    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • F
      fantoosh420
      It is for you. please investigate the file.. Joint Push pull not working. giving error.
      TO SKETCHUCATION.skp
      Sketchup 14.0.4900
      Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
      • fredo6F
        Thanks for signaling.
        It is on my list to provide a safe generation mode, as a backup to the current generation mode (which is fast, but assumes the shape is not ill-formed).
        For your model, the problem comes from a lot of lonely vertices (i.e. split edges).
        I suggest you clean them up with, for instance, FredoTools::EdgeInspector or Thomthom's Cleanup.
        Then the generation happens without error.
          @Amit
          Use Fredo's Tools to 'Remove Lonely Vertices' - you have several unneeded vertices along the edges of the form.
          These are very closely spaced and create overlapping extrusions making it fail
          Retry JointPushPull on the corrected form - it will then work...
          I just tried it and it worked...
          [Fredo beat me to it ! 😒 ]
          • F
            fantoosh420
            @ Fredo & TIG
            I already cleaned that before you guys mentioned it but i thought i would be good to share it with you guys so that if it is happening because of any undiscovered reason it can be sorted out.
            As far as having a lot of lonely vertices, it is because of the organic nature of modelling i am currently doing. i am doing a hotel project on the hill and a meandering road was also being modelled which is meant to access the hotel (the surface i sent was one face of a retaining wall coming along the road). I was doing it without cleaning up the geometry due to save time and end the end spent all the saved time due to problem. 😄 😄... never mind since fredo is aware of the situation, a solution is inevitable.
            Sketchup 14.0.4900
            • F
              fantoosh420
              and bi the way fredo, how can i donate you? i don't have a credit card so facing problem... i wanted to donated to TIG to for cutNfill plugin but same problem happened. is there any other way? if no easy way out then i guess i need to figure out a credit card from any of my friend.
              Sketchup 14.0.4900
                We'll both accept PayPal donations.
                You can link those to a Bank-Account without any Credit-Card being needed... 😕
                • F
                  fantoosh420
                  @ TIG.. i tried that.... i guess direct debit by paypal from bank account is not supported here in India. My bank account is connected to paypal but even then it asks for a credit card. it says bank account is to credit money into your account but for debit you need a card. may be i need to figure out a credit card only...
                  Sketchup 14.0.4900
                    Ruf85
                    sorry I have this problem with the last version.
                    Why?
                    When I use the Round push pull
                    Date: 07-Mar-14 16:10:03
                    An error occured in Round Push Pull
                    Error in generation of the geometry
                    undefined method `line_vec=' for nil:NilClass
                    JointPushPullGeometry.rb: 1450 -- geometry_rounding_mesh
                    JointPushPullGeometry.rb: 1275 -- geometry_create_roundings
                    JointPushPullGeometry.rb: 1274 -- each
                    JointPushPullGeometry.rb: 1274 -- geometry_create_roundings
                    JointPushPullGeometry.rb: 262 -- geometry_robot_prepare_mesh
                    JointPushPullGeometry.rb: 206 -- robot_call_action
                    JointPushPullGeometry.rb: 177 -- geometry_robot_exec
                    JointPushPullGeometry.rb: 160 -- geometry_robot
                    JointPushPullGeometry.rb: 75 -- geometry_execute
                    Lib6Operation.rb: 317 -- call
                    Lib6Operation.rb: 317 -- step_geometry
                    Lib6Operation.rb: 358 -- start_execution
                    JointPushPullTool.rb: 879 -- go_preview_or_geom
                    JointPushPullTool.rb: 690 -- dragging_stop
                    JointPushPullTool.rb: 1303 -- onLButtonUp
                    • fredo6F
                      @ruf65,
                      Could you post or PM me the model. I found the problem but would like to check that this is cured.
                        Ruf85
                        Sorry for the delay.
                        It's an element of the roof tile. I would model the front side.
                        Just for teach I use your plugins but I had the error
                        sorry for my bad english. I hope you understand me.
                        SKUpro8
                        • brodieB
                          brodie
                          I'm used to the old JPP so I'm not used to all of the options with the new one which may be causing my issue here. When I use JPP on a cone instead of basically making a bigger cone it pushes the point off to one side and does some weird stuff at the base.
                          What am I doing wrong here?
                          -Brodie
                          • mitcorbM
                            mitcorb
                            Hi, Brodie:
                            I was trying this out and managed to generate a ruby error:
                            Date: 11-Mar-14 19:30:04
                            An error occured in Vector Push Pull
                            Not a valid argument type
                            JointPushPullGeometry.rb: 434 -- *
                            JointPushPullGeometry.rb: 434 -- block in geometry_create_top_face
                            JointPushPullGeometry.rb: 432 -- collect
                            JointPushPullGeometry.rb: 432 -- geometry_create_top_face
                            JointPushPullGeometry.rb: 251 -- block in geometry_robot_prepare_mesh
                            JointPushPullGeometry.rb: 250 -- each
                            JointPushPullGeometry.rb: 250 -- each_with_index
                            JointPushPullGeometry.rb: 250 -- geometry_robot_prepare_mesh
                            JointPushPullGeometry.rb: 75 -- block in geometry_execute
                            But I was trying them all. I did get the double shell once and the slanted one with the dropped bottom. Try jpp on whole selection with smooth surfaces.
                            • mitcorbM
                              mitcorb
                              Here's a bit of what I did. xray view.
                              I think it also depends where on the face you trigger the jpp.
                              • brodieB
                                brodie
                                Here's what I'm getting...
                                Dropbox - Error - Simplify your life
                                (www.dropbox.com)
                                • mitcorbM
                                  mitcorb
                                  Hi, Brodie:
                                  I can't deal with the swf, sorry. Maybe someone else?
                                  • xiombargX
                                    xiombarg
                                    I seem to be having problems with the option of toggling axes from world to local. It doesn't recognize local, only world. I've tried it on both working models and new file. Any clues on this?
                                    • fredo6F
                                      NEW RELEASE: JointPush Pull Interactive v3.2b - 17 Mar 14
                                      JointPushPull Interactive 3.2b fixes a number of bugs related to the modes of forced planar direction, which basically did not work.
                                      Thanks to xiombarg for signaling this problem.
                                      See main post of this thread for Download of JointPushPull.
                                      • xiombargX
                                        xiombarg
                                        I've updated everything, but it still doesn't respond to the local toggle. I've tried to go through and get rid of any unused plugin files and I've used your 'purge obsolete files' utility but to no effect.
                                        I guess I could just re-install everything and see what happens.
                                        • fredo6F
                                          Could you post or PM the model where you have the problem.
                                          The local toggle enable to use the axes of the component which contains the picked face selected, instead of the model axes.
                                          • xiombargX
                                            xiombarg
                                            Maybe I'm just doing something incorrectly? But I've never had problems with it until I last updated. It had been quite awhile since I had updated, would that make a difference?
                                            http://i9.photobucket.com/albums/a51/xiombarg001/jpp_zpsd18b497b.jpg
                                            • 30
                                            • 31
                                            • 4 / 31
