    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.9m Views 79 Watching
      How many time the subdivision itself ? Negligible or...
      • alsomarA Offline
        alsomar Extension Creator
        There's two subdivisions and it took about 2 mins to complete the process.
        Alejandro Soriano Visuals ยท All my links
          @alsomar said:
          and after a little bit of Thea and Photoshop, this is the result:
          Great model - and I love that presentation style. Reminded me of the LEGO instructions.
          • N Offline
            numerobis
            ๐Ÿ’š
            I really hope Trimble is following this thread and finally realizes that there is something wrong - 2 mins for such a small model is a joke and one reason why i still do my subd work in Max.
            Something like this should be generated instantly.
            • olisheaO Offline
              olishea
              Yes and about a half second in Wings 3D (which is pretty much redundant) and a half second in meshlab. SU is really bad at subdivision times; makes you wonder if you can integrate a subdivision app via a plugin so that SU doesn't even have to calculate the subdivision at all.
              oli
                At the moment; no. The current API require me to generate new model entities in the model DOM. Where as the ideal way would be to be able to override the viewport presentation of an object. Basically highjack the render-pipeline for a given object. That would allowed me to avoid the biggest bottleneck: generating SU entities which each needs to merge with each other for the special SU stickyness.
                The SU magic isn't ideal for extensions like SUbD where you aren't supposed to be editing the final result in the viewport. Had SU known only about the control mesh then any tool could edit the mesh while the viewport displayed the subdivided result.
                • olisheaO Offline
                  olishea
                  You explain things better than I do! ๐Ÿ˜„
                  This is what I mean; is there a way to show the subdivided mesh in a small window that runs real-time with the SU model?
                  You would simply play with the control mesh in SU and a window shows a subdivided version that moves in real time with the SU model? When you rotate, zoom and orbit the subdivided "render" does so too.
                  Then when you are happy you can do the final subdivision inside SU right at the end.
                  oli
                    Oh, well, that surely is the next thing I'd poke into once OpenSubdiv is implemented! I was thinking of it in two stages:
                    1. A preview window on the side.
                    2. Make the background of that preview window transparent and overlay it the SU viewport. (not sure how well that'll work since it'd be a separate 3d spacxe on top of SU's view...)
                    • olisheaO Offline
                      olishea
                      Nice!!
                      I thought I was talking jibber jabber but you catch my drift! ๐Ÿ˜‰
                      Can't you already do something similar with Maxwell? It renders a subdivided version of your control mesh? I'm not maxwell user so unsure. Also needs to be realtime, simple shader.
                      If you could switch between SU viewport and a SubD render overlay that would be better.....kinda like Thea where you can see the render in the viewport. If you could press a hotkey and the screen changes to the subdivided render that would be a total game changer for SU.
                      Even if it was a preview window I would be happy to be fair.
                      oli
                        Yea I wonder if I saw a YouTube video on that. Though I'm not a Maxwell user...
                        • N Offline
                          numerobis
                          Please, no separate window! ๐Ÿ˜ฎ
                          Yes, Maxwell has render time subdivision. It's not a shader, it's a modifier, that produces real subdivision geometry.
                          http://support.nextlimit.com/display/mxdocsv3/Pixar+OpenSubdiv
                            Not much way around that - since the SU API doesn't give access to the pipe-line. It'd off course be optional to use it.
                            • Z Offline
                              ZahariStoyanov
                              Not quite sure where to post this but, since I'll be applying SubD on it, I'll ask here: any ideas how to fix the topology of the red section in this model?
                              Benz+190+Evo.skp
                              • ely862meE Offline
                                ely862me
                                Maybe add another loop.
                                original
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                • Z Offline
                                  ZahariStoyanov
                                  My biggest concern is the rear glass' frame - the corner looks a bit weird when I subdivide it because the ring from there goes along the roof all the way to the front instead of connecting somehow to the door's corner or something. I mean, I'm trying to solve the way I did on the corresponding front section(A-pillar?) ๐Ÿ˜•
                                  • Z Offline
                                    ZahariStoyanov
                                    Fixed! I color-coded the problematic section again so I can better explain what was running through my head: I'm looking at the whole front-to-back edge as a group of rings that go along through the whole car. The issues shown on the "before" picture caused the corners between the roof and the C-pillar to kind of flick open. Now that I rearranged those rings and added a little extrusion to all contours, the problem's gone ๐Ÿ˜„
                                    Before:
                                    After:
                                    Smooth:
                                      cuttingedge
                                      @alsomar said:
                                      Well, here comes mine:
                                      http://imagizer.imageshack.us/v2/xq90/923/lQPbJA.jpg
                                      http://imagizer.imageshack.us/v2/xq90/924/FVT3MO.jpg
                                      Very clean high poly modeling!
                                        Images doesn't seem to load on my end. (IMO it's better to upload to the forum instead of hot-linking.)
                                        • cottyC Offline
                                          cotty
                                          It's Spanish and I don't see the images too.
                                          my SketchUp gallery
                                          • garydornG Offline
                                            garydorn
                                            I found this subdivision tips
                                            http://blog.whiteblaizer.com/2009/03/subdivision-tips-hard-surface-modelling-iv/
                                            not sure of the language - might be Italian.
                                            here is the index page
                                            http://blog.whiteblaizer.com/tutorials/
                                            Hope it helps.
                                            [img]http://blog.whiteblaizer.com/wp-content/uploads/2009/03/sdm04_05.jpg[/img]
                                            [img]http://blog.whiteblaizer.com/wp-content/uploads/2009/03/sdm04_04.jpg[/img]
                                            [img]http://blog.whiteblaizer.com/wp-content/uploads/2009/03/sdm04_03.jpg[/img]
                                            [img]http://blog.whiteblaizer.com/wp-content/uploads/2009/03/sdm04_02a.gif[/img]
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 83
                                            • 84
                                            • 24 / 84
