    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 373.7k Views 45 Watching
    • HieruH
      Hieru
      Or how about this? Here I've rebuilt the form using 6-sided openings...much more economical!
      CylinderWithHoles-V3.skp
      www.davidhier.co.uk
      • HieruH
        Hieru
        Two versions of a simple cylinder with a bevelled edge. The second version (bottom) is for situations where you can't get away with a 6-sided shape.
        Cylinder.skp
        www.davidhier.co.uk
          Too many poles. 3 and 5 sided converging quads.
          • HieruH
            Hieru
            Last one for today: joining two pipes of the same diameter.
            This one is significantly different to the reference as I couldn't figure out how to join the pipes without distorting the bottom pipe and making it non-cylindrical (see circled area).
            JoiningPipe.skp
            www.davidhier.co.uk
            • HieruH
              Hieru
              Presumably that makes it difficult for UV mapping?
              Edit: I was obviously over-thinking things again...
              www.davidhier.co.uk
              • olisheaO
                olishea
                Yeah you nailed it with CylinderWithHoles-V3. Sometimes you think there is no other possible way of doing it....then you come back to the model and think Ohhhhhh! Great examples and thanks for posting here! πŸ‘
                Your pipe is better than the example. The area you circled is an N-gon. πŸ˜‰ I guess the reason they did that was to reduce the "pinch" of the pole that you have in your model. They should have used another loop though. I love subdivision modelling; so many different outcomes from very subtle changes. πŸ˜„
                Would be cool if we had a "circularize" plugin for sketchup, you could click on specific rectangles and convert them into squares. Or maybe create an offset square face within the rectangle. Would be nice to be able to specify how many edges so you could even offset a triangle, square, pentagon etc etc....
                This would help creating circular holes in peculiar shapes. I use this tool in Wings 3D quite often, maybe I'll ask TIG about it....maybe call it Offset Circle where you can choose the amount of edges the offset circle has.
                oli
                • HieruH
                  Hieru
                  Thanks πŸ‘
                  +1 Definitely sounds like something that would come in handy.
                  www.davidhier.co.uk
                  • bazB
                    baz
                    David and Oli, fascinating as this is, I think you might be going a bit off-topic, as in "Simple Artisan examples".
                    If this were to be hived off to a separate thread, you would find many lurkers and contributors I reckon, but I find it a bit complicated for my poor brain.
                    What about a new thread called... "Extremely bloody complicated Artisan examples with lots of esoteric technical terms"
                    Sorry πŸ˜‰
                      It can when you try to relax the UVs around poles because the quads are unable to form square shapes.
                      • olisheaO
                        olishea
                        How can you get more simple than cylinders and pipes? πŸ˜‰
                        Unfortunately you have to use some jargon. I hate it too.
                        oli
                        • cottyC
                          cotty
                          Should I delete "Simple" in the topic headline?
                          my SketchUp gallery
                          • bazB
                            baz
                            Point taken, perhaps a link or info on some jargon busting, Geometry for Artison 101?.
                            For example 'N-gons'???
                              @baz
                              polygon or tri-gon = triangle
                              quad = 4 sided polygon
                              n-gon = more than 4 sided polygon (replace n with the numbers of sides)
                              • olisheaO
                                olishea
                                Into to subdivision modelling and associated jargon:
                                404 Not Found
                                (theorangeduck.com)
                                oli
                                • olisheaO
                                  olishea
                                  No, because these are still relatively simple. I think it was just the jargon that was getting out of control. πŸ˜†
                                  oli
                                    anyone is free to ask what's being said.
                                    it is something worth learning.
                                    @cotty
                                    we have a preliminary wiki in dev if you are interested in porting this thread to that at some point.
                                    • HieruH
                                      Hieru
                                      Maybe some of my examples are more 'intermediate' - part way between basic primitives and complex objects like soft furnishings or vehicles?
                                      I don't want to bloat the thread, so perhaps I should start a new topic just for the examples I've been reinterpreting for SU?
                                      In the mean time, here's a faceted hexagonal form that blends into a cylinder (sort of like a screwdriver handle).
                                      I would have liked to have achieved this with quads only, but I couldn't figure out a solution.
                                      www.davidhier.co.uk
                                        Maybe this can help you πŸ˜‰
                                        • bazB
                                          baz
                                          404 Not Found
                                          (theorangeduck.com)
                                          Thanks Oli, that's a great article, a must read I'd say. The 2 videos are very good too.
                                          I've just reread the 'esoteric' posts, and to my surprise I now have a glimmer of understanding.
                                          • HieruH
                                            Hieru
                                            Can you see the images on that thread? Most of them are missing for me, even when I'm logged in.
                                            www.davidhier.co.uk
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
