    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • BoxB Offline
      He's a simple Dolphin if anyone wants one.
      It's only very quick and straight out of my head so may offend the aesthetic sensibilities of any passing Aquatic Mammal specialists.
      Saved the proxy back to 8.
      DolphinSU8.skp
      • HornOxxH Offline
        HornOxx
        a great idea and model for this place - thanks for that
        never trust a skinny cook
        • ntxdaveN Offline
          ntxdave
          Very nice Box - good basic example of how to use the tools.
          Press F1...thank me later
          • alsomarA Offline
            alsomar Extension Creator
            Well, here comes mine:
            http://imagizer.imageshack.us/v2/xq90/923/lQPbJA.jpg
            and after a little bit of Thea and Photoshop, this is the result:
            http://imagizer.imageshack.us/v2/xq90/924/FVT3MO.jpg
            Alejandro Soriano Visuals · All my links
              love that tyre!
              • O Offline
                optimaforever
                impressive!
                did you model one groove, component it and copy it in revolving fashion, then explode them before subdividing??
                • alsomarA Offline
                  You nailed it. That's exactly what I did 😉
                    How many time the subdivision itself ? Negligible or...
                    • alsomarA Offline
                      There's two subdivisions and it took about 2 mins to complete the process.
                        Great model - and I love that presentation style. Reminded me of the LEGO instructions.
                        • N Offline
                          numerobis
                          I really hope Trimble is following this thread and finally realizes that there is something wrong - 2 mins for such a small model is a joke and one reason why i still do my subd work in Max.
                          Something like this should be generated instantly.
                          • olisheaO Offline
                            olishea
                            Yes and about a half second in Wings 3D (which is pretty much redundant) and a half second in meshlab. SU is really bad at subdivision times; makes you wonder if you can integrate a subdivision app via a plugin so that SU doesn't even have to calculate the subdivision at all.
                            oli
                              At the moment; no. The current API require me to generate new model entities in the model DOM. Where as the ideal way would be to be able to override the viewport presentation of an object. Basically highjack the render-pipeline for a given object. That would allowed me to avoid the biggest bottleneck: generating SU entities which each needs to merge with each other for the special SU stickyness.
                              The SU magic isn't ideal for extensions like SUbD where you aren't supposed to be editing the final result in the viewport. Had SU known only about the control mesh then any tool could edit the mesh while the viewport displayed the subdivided result.
                              • olisheaO Offline
                                olishea
                                You explain things better than I do! 😄
                                This is what I mean; is there a way to show the subdivided mesh in a small window that runs real-time with the SU model?
                                You would simply play with the control mesh in SU and a window shows a subdivided version that moves in real time with the SU model? When you rotate, zoom and orbit the subdivided "render" does so too.
                                Then when you are happy you can do the final subdivision inside SU right at the end.
                                oli
                                  Oh, well, that surely is the next thing I'd poke into once OpenSubdiv is implemented! I was thinking of it in two stages:
                                  1. A preview window on the side.
                                  2. Make the background of that preview window transparent and overlay it the SU viewport. (not sure how well that'll work since it'd be a separate 3d spacxe on top of SU's view...)
                                  • olisheaO Offline
                                    olishea
                                    Nice!!
                                    I thought I was talking jibber jabber but you catch my drift! 😉
                                    Can't you already do something similar with Maxwell? It renders a subdivided version of your control mesh? I'm not maxwell user so unsure. Also needs to be realtime, simple shader.
                                    If you could switch between SU viewport and a SubD render overlay that would be better.....kinda like Thea where you can see the render in the viewport. If you could press a hotkey and the screen changes to the subdivided render that would be a total game changer for SU.
                                    Even if it was a preview window I would be happy to be fair.
                                    oli
                                      Yea I wonder if I saw a YouTube video on that. Though I'm not a Maxwell user...
                                      • N Offline
                                        numerobis
                                        Please, no separate window! 😮
                                        Yes, Maxwell has render time subdivision. It's not a shader, it's a modifier, that produces real subdivision geometry.
                                        http://support.nextlimit.com/display/mxdocsv3/Pixar+OpenSubdiv
                                          Not much way around that - since the SU API doesn't give access to the pipe-line. It'd off course be optional to use it.
                                          • Z Offline
                                            ZahariStoyanov
                                            Not quite sure where to post this but, since I'll be applying SubD on it, I'll ask here: any ideas how to fix the topology of the red section in this model?
                                            Benz+190+Evo.skp
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 82
                                            • 83
                                            • 41 / 83
