    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 950.9k Views 155 Watching
      Ruf85
      sorry I have this problem with the last version.
      Why?
      When I use the Round push pull
      Date: 07-Mar-14 16:10:03
      An error occured in Round Push Pull
      Error in generation of the geometry
      undefined method `line_vec=' for nil:NilClass
      JointPushPullGeometry.rb: 1450 -- geometry_rounding_mesh
      JointPushPullGeometry.rb: 1275 -- geometry_create_roundings
      JointPushPullGeometry.rb: 1274 -- each
      JointPushPullGeometry.rb: 1274 -- geometry_create_roundings
      JointPushPullGeometry.rb: 262 -- geometry_robot_prepare_mesh
      JointPushPullGeometry.rb: 206 -- robot_call_action
      JointPushPullGeometry.rb: 177 -- geometry_robot_exec
      JointPushPullGeometry.rb: 160 -- geometry_robot
      JointPushPullGeometry.rb: 75 -- geometry_execute
      Lib6Operation.rb: 317 -- call
      Lib6Operation.rb: 317 -- step_geometry
      Lib6Operation.rb: 358 -- start_execution
      JointPushPullTool.rb: 879 -- go_preview_or_geom
      JointPushPullTool.rb: 690 -- dragging_stop
      JointPushPullTool.rb: 1303 -- onLButtonUp
      • fredo6F
        @ruf65,
        Could you post or PM me the model. I found the problem but would like to check that this is cured.
          Ruf85
          Sorry for the delay.
          It's an element of the roof tile. I would model the front side.
          Just for teach I use your plugins but I had the error
          sorry for my bad english. I hope you understand me.
          SKUpro8
          • brodieB
            brodie
            I'm used to the old JPP so I'm not used to all of the options with the new one which may be causing my issue here. When I use JPP on a cone instead of basically making a bigger cone it pushes the point off to one side and does some weird stuff at the base.
            What am I doing wrong here?
            -Brodie
            • mitcorbM
              mitcorb
              Hi, Brodie:
              I was trying this out and managed to generate a ruby error:
              Date: 11-Mar-14 19:30:04
              An error occured in Vector Push Pull
              Not a valid argument type
              JointPushPullGeometry.rb: 434 -- *
              JointPushPullGeometry.rb: 434 -- block in geometry_create_top_face
              JointPushPullGeometry.rb: 432 -- collect
              JointPushPullGeometry.rb: 432 -- geometry_create_top_face
              JointPushPullGeometry.rb: 251 -- block in geometry_robot_prepare_mesh
              JointPushPullGeometry.rb: 250 -- each
              JointPushPullGeometry.rb: 250 -- each_with_index
              JointPushPullGeometry.rb: 250 -- geometry_robot_prepare_mesh
              JointPushPullGeometry.rb: 75 -- block in geometry_execute
              But I was trying them all. I did get the double shell once and the slanted one with the dropped bottom. Try jpp on whole selection with smooth surfaces.
              • mitcorbM
                mitcorb
                Here's a bit of what I did. xray view.
                I think it also depends where on the face you trigger the jpp.
                • brodieB
                  brodie
                  Here's what I'm getting...
                  Dropbox - Error - Simplify your life
                  (www.dropbox.com)
                  • mitcorbM
                    mitcorb
                    Hi, Brodie:
                    I can't deal with the swf, sorry. Maybe someone else?
                    • xiombargX
                      xiombarg
                      I seem to be having problems with the option of toggling axes from world to local. It doesn't recognize local, only world. I've tried it on both working models and new file. Any clues on this?
                      • fredo6F
                        NEW RELEASE: JointPush Pull Interactive v3.2b - 17 Mar 14
                        JointPushPull Interactive 3.2b fixes a number of bugs related to the modes of forced planar direction, which basically did not work.
                        Thanks to xiombarg for signaling this problem.
                        See main post of this thread for Download of JointPushPull.
                        • xiombargX
                          xiombarg
                          I've updated everything, but it still doesn't respond to the local toggle. I've tried to go through and get rid of any unused plugin files and I've used your 'purge obsolete files' utility but to no effect.
                          I guess I could just re-install everything and see what happens.
                          • fredo6F
                            Could you post or PM the model where you have the problem.
                            The local toggle enable to use the axes of the component which contains the picked face selected, instead of the model axes.
                            • xiombargX
                              xiombarg
                              Maybe I'm just doing something incorrectly? But I've never had problems with it until I last updated. It had been quite awhile since I had updated, would that make a difference?
                              http://i9.photobucket.com/albums/a51/xiombarg001/jpp_zpsd18b497b.jpg
                                I think it's a setting thing.
                                • xiombargX
                                  xiombarg
                                  Nope. Whether I have that "local button" toggled on or off it still sets itself to world. I've tried all sorts of variations of setting the axis and it always resorts to world axis. It almost seems like another script is overriding it as a precedence.
                                    Two options come to mind, then. Make a new, temporary Plugins folder. Rename the orignal Old Plugins or something. Then install fresh copies of JPP and LibFredo6 to that folder. See what you get.
                                    Or, remove all the other plugins from the current one until you find something that conflicts.
                                    • xiombargX
                                      xiombarg
                                      Right, that's probably what it's come to. I was just hoping that maybe I was overlooking something.
                                        What if you "press" the button below the X in red? That's different in my screen shot compared to yours.
                                          dtrarch
                                          Dear Fredo
                                          If it is at all possible please make the old JPP version work in SU2014?
                                          The old version was so elegant and simple and while the new and improved will do more, for me it just crashes, loses object elements and the settings do not do what they are told to do.
                                          I will be pleased to the first to add to your cookie jar if we could have the option to choose the JPP version to install.
                                          SU user since V2 and honestly I did install the new JPP properly too.
                                          I cleaned out the old version (.....roaming/sketchup and such as well)
                                          Thanks and please
                                          dtr
                                          • xiombargX
                                            xiombarg
                                            Pushing the button below the "X" makes it so that is doesn't lock to any specific axis? That works fine when I use it. It's the locking to a local axis that doesn't work.
                                            Here's the current update:
                                            So I tried uninstalling SU8 and reinstalling it and only loading Libfredo6 and Joint Push Pull and no other plugins installed... It still doesn't work. I'm at a total loss now. I thought for sure that would fix it, but nope.
                                            I can try anything if anyone has any ideas?
                                            • 30
                                            • 31
                                            • 5 / 31
