    Wrap-R for SketchUp
    extensions
    191 Posts 43 Posters 208.5k Views 43 Watching
    • O
      optimaforever
      Ah! I forgot to post the final result...
      Modeled in Sketchup pro 2017/8 + QFT + SubD
      Unwrap in Wrap-R
      Bodies painted with Substance Painter 2
      Rendered with Thea 1.5/2
      Kyosho Optima Mid trio
        @kaas
        Non square is coming. need to address some export issues for non-square textures
        @opti
        those are yummy models!
        • O
          optimaforever
          thanks Rich! 😄
          • K
            kaas
            Question: will there be an update for 2019 soon OR should we use the 2018 Wrap-r version?
            • alsomarA
              alsomar Extension Creator
              +1
              Alejandro Soriano Visuals ¡ All my links
              • G
                GĂĄbor
                Wrap-R 2018.4 is SU 2019 compatible. It can be downloaded from here: https://s3.amazonaws.com/wrapr-download/WrapR-installer_2018_4.exe
                The new features of this release compared to the 2018.2 version are:
                • 2019 compatibility
                • Won't create the surplus hidden Wrap-R layer in the .skp file
                • Improved error handling
                • Limited Ngon support
                • Group and Component support
                • Untextured faces support
                • License fixes
                • Context menu added
                • Modified "Save" workflow
                • New Ruby plugin to support the above features
                • Modified plugin installer
                • Modified Relax Function
                • Improved 3D display performance
                • Check for updates in Help nemu
                We plan to release the 2019 version of Wrap-R with loads of new features later this year.
                • OxerO
                  Oxer
                  Some new about Mac version?
                  • G
                    GĂĄbor
                    Still among the plans. No set relase date yet.
                    Sent from my SM-G965F using Tapatalk
                    • OxerO
                      Oxer
                      Thanks for the info!
                      • T
                        tengel07
                        Payed nd got nothing! Cheater!
                        • jujuJ
                          juju
                          This won't help resolve any problems you may be experiencing.
                          More details would help though, like when the transaction happened, etc.
                          Be sure to check you spam filters / folders as well, sometimes there are false positives.
                          • T
                            tengel07
                            i did check my spam folder and my folder with mails from unkown too.
                            Its now 24h after i did the payment and i got nothing - only the payment response mail.
                            They do not respond on mails to support too.
                            CHEATER!
                            • G
                              GĂĄbor
                              Hi tengel07,
                              Thank you for your interest in Wrap-R.
                              I'm now investigating what happened. Will answer your support ticket soon.
                              GĂĄbor
                              • G
                                GĂĄbor
                                Hi tengel07,
                                I checked and our system sent out the licence by email at the time of the purchase. Sometimes it happens that some over sensitive spam filter puts it into the spam folder or erases it.
                                Anyhow now I've re-sent the licence both from the system and from my gmail mailbox. Hope you've received it this time.
                                Best regards,
                                GĂĄbor
                                  • QFT + SubD
                                  What is QFT ? 😳
                                  • jujuJ
                                    juju
                                    @pilou said:
                                    • QFT + SubD
                                    What is QFT ? 😳
                                    Quad Face Tools 👍
                                      Aaaah! Thx! ☀
                                      I believe that Optimaforever is an old famous member of PPB*! 😉
                                      And Master of Su of course! 😎
                                      • PushPullBar
                                        A very cool SketchUp forum who has alas hacked! 😞
                                        suSteve
                                        Could you please confirm that it is compatible with make 2017 and pro 2019?
                                        thank you (the wrap-r website says pro 2018).
                                        Also the website has a cyber monday 2018 code is that still valid?
                                        thank you
                                          Get the latest version to ensure v2019 compatibility...
                                          You can but try the code 😉
                                          • G
                                            GĂĄbor
                                            Yes, it is compatible with these versions. But to be sure it fits your needs I suggest to obtain and try the 7 days free trial at https://wrap-r.com/trial-access.html .
                                            If you already have purchased a license you can download the latest version of the program from here: https://s3.amazonaws.com/wrapr-download/WrapR-installer_2018_4.exe
                                            • 6 / 10
