrong on your system... πŸ˜• You can try once again to reinstall the Microsoft Visual C++ library.
                                        • samuel_tS Offline
                                          samuel_t @MikeG73
                                          @MikeG73 I'm not sure to understand you.
                                          Universal Importer isn't compatible with recent .blend files but this may change in the future πŸ™‚
                                          • samuel_tS Offline
                                            samuel_t @vadhome
                                            @vadhome I rented a Mac Mini M1 for 24H but I couldn't reproduce the bug shown in your screenshot, at least with macOS Sonoma 14.6.1. However, SketchUp 2025 crashed several times randomly when placing the model to import. I need to investigate further...
                                            • 22
                                            • 23
                                            • 5 / 23
