    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • samuel_tS
      samuel_t @MikeG73
      Hello @MikeG73
      Thanks πŸ˜‰
      Indeed, BLEND format support in this extension is limited to older .blend files and one must claim then map the textures manually...
      I hope to improve that in the future πŸ˜‡
      Cheers!
        RLGL
        I have the latest DL. Thank you for the update. The scale is now correctly imported.
        Dave
          sashapepperspray
          I have just updated the plugin and tried using it, and I get the following error:
          Universal Importer Error: Command failed: cd /d "C:/Users/tenen/AppData/Local/Temp/Universal Importer" && "C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Assimp/Win/assimp.exe" export "export.dae" "export.obj" -tri
          I tried going to a previous version of sketchup, where I have an older version of the plugin, and I have the same error
          Do you know what this error is, and how I could fix it?
          S 1 Reply Last reply
            sashapepperspray @sashapepperspray
            This is the complete error:
            C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/universal_importer/assimp.rb:106:in `convert_model'
            Universal Importer Version: 1.2.6
            I have tried uninstalling and reinstalling microsoft visual runtime, and I still have the problem.
            @samuel_t do you have any ideas about this? thank you
            samuel_tS 1 Reply Last reply
            • samuel_tS
              samuel_t @sashapepperspray
              @sashapepperspray This error message indicates that the bug occurs when a polygon reduction is requested, in the SU viewport, with the plugin toolbar... but I don't know why.
              Have you succeeded in this operation with other 3D models? Or this operation fails everytime, whatever the 3D model?
                sashapepperspray @samuel_t
                @samuel_t It happens anytime I try any model, and also when I try importing models, I get this error
                • samuel_tS
                  @sashapepperspray Do you have Windows 10 or Windows 11? Are you Administrator of your OS?
                  S S 2 Replies Last reply
                    @samuel_t I am the administrator, and I have windows 11
                    • samuel_tS
                      @sashapepperspray
                      Can you please confirm that the latest Visual C++ Redistributable x64 is installed on your Windows? Here is a reference screenshot:
                      Hypothesis: You have a security software that blocks the Assimp executable (assimp.exe) when it tries to access the file system πŸ€”
                        @samuel_t I have the laset visual c++ installed. Do you know how I could fix this security problem?
                        • samuel_tS
                          @sashapepperspray
                          The security software is just a clue, I don't know if that's the issue.
                          Using the Windows File Explorer, can you please access this folder:
                          C:\Users\tenen\AppData\Roaming\SketchUp\SketchUp 2024\SketchUp\Plugins\universal_importer\Applications\Assimp\Win
                          Run assimp.exe and then report to this thread any errors you see.
                            @samuel_t nothing happens, a screen pops up for half a second, but disappears, and that is it.
                            • C
                              cuagn
                              Hello,
                              I've installed Universal Importer 1.2.6 llast July in order to use it with SketchUp Make 2017 (I'm not a PRO, just for Hobby).
                              I try to use it today and I face this error, even after a reinstall of UI 1.2.6
                              alt text
                              I'm running
                              Windows 11 Professionnel
                                shagrat @samuel_t
                                Hi, I'm having a similar issue with this extension, I just get an error message (below) when I try to import a step file. This is the first time I've tried using this extension.
                                Any help would be greatly appreciated. I have a whole bunch of components to import from a customer (I'm designing an assembly machine for him).
                                Really hope you can help as it takes forever to draw them from scratch.
                                Many thanks.
                                TIGT 1 Reply Last reply
                                  TIG Moderator @shagrat
                                  @shagrat
                                  I'm sure samuel will chip in...
                                  In the meanwhile...
                                  The error message refers to v1.2.4 - there is a newer version v1.2.6
                                  Also the error message relates to the import of an STP file as an OBJ file - you say in your text it was a STeP file [AP203/214 an 242 are supported]
                                  It will help samuel if you clarify exactly what file-type you are trying to import and how you are doing it...
                                  Meanwhile install the newest version of the extension...
                                    shagrat @TIG
                                    @TIG I've downloaded the latest version and get the following message:
                                    The file I'm trying to import is this:
                                    Hope someone can help as I have 40 of these components to import (or I have to draw them from scratch in SketchUp ☹
                                    Cheers
                                    TIGT samuel_tS 2 Replies Last reply
                                      @shagrat
                                      At least you're getting new errors !!
                                      Hopefully @samuel_t can comment asap...
                                      • V
                                        vadhome
                                        Hi! The extension does not work on MacOS Ventura M2 . How to install it correctly?!error.jpg
                                          @sashapepperspray
                                          I have installed an older version of the plugin (1.1.9) and I now can do poligon reduction, but I can't import, I get the following error messageScreenshot 2024-11-21 201114.png Screenshot 2024-11-21 201155.png
                                          do you have any ideas?
                                          • E
                                            esthery Newcomers
                                            getting this error.. any solution?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
