    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • brodieB
      brodie
      I'm used to the old JPP so I'm not used to all of the options with the new one which may be causing my issue here. When I use JPP on a cone instead of basically making a bigger cone it pushes the point off to one side and does some weird stuff at the base.
      What am I doing wrong here?
      -Brodie
      • mitcorbM
        mitcorb
        Hi, Brodie:
        I was trying this out and managed to generate a ruby error:
        Date: 11-Mar-14 19:30:04
        An error occured in Vector Push Pull
        Error in generation of the geometry
        Not a valid argument type
        JointPushPullGeometry.rb: 434 -- *
        JointPushPullGeometry.rb: 434 -- block in geometry_create_top_face
        JointPushPullGeometry.rb: 432 -- collect
        JointPushPullGeometry.rb: 432 -- geometry_create_top_face
        JointPushPullGeometry.rb: 251 -- block in geometry_robot_prepare_mesh
        JointPushPullGeometry.rb: 250 -- each
        JointPushPullGeometry.rb: 250 -- each_with_index
        JointPushPullGeometry.rb: 250 -- geometry_robot_prepare_mesh
        JointPushPullGeometry.rb: 206 -- robot_call_action
        JointPushPullGeometry.rb: 177 -- geometry_robot_exec
        JointPushPullGeometry.rb: 160 -- geometry_robot
        JointPushPullGeometry.rb: 75 -- block in geometry_execute
        Lib6Operation.rb: 317 -- call
        Lib6Operation.rb: 317 -- step_geometry
        Lib6Operation.rb: 358 -- start_execution
        JointPushPullGeometry.rb: 75 -- geometry_execute
        JointPushPullTool.rb: 879 -- go_preview_or_geom
        JointPushPullTool.rb: 690 -- dragging_stop
        JointPushPullTool.rb: 1303 -- onLButtonUp
        But I was trying them all. I did get the double shell once and the slanted one with the dropped bottom. Try jpp on whole selection with smooth surfaces.
        • mitcorbM
          mitcorb
          Here's a bit of what I did. xray view.
          I think it also depends where on the face you trigger the jpp.
          • brodieB
            brodie
            Here's what I'm getting...
            Dropbox - Error - Simplify your life
            (www.dropbox.com)
            • mitcorbM
              mitcorb
              Hi, Brodie:
              I can't deal with the swf, sorry. Maybe someone else?
              • xiombargX
                xiombarg
                I seem to be having problems with the option of toggling axes from world to local. It doesn't recognize local, only world. I've tried it on both working models and new file. Any clues on this?
                • fredo6F
                  NEW RELEASE: JointPush Pull Interactive v3.2b - 17 Mar 14
                  JointPushPull Interactive 3.2b fixes a number of bugs related to the modes of forced planar direction, which basically did not work.
                  Thanks to xiombarg for signaling this problem.
                  See main post of this thread for Download of JointPushPull.
                  • xiombargX
                    xiombarg
                    I've updated everything, but it still doesn't respond to the local toggle. I've tried to go through and get rid of any unused plugin files and I've used your 'purge obsolete files' utility but to no effect.
                    I guess I could just re-install everything and see what happens.
                    • fredo6F
                      Could you post or PM the model where you have the problem.
                      The local toggle enable to use the axes of the component which contains the picked face selected, instead of the model axes.
                      • xiombargX
                        xiombarg
                        Maybe I'm just doing something incorrectly? But I've never had problems with it until I last updated. It had been quite awhile since I had updated, would that make a difference?
                        http://i9.photobucket.com/albums/a51/xiombarg001/jpp_zpsd18b497b.jpg
                          I think it's a setting thing.
                          • xiombargX
                            xiombarg
                            Nope. Whether I have that "local button" toggled on or off it still sets itself to world. I've tried all sorts of variations of setting the axis and it always resorts to world axis. It almost seems like another script is overriding it as a precedence.
                              Two options come to mind, then. Make a new, temporary Plugins folder. Rename the orignal Old Plugins or something. Then install fresh copies of JPP and LibFredo6 to that folder. See what you get.
                              Or, remove all the other plugins from the current one until you find something that conflicts.
                              • xiombargX
                                xiombarg
                                Right, that's probably what it's come to. I was just hoping that maybe I was overlooking something.
                                  What if you "press" the button below the X in red? That's different in my screen shot compared to yours.
                                    dtrarch
                                    Dear Fredo
                                    If it is at all possible please make the old JPP version work in SU2014?
                                    The old version was so elegant and simple and while the new and improved will do more, for me it just crashes, loses object elements and the settings do not do what they are told to do.
                                    I will be pleased to the first to add to your cookie jar if we could have the option to choose the JPP version to install.
                                    SU user since V2 and honestly I did install the new JPP properly too.
                                    I cleaned out the old version (.....roaming/sketchup and such as well)
                                    Thanks and please
                                    dtr
                                    • xiombargX
                                      xiombarg
                                      Pushing the button below the "X" makes it so that is doesn't lock to any specific axis? That works fine when I use it. It's the locking to a local axis that doesn't work.
                                      Here's the current update:
                                      So I tried uninstalling SU8 and reinstalling it and only loading Libfredo6 and Joint Push Pull and no other plugins installed... It still doesn't work. I'm at a total loss now. I thought for sure that would fix it, but nope.
                                      I can try anything if anyone has any ideas?
                                      • fredo6F
                                        @dtrarch said:
                                        Dear Fredo
                                        Thanks and please
                                        dtr
                                        The old version (v2.1a) is still available at the following post.
                                        It is compatible with SU2014.
                                        You can run the new and old versions concurrently.
                                        PS: do you get bugsplats or intercepted crashes (with a clean dialog box)? And If so, is it during the geometry generation?
                                          dtrarch
                                          Hi Fredo
                                          First thanks for the updated simple JPP version.
                                          Works perfect on SU 2014
                                          I was using the Vector tool(new)with user direction and distance selected.
                                          Preset distance and direction were just not invoked ?
                                          Your error panel showed when trying to extrude and in some cases the surface (topo) disappeared and ctl-z could not recover it.
                                          I just could not get the settings to stick.
                                          Must just be pilot error 😕
                                          Again thank you for all your good works 👍 👍
                                          Dave
                                          • JQLJ
                                            JQL
                                            Hi Fredo,
                                            I cannot thank you enough for this amazing plugin. Among every feature, the improvements you've done to follow pushpull are incredible.
                                            There's just something that I don't know if it could be avoided or not but when I use your plugin it always leaves behind the temp layer it requires to work.
                                            Is it possible to make the plugin auto-delete the layer after finishing command?
                                            I know it's just a small detail and it is ridiculous of me to point it out but...
                                            Thanks for everything,
                                            JQL
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 30
                                            • 31
                                            • 5 / 31
