    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.9m Views 79 Watching
    • O Offline
      optimaforever
      very impressive!
      • Z Offline
        ZahariStoyanov
        Bruh! 600v is one of my favorite SketchUppers!
          Ixlrlxi was yet a master modeler, so with SubD it will be a super master! 😎
          • olisheaO Offline
            olishea
            the rear end of that car is so emotive. love it.
            oli
            • BoxB Offline
              He's a simple Dolphin if anyone wants one.
              It's only very quick and straight out of my head so may offend the aesthetic sensibilities of any passing Aquatic Mammal specialists.
              Saved the proxy back to 8.
              DolphinSU8.skp
              • HornOxxH Offline
                HornOxx
                πŸ‘
                a great idea and model for this place - thanks for that
                never trust a skinny cook
                • ntxdaveN Offline
                  ntxdave
                  Very nice Box - good basic example of how to use the tools.
                  Press F1...thank me later
                  • alsomarA Offline
                    alsomar Extension Creator
                    Well, here comes mine:
                    http://imagizer.imageshack.us/v2/xq90/923/lQPbJA.jpg
                    and after a little bit of Thea and Photoshop, this is the result:
                    http://imagizer.imageshack.us/v2/xq90/924/FVT3MO.jpg
                    Alejandro Soriano Visuals Β· All my links
                      love that tyre!
                      • O Offline
                        optimaforever
                        impressive!
                        did you model one groove, component it and copy it in revolving fashion, then explode them before subdividing??
                        • alsomarA Offline
                          You nailed it. That's exactly what I did πŸ˜‰
                            How many time the subdivision itself ? Negligible or...
                            • alsomarA Offline
                              There's two subdivisions and it took about 2 mins to complete the process.
                                Great model - and I love that presentation style. Reminded me of the LEGO instructions.
                                • N Offline
                                  numerobis
                                  πŸ’š
                                  I really hope Trimble is following this thread and finally realizes that there is something wrong - 2 mins for such a small model is a joke and one reason why i still do my subd work in Max.
                                  Something like this should be generated instantly.
                                  • olisheaO Offline
                                    olishea
                                    Yes and about a half second in Wings 3D (which is pretty much redundant) and a half second in meshlab. SU is really bad at subdivision times; makes you wonder if you can integrate a subdivision app via a plugin so that SU doesn't even have to calculate the subdivision at all.
                                    oli
                                      At the moment; no. The current API require me to generate new model entities in the model DOM. Where as the ideal way would be to be able to override the viewport presentation of an object. Basically highjack the render-pipeline for a given object. That would allowed me to avoid the biggest bottleneck: generating SU entities which each needs to merge with each other for the special SU stickyness.
                                      The SU magic isn't ideal for extensions like SUbD where you aren't supposed to be editing the final result in the viewport. Had SU known only about the control mesh then any tool could edit the mesh while the viewport displayed the subdivided result.
                                      • olisheaO Offline
                                        olishea
                                        You explain things better than I do! πŸ˜„
                                        This is what I mean; is there a way to show the subdivided mesh in a small window that runs real-time with the SU model?
                                        You would simply play with the control mesh in SU and a window shows a subdivided version that moves in real time with the SU model? When you rotate, zoom and orbit the subdivided "render" does so too.
                                        Then when you are happy you can do the final subdivision inside SU right at the end.
                                        oli
                                          Oh, well, that surely is the next thing I'd poke into once OpenSubdiv is implemented! I was thinking of it in two stages:
                                          1. A preview window on the side.
                                          2. Make the background of that preview window transparent and overlay it the SU viewport. (not sure how well that'll work since it'd be a separate 3d spacxe on top of SU's view...)
                                          • olisheaO Offline
                                            olishea
                                            Nice!!
                                            I thought I was talking jibber jabber but you catch my drift! πŸ˜‰
                                            Can't you already do something similar with Maxwell? It renders a subdivided version of your control mesh? I'm not maxwell user so unsure. Also needs to be realtime, simple shader.
                                            If you could switch between SU viewport and a SubD render overlay that would be better.....kinda like Thea where you can see the render in the viewport. If you could press a hotkey and the screen changes to the subdivided render that would be a total game changer for SU.
                                            Even if it was a preview window I would be happy to be fair.
                                            oli
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 83
                                            • 84
                                            • 24 / 84
