    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 373.7k Views 45 Watching
    • HieruH
      Hieru
      Two versions of a simple cylinder with a bevelled edge. The second version (bottom) is for situations where you can't get away with a 6-sided shape.
      Cylinder.skp
      www.davidhier.co.uk
        Too many poles. 3 and 5 sided converging quads.
        • HieruH
          Hieru
          Last one for today: joining two pipes of the same diameter.
          This one is significantly different to the reference as I couldn't figure out how to join the pipes without distorting the bottom pipe and making it non-cylindrical (see circled area).
          JoiningPipe.skp
          www.davidhier.co.uk
          • HieruH
            Hieru
            Presumably that makes it difficult for UV mapping?
            Edit: I was obviously over-thinking things again...
            www.davidhier.co.uk
            • olisheaO
              olishea
              Yeah you nailed it with CylinderWithHoles-V3. Sometimes you think there is no other possible way of doing it....then you come back to the model and think Ohhhhhh! Great examples and thanks for posting here! ๐Ÿ‘
              Your pipe is better than the example. The area you circled is an N-gon. ๐Ÿ˜‰ I guess the reason they did that was to reduce the "pinch" of the pole that you have in your model. They should have used another loop though. I love subdivision modelling; so many different outcomes from very subtle changes. ๐Ÿ˜„
              Would be cool if we had a "circularize" plugin for sketchup, you could click on specific rectangles and convert them into squares. Or maybe create an offset square face within the rectangle. Would be nice to be able to specify how many edges so you could even offset a triangle, square, pentagon etc etc....
              This would help creating circular holes in peculiar shapes. I use this tool in Wings 3D quite often, maybe I'll ask TIG about it....maybe call it Offset Circle where you can choose the amount of edges the offset circle has.
              oli
              • HieruH
                Hieru
                Thanks ๐Ÿ‘
                +1 Definitely sounds like something that would come in handy.
                www.davidhier.co.uk
                • bazB
                  baz
                  David and Oli, fascinating as this is, I think you might be going a bit off-topic, as in "Simple Artisan examples".
                  If this were to be hived off to a separate thread, you would find many lurkers and contributors I reckon, but I find it a bit complicated for my poor brain.
                  What about a new thread called... "Extremely bloody complicated Artisan examples with lots of esoteric technical terms"
                  Sorry ๐Ÿ˜‰
                    It can when you try to relax the UVs around poles because the quads are unable to form square shapes.
                    • olisheaO
                      olishea
                      How can you get more simple than cylinders and pipes? ๐Ÿ˜‰
                      Unfortunately you have to use some jargon. I hate it too.
                      oli
                      • cottyC
                        cotty
                        Should I delete "Simple" in the topic headline?
                        my SketchUp gallery
                        • bazB
                          baz
                          Point taken, perhaps a link or info on some jargon busting, Geometry for Artison 101?.
                          For example 'N-gons'???
                            @baz
                            polygon or tri-gon = triangle
                            quad = 4 sided polygon
                            n-gon = more than 4 sided polygon (replace n with the numbers of sides)
                            • olisheaO
                              olishea
                              Into to subdivision modelling and associated jargon:
                              404 Not Found
                              (theorangeduck.com)
                              oli
                              • olisheaO
                                olishea
                                No, because these are still relatively simple. I think it was just the jargon that was getting out of control. ๐Ÿ˜†
                                oli
                                  anyone is free to ask what's being said.
                                  it is something worth learning.
                                  @cotty
                                  we have a preliminary wiki in dev if you are interested in porting this thread to that at some point.
                                  • HieruH
                                    Hieru
                                    Maybe some of my examples are more 'intermediate' - part way between basic primitives and complex objects like soft furnishings or vehicles?
                                    I don't want to bloat the thread, so perhaps I should start a new topic just for the examples I've been reinterpreting for SU?
                                    In the mean time, here's a faceted hexagonal form that blends into a cylinder (sort of like a screwdriver handle).
                                    I would have liked to have achieved this with quads only, but I couldn't figure out a solution.
                                    www.davidhier.co.uk
                                      Maybe this can help you ๐Ÿ˜‰
                                      • bazB
                                        baz
                                        404 Not Found
                                        (theorangeduck.com)
                                        Thanks Oli, that's a great article, a must read I'd say. The 2 videos are very good too.
                                        I've just reread the 'esoteric' posts, and to my surprise I now have a glimmer of understanding.
                                        • HieruH
                                          Hieru
                                          Can you see the images on that thread? Most of them are missing for me, even when I'm logged in.
                                          www.davidhier.co.uk
                                            I see all images without to be logged! ๐Ÿ˜ฎ
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
