    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 373.7k Views 45 Watching
    • olisheaO
      olishea
      Can you do something about the marked areas? Looks a bit strange to me having those stray edges, even though it does form a quad. The large triangles could possibly be avoided too, don't have time to look though.
      oli
      • HieruH
        Hieru
        I was simply copying one of the provided examples, but I'll see if there is a better way of doing it.
        www.davidhier.co.uk
        • HieruH
          Hieru
          Insets on a curved surface.
          CurvedInsets.skp
          www.davidhier.co.uk
          • HieruH
            Hieru
            @olishea said:
            Try using circles with 6 edges instead of 8. When you intersect a 6 sided circle in half with a line you get two halves of quads, if that makes sense.
            Good point....that's a great tip πŸ‘
            www.davidhier.co.uk
            • HieruH
              Hieru
              Is this any better? It generates much neater topology but the poly count goes up.
              CylinderWithHoles-V2.skp
              www.davidhier.co.uk
              • HieruH
                Hieru
                Or how about this? Here I've rebuilt the form using 6-sided openings...much more economical!
                CylinderWithHoles-V3.skp
                www.davidhier.co.uk
                • HieruH
                  Hieru
                  Two versions of a simple cylinder with a bevelled edge. The second version (bottom) is for situations where you can't get away with a 6-sided shape.
                  Cylinder.skp
                  www.davidhier.co.uk
                    Too many poles. 3 and 5 sided converging quads.
                    • HieruH
                      Hieru
                      Last one for today: joining two pipes of the same diameter.
                      This one is significantly different to the reference as I couldn't figure out how to join the pipes without distorting the bottom pipe and making it non-cylindrical (see circled area).
                      JoiningPipe.skp
                      www.davidhier.co.uk
                      • HieruH
                        Hieru
                        Presumably that makes it difficult for UV mapping?
                        Edit: I was obviously over-thinking things again...
                        www.davidhier.co.uk
                        • olisheaO
                          olishea
                          Yeah you nailed it with CylinderWithHoles-V3. Sometimes you think there is no other possible way of doing it....then you come back to the model and think Ohhhhhh! Great examples and thanks for posting here! πŸ‘
                          Your pipe is better than the example. The area you circled is an N-gon. πŸ˜‰ I guess the reason they did that was to reduce the "pinch" of the pole that you have in your model. They should have used another loop though. I love subdivision modelling; so many different outcomes from very subtle changes. πŸ˜„
                          Would be cool if we had a "circularize" plugin for sketchup, you could click on specific rectangles and convert them into squares. Or maybe create an offset square face within the rectangle. Would be nice to be able to specify how many edges so you could even offset a triangle, square, pentagon etc etc....
                          This would help creating circular holes in peculiar shapes. I use this tool in Wings 3D quite often, maybe I'll ask TIG about it....maybe call it Offset Circle where you can choose the amount of edges the offset circle has.
                          oli
                          • HieruH
                            Hieru
                            Thanks πŸ‘
                            +1 Definitely sounds like something that would come in handy.
                            www.davidhier.co.uk
                            • bazB
                              baz
                              David and Oli, fascinating as this is, I think you might be going a bit off-topic, as in "Simple Artisan examples".
                              If this were to be hived off to a separate thread, you would find many lurkers and contributors I reckon, but I find it a bit complicated for my poor brain.
                              What about a new thread called... "Extremely bloody complicated Artisan examples with lots of esoteric technical terms"
                              Sorry πŸ˜‰
                                It can when you try to relax the UVs around poles because the quads are unable to form square shapes.
                                • olisheaO
                                  olishea
                                  How can you get more simple than cylinders and pipes? πŸ˜‰
                                  Unfortunately you have to use some jargon. I hate it too.
                                  oli
                                  • cottyC
                                    cotty
                                    Should I delete "Simple" in the topic headline?
                                    my SketchUp gallery
                                    • bazB
                                      baz
                                      Point taken, perhaps a link or info on some jargon busting, Geometry for Artison 101?.
                                      For example 'N-gons'???
                                        @baz
                                        polygon or tri-gon = triangle
                                        quad = 4 sided polygon
                                        n-gon = more than 4 sided polygon (replace n with the numbers of sides)
                                        • olisheaO
                                          olishea
                                          Into to subdivision modelling and associated jargon:
                                          404 Not Found
                                          (theorangeduck.com)
                                          oli
                                          • olisheaO
                                            olishea
                                            No, because these are still relatively simple. I think it was just the jargon that was getting out of control. πŸ˜†
                                            oli
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
