    Wrap-R for SketchUp
    extensions
    191 Posts 43 Posters 180.5k Views 43 Watching
      kaas
      @rich o brien said:
      Make sure your texture is square 1 : 1
      I recently re-discoverd Wrapr and I'm loving it - great tool! Any chance non-square textures will be supported? (2048x1024)
      • O Offline
        optimaforever
        Ah! I forgot to post the final result...
        Modeled in Sketchup pro 2017/8 + QFT + SubD
        Unwrap in Wrap-R
        Bodies painted with Substance Painter 2
        Rendered with Thea 1.5/2
        Kyosho Optima Mid trio
          @kaas
          Non square is coming. need to address some export issues for non-square textures
          @opti
          those are yummy models!
          • O Offline
            optimaforever
            thanks Rich! 😄
              kaas
              Question: will there be an update for 2019 soon OR should we use the 2018 Wrap-r version?
              • alsomarA Offline
                alsomar Extension Creator
                +1
                Alejandro Soriano Visuals ¡ All my links
                  GĂĄbor
                  Wrap-R 2018.4 is SU 2019 compatible. It can be downloaded from here: https://s3.amazonaws.com/wrapr-download/WrapR-installer_2018_4.exe
                  The new features of this release compared to the 2018.2 version are:
                  • 2019 compatibility
                  • Won't create the surplus hidden Wrap-R layer in the .skp file
                  • Improved error handling
                  • Limited Ngon support
                  • Group and Component support
                  • Untextured faces support
                  • License fixes
                  • Context menu added
                  • Modified "Save" workflow
                  • New Ruby plugin to support the above features
                  • Modified plugin installer
                  • Modified Relax Function
                  • Improved 3D display performance
                  • Check for updates in Help nemu
                  We plan to release the 2019 version of Wrap-R with loads of new features later this year.
                  • OxerO Offline
                    Oxer
                    Some new about Mac version?
                      GĂĄbor
                      Still among the plans. No set relase date yet.
                      Sent from my SM-G965F using Tapatalk
                      • OxerO Offline
                        Oxer
                        Thanks for the info!
                          tengel07
                          Payed nd got nothing! Cheater!
                          • jujuJ Offline
                            juju
                            This won't help resolve any problems you may be experiencing.
                            More details would help though, like when the transaction happened, etc.
                            Be sure to check you spam filters / folders as well, sometimes there are false positives.
                              tengel07
                              i did check my spam folder and my folder with mails from unkown too.
                              Its now 24h after i did the payment and i got nothing - only the payment response mail.
                              They do not respond on mails to support too.
                              CHEATER!
                                GĂĄbor
                                Hi tengel07,
                                Thank you for your interest in Wrap-R.
                                I'm now investigating what happened. Will answer your support ticket soon.
                                GĂĄbor
                                  GĂĄbor
                                  Hi tengel07,
                                  I checked and our system sent out the licence by email at the time of the purchase. Sometimes it happens that some over sensitive spam filter puts it into the spam folder or erases it.
                                  Anyhow now I've re-sent the licence both from the system and from my gmail mailbox. Hope you've received it this time.
                                  Best regards,
                                  GĂĄbor
                                    • QFT + SubD
                                    What is QFT ? 😳
                                    • jujuJ Offline
                                      juju
                                      @pilou said:
                                      • QFT + SubD
                                      What is QFT ? 😳
                                      Quad Face Tools 👍
                                        Aaaah! Thx! ☀
                                        I believe that Optimaforever is an old famous member of PPB*! 😉
                                        And Master of Su of course! 😎
                                        • PushPullBar
                                          A very cool SketchUp forum who has alas hacked! 😞
                                          suSteve
                                          Could you please confirm that it is compatible with make 2017 and pro 2019?
                                          thank you (the wrap-r website says pro 2018).
                                          Also the website has a cyber monday 2018 code is that still valid?
                                          thank you
                                            Get the latest version to ensure v2019 compatibility...
                                            You can but try the code 😉
                                            • 6 / 10
