    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • ntxdaveN Offline
      ntxdave
      @pilou said:
      Yes thanks to Proxies! πŸ˜‰
      Another dumb question: What are Proxies?
      Press F1...thank me later
      • BoxB Offline
        Here's a quicky to show how to slice things up with QFT.
        http://i155.photobucket.com/albums/s296/storeben/SU/Qft.gif
        • HornOxxH Offline
          HornOxx
          @ntxdave said:
          What are Proxies?
          The Proxy in this context is the simple raw geometry.
          Also for example Artisan uses this term - also there is a simple raw geometry (the proxy)
          which then gets subdivided in a much complexer and biger geometry. The Proxy allways is the
          "placeholder"(? donΒ΄t know if that word exists in English?) for something modified.
          A lot of Render tools replace simple Proxys with most complex replace-geometrys or components.
          So you can draw (or use) for example a simple line-box in SU, wich then gets replaces within a renderer by a most complex 3D-tree...
          never trust a skinny cook
            @cuttingedge said:
            QFT, Vertex Tools & SubD, proved to be the most enjoyable tools for modeling. Here's a WIP of my earpods..
            Is the colour there from post processing? Or is that actually a SketchUp style?
              @jql said:
              If they're working with render engines and if you have Thea Interactive Rendering capabilities, you'll be able to fire up a render with subdivision without Sketchup Open GL viewport even being aware of it!
              Indeed. At the moment I'm moving towards using OpenSubdiv as subdivision engine. It actually have support for fast display of the subdivided mesh for OpenGL and DirectX - however the SU API doesn't provide access to the GL pipeline. Otherwise you'd have it override the normal drawing of the mesh in high-poly while SU itself would only know about the control mesh. dreams
              But I got some ideas here ... need to make some experiments. πŸ€“
                @ntxdave said:
                • Poly* Quad* Tri* N-Gon* Other Terms
                Have you looked at the links on the SUbD site?
                http://evilsoftwareempire.com/subd/quads
                Currently there are four links to external sites that describe the general concept of tris, quads and ngons. Is there information there you feel is missing?
                • jiminy-billy-bobJ Offline
                  jiminy-billy-bob
                  Tomasz did it! It needs some heavy hacking, but your colleagues in the core team may help you?
                  If you do succeed, I'd love to know how πŸ˜„
                    @jiminy-billy-bob said:
                    Tomasz did it!
                    Yea, I know there are way to get access directly to the SU viewport. But I got another idea that might be less hacking. I'm hesitant to dig too deep into host applications like that as it could easily break. I was thinking more in terms of overlays. Separate transparent window in a separate process (that way if it breaks it shouldn't take down SU with it.)
                    But yea - BaseCamp hackathon? πŸ˜„
                    • JQLJ Offline
                      JQL
                      Damn I love Thea For Sketchup!
                      www.casca.pt
                      Visit us on facebook!
                      • O Offline
                        optimaforever
                        Is there a tut for terrain and especially road modeling in quads?
                        I'm struggling to find examples for correct crossings topologies...
                          cuttingedge
                          Nope i just provided a platform for good contrast against the white.
                          Thinking about it.. It isnt easy to model perfectly. took me about an hour and half..while it looks okay here.
                          I had to redo it again to perfectly model it. My target it to actually make my modeling skill usable in the actual production of professional 3d prints.
                          • Rich O BrienR Online
                            SketchUp needs Matcaps soooo bad 😞
                              I might just have to replicate that. I quite liked that colour scheme.
                              • O Offline
                                optimaforever
                                I arrived to this with the roads in quads.
                                But I have no idea for the topology of the terrain between them...
                                What's the basic strategy? try to create a complete grid with similar quad size (closest to square as possible)?
                                And is quad modeling only for volumes? In the present case I'm only working on a plane...
                                  optimaforever - what is your target end result? Are you planning on subdividing?
                                  Are you planing on keeping it 100% flat? Will you be adding pavements etc? Some times you might not need quads 100% of the time.
                                  • O Offline
                                    optimaforever
                                    I was planning to move some vertexes in Z as the terrain isn't flat.
                                    My aim was to be able to get nice road borders (eventually duplicate some edges to generate concrete curbs with profile builder), smooth slopes.
                                    But I am wondering how to "fill" the zones between the roads. I guess it's basic know-how I'm missing here πŸ˜•
                                    • ntxdaveN Offline
                                      ntxdave
                                      @Box - another excellent video. Always more that can be learned from sages like you. πŸ‘
                                        I used to do that in my old job. use QFT to map curbs. However - I then had non-quad fill. Simply because I didn't need it.
                                        Filling that model you have would require some work to get good loops and topology flow - but ask yourself if you need it for all of it. Quads is after all not a goal by itself - but a means to make tools work better (where needed).
                                        • O Offline
                                          optimaforever
                                          Yes, I guess.
                                          But it's like learning a new language, once you've begun, it's hard to stop.
                                            Indeed - one start seeing everything in quads. Same as once you start any 3d modelling you see the world in geometric primitives. πŸ˜„
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 82
                                            • 83
                                            • 16 / 83
