    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 373.7k Views 45 Watching
    • HieruH
      Hieru
      @olishea said:
      It doesn't matter how "odd" the quad looks. If it's a quad it's a quad and will perform well.
      Lesson learned πŸ˜‰
      I'll certainly never model proxy circular planes any other way from now on. If this shape is typical, there should be a lot to be learnt from the rest of the examples.
      www.davidhier.co.uk
      • HieruH
        Hieru
        Had some time to tackle one of the shapes from the topology reference guide. I've changed some of the modelling to make it easier/faster to achieve in Sketchup.
        It was certainly a worthwhile exercise as I learnt that n-gons in your proxy can be used to create better topology (see the areas highlighted in red).
        Edit: The red areas are quads rather than n-gons. They are however still very important when it comes to creating better topology.
        BoltHeadPrimitive.skp
        www.davidhier.co.uk
        • HieruH
          Hieru
          Another example. This time a cylinder with holes.
          CylinderWithHoles.skp
          www.davidhier.co.uk
          • olisheaO
            olishea
            Very nice work.
            Just a quick note: Try using circles with 6 edges instead of 8. When you intersect a 6 sided circle in half with a line you get two halves of quads, if that makes sense. It doesn't really matter for this model, it's just something I should point out. You would end up with less poly too. The starting circle really determines how successful the subdivision is going to be; if you've tried using a strange amount of edges it becomes difficult to keep quads and the model becomes frustrating.
            oli
            • olisheaO
              olishea
              Can you do something about the marked areas? Looks a bit strange to me having those stray edges, even though it does form a quad. The large triangles could possibly be avoided too, don't have time to look though.
              oli
              • HieruH
                Hieru
                I was simply copying one of the provided examples, but I'll see if there is a better way of doing it.
                www.davidhier.co.uk
                • HieruH
                  Hieru
                  Insets on a curved surface.
                  CurvedInsets.skp
                  www.davidhier.co.uk
                  • HieruH
                    Hieru
                    Good point....that's a great tip πŸ‘
                    www.davidhier.co.uk
                    • HieruH
                      Hieru
                      Is this any better? It generates much neater topology but the poly count goes up.
                      CylinderWithHoles-V2.skp
                      www.davidhier.co.uk
                      • HieruH
                        Hieru
                        Or how about this? Here I've rebuilt the form using 6-sided openings...much more economical!
                        CylinderWithHoles-V3.skp
                        www.davidhier.co.uk
                        • HieruH
                          Hieru
                          Two versions of a simple cylinder with a bevelled edge. The second version (bottom) is for situations where you can't get away with a 6-sided shape.
                          Cylinder.skp
                          www.davidhier.co.uk
                            Too many poles. 3 and 5 sided converging quads.
                            • HieruH
                              Hieru
                              Last one for today: joining two pipes of the same diameter.
                              This one is significantly different to the reference as I couldn't figure out how to join the pipes without distorting the bottom pipe and making it non-cylindrical (see circled area).
                              JoiningPipe.skp
                              www.davidhier.co.uk
                              • HieruH
                                Hieru
                                Presumably that makes it difficult for UV mapping?
                                Edit: I was obviously over-thinking things again...
                                www.davidhier.co.uk
                                • olisheaO
                                  olishea
                                  Yeah you nailed it with CylinderWithHoles-V3. Sometimes you think there is no other possible way of doing it....then you come back to the model and think Ohhhhhh! Great examples and thanks for posting here! πŸ‘
                                  Your pipe is better than the example. The area you circled is an N-gon. πŸ˜‰ I guess the reason they did that was to reduce the "pinch" of the pole that you have in your model. They should have used another loop though. I love subdivision modelling; so many different outcomes from very subtle changes. πŸ˜„
                                  Would be cool if we had a "circularize" plugin for sketchup, you could click on specific rectangles and convert them into squares. Or maybe create an offset square face within the rectangle. Would be nice to be able to specify how many edges so you could even offset a triangle, square, pentagon etc etc....
                                  This would help creating circular holes in peculiar shapes. I use this tool in Wings 3D quite often, maybe I'll ask TIG about it....maybe call it Offset Circle where you can choose the amount of edges the offset circle has.
                                  oli
                                  • HieruH
                                    Hieru
                                    Thanks πŸ‘
                                    +1 Definitely sounds like something that would come in handy.
                                    www.davidhier.co.uk
                                    • bazB
                                      baz
                                      David and Oli, fascinating as this is, I think you might be going a bit off-topic, as in "Simple Artisan examples".
                                      If this were to be hived off to a separate thread, you would find many lurkers and contributors I reckon, but I find it a bit complicated for my poor brain.
                                      What about a new thread called... "Extremely bloody complicated Artisan examples with lots of esoteric technical terms"
                                      Sorry πŸ˜‰
                                        It can when you try to relax the UVs around poles because the quads are unable to form square shapes.
                                        • olisheaO
                                          olishea
                                          How can you get more simple than cylinders and pipes? πŸ˜‰
                                          Unfortunately you have to use some jargon. I hate it too.
                                          oli
                                          • cottyC
                                            cotty
                                            Should I delete "Simple" in the topic headline?
                                            my SketchUp gallery
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
