    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 938.0k Views 155 Watching
    • F
      fantoosh420
      @ Fredo & TIG
      I already cleaned that before you guys mentioned it but i thought i would be good to share it with you guys so that if it is happening because of any undiscovered reason it can be sorted out.
      As far as having a lot of lonely vertices, it is because of the organic nature of modelling i am currently doing. i am doing a hotel project on the hill and a meandering road was also being modelled which is meant to access the hotel (the surface i sent was one face of a retaining wall coming along the road). I was doing it without cleaning up the geometry due to save time and end the end spent all the saved time due to problem. 😄 😄... never mind since fredo is aware of the situation, a solution is inevitable.
      Sketchup 14.0.4900
      Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
      • F
        fantoosh420
        and bi the way fredo, how can i donate you? i don't have a credit card so facing problem... i wanted to donated to TIG to for cutNfill plugin but same problem happened. is there any other way? if no easy way out then i guess i need to figure out a credit card from any of my friend.
        Sketchup 14.0.4900
          We'll both accept PayPal donations.
          You can link those to a Bank-Account without any Credit-Card being needed... 😕
          • F
            fantoosh420
            @ TIG.. i tried that.... i guess direct debit by paypal from bank account is not supported here in India. My bank account is connected to paypal but even then it asks for a credit card. it says bank account is to credit money into your account but for debit you need a card. may be i need to figure out a credit card only...
            Sketchup 14.0.4900
              Ruf85
              sorry I have this problem with the last version.
              Why?
              When I use the Round push pull
              Date: 07-Mar-14 16:10:03
              An error occured in Round Push Pull
              Error in generation of the geometry
              undefined method `line_vec=' for nil:NilClass
              JointPushPullGeometry.rb: 1450 -- geometry_rounding_mesh
              JointPushPullGeometry.rb: 1275 -- geometry_create_roundings
              JointPushPullGeometry.rb: 1274 -- each
              JointPushPullGeometry.rb: 1274 -- geometry_create_roundings
              JointPushPullGeometry.rb: 262 -- geometry_robot_prepare_mesh
              JointPushPullGeometry.rb: 206 -- robot_call_action
              JointPushPullGeometry.rb: 177 -- geometry_robot_exec
              JointPushPullGeometry.rb: 160 -- geometry_robot
              JointPushPullGeometry.rb: 75 -- geometry_execute
              Lib6Operation.rb: 317 -- call
              Lib6Operation.rb: 317 -- step_geometry
              Lib6Operation.rb: 358 -- start_execution
              JointPushPullTool.rb: 879 -- go_preview_or_geom
              JointPushPullTool.rb: 690 -- dragging_stop
              JointPushPullTool.rb: 1303 -- onLButtonUp
              • fredo6F
                @ruf65,
                Could you post or PM me the model. I found the problem but would like to check that this is cured.
                  Ruf85
                  Sorry for the delay.
                  It's an element of the roof tile. I would model the front side.
                  Just for teach I use your plugins but I had the error
                  sorry for my bad english. I hope you understand me.
                  SKUpro8
                  • brodieB
                    brodie
                    I'm used to the old JPP so I'm not used to all of the options with the new one which may be causing my issue here. When I use JPP on a cone instead of basically making a bigger cone it pushes the point off to one side and does some weird stuff at the base.
                    What am I doing wrong here?
                    -Brodie
                    • mitcorbM
                      mitcorb
                      Hi, Brodie:
                      I was trying this out and managed to generate a ruby error:
                      Date: 11-Mar-14 19:30:04
                      An error occured in Vector Push Pull
                      Not a valid argument type
                      JointPushPullGeometry.rb: 434 -- *
                      JointPushPullGeometry.rb: 434 -- block in geometry_create_top_face
                      JointPushPullGeometry.rb: 432 -- collect
                      JointPushPullGeometry.rb: 432 -- geometry_create_top_face
                      JointPushPullGeometry.rb: 251 -- block in geometry_robot_prepare_mesh
                      JointPushPullGeometry.rb: 250 -- each
                      JointPushPullGeometry.rb: 250 -- each_with_index
                      JointPushPullGeometry.rb: 250 -- geometry_robot_prepare_mesh
                      JointPushPullGeometry.rb: 75 -- block in geometry_execute
                      But I was trying them all. I did get the double shell once and the slanted one with the dropped bottom. Try jpp on whole selection with smooth surfaces.
                      • mitcorbM
                        mitcorb
                        Here's a bit of what I did. xray view.
                        I think it also depends where on the face you trigger the jpp.
                        • brodieB
                          brodie
                          Here's what I'm getting...
                          Dropbox - Error - Simplify your life
                          (www.dropbox.com)
                          • mitcorbM
                            mitcorb
                            Hi, Brodie:
                            I can't deal with the swf, sorry. Maybe someone else?
                            • xiombargX
                              xiombarg
                              I seem to be having problems with the option of toggling axes from world to local. It doesn't recognize local, only world. I've tried it on both working models and new file. Any clues on this?
                              • fredo6F
                                NEW RELEASE: JointPush Pull Interactive v3.2b - 17 Mar 14
                                JointPushPull Interactive 3.2b fixes a number of bugs related to the modes of forced planar direction, which basically did not work.
                                Thanks to xiombarg for signaling this problem.
                                See main post of this thread for Download of JointPushPull.
                                • xiombargX
                                  xiombarg
                                  I've updated everything, but it still doesn't respond to the local toggle. I've tried to go through and get rid of any unused plugin files and I've used your 'purge obsolete files' utility but to no effect.
                                  I guess I could just re-install everything and see what happens.
                                  • fredo6F
                                    Could you post or PM the model where you have the problem.
                                    The local toggle enable to use the axes of the component which contains the picked face selected, instead of the model axes.
                                    • xiombargX
                                      xiombarg
                                      Maybe I'm just doing something incorrectly? But I've never had problems with it until I last updated. It had been quite awhile since I had updated, would that make a difference?
                                      http://i9.photobucket.com/albums/a51/xiombarg001/jpp_zpsd18b497b.jpg
                                        I think it's a setting thing.
                                        • xiombargX
                                          xiombarg
                                          Nope. Whether I have that "local button" toggled on or off it still sets itself to world. I've tried all sorts of variations of setting the axis and it always resorts to world axis. It almost seems like another script is overriding it as a precedence.
                                            Two options come to mind, then. Make a new, temporary Plugins folder. Rename the orignal Old Plugins or something. Then install fresh copies of JPP and LibFredo6 to that folder. See what you get.
                                            Or, remove all the other plugins from the current one until you find something that conflicts.
                                            • 30
                                            • 31
                                            • 5 / 31
