    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.0k Views 155 Watching
    • U
      unearthed
      Agree with Pilou 100% - the plugin writers on here are coming from dozens of different design backgrounds and cultures - so you can expect some individuality in interfaces (and some unique and different approaches to problems), and fredo's tools are great tools - out of all the tools I suggest you start on something like vector or normal (multi-face push-pull) they're pretty amazing all on their own, some serious time savers here.
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
      • fredo6F
        @david.p said:
        As a brand new user to Fredo's tools I am sure that this is all incredibly amazing.
        Only thing is that the GUI looks garbled on pretty much anything other than the standard DPI settings of Windows (which is much too low for nowadays high resolution screens):
        http://666kb.com/i/cm74vc86gocwgwb5h.png
        This is with Windows screen DPI set to 125%.
        Anyway, keep up the great work
        Regards David.P
        It is advised to keep a 100% resolution because the scripts have no control over the size of the text displayed in the GUI.
        Some functions are also available in the VCB and contextual menus.
        • F
          fantoosh420
          It is for you. please investigate the file.. Joint Push pull not working. giving error.
          TO SKETCHUCATION.skp
          Sketchup 14.0.4900
          Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
          • fredo6F
            Thanks for signaling.
            It is on my list to provide a safe generation mode, as a backup to the current generation mode (which is fast, but assumes the shape is not ill-formed).
            For your model, the problem comes from a lot of lonely vertices (i.e. split edges).
            I suggest you clean them up with, for instance, FredoTools::EdgeInspector or Thomthom's Cleanup.
            Then the generation happens without error.
              @Amit
              Use Fredo's Tools to 'Remove Lonely Vertices' - you have several unneeded vertices along the edges of the form.
              These are very closely spaced and create overlapping extrusions making it fail
              Retry JointPushPull on the corrected form - it will then work...
              I just tried it and it worked...
              [Fredo beat me to it ! 😒 ]
              • F
                fantoosh420
                @ Fredo & TIG
                I already cleaned that before you guys mentioned it but i thought i would be good to share it with you guys so that if it is happening because of any undiscovered reason it can be sorted out.
                As far as having a lot of lonely vertices, it is because of the organic nature of modelling i am currently doing. i am doing a hotel project on the hill and a meandering road was also being modelled which is meant to access the hotel (the surface i sent was one face of a retaining wall coming along the road). I was doing it without cleaning up the geometry due to save time and end the end spent all the saved time due to problem. 😄 😄... never mind since fredo is aware of the situation, a solution is inevitable.
                Sketchup 14.0.4900
                • F
                  fantoosh420
                  and bi the way fredo, how can i donate you? i don't have a credit card so facing problem... i wanted to donated to TIG to for cutNfill plugin but same problem happened. is there any other way? if no easy way out then i guess i need to figure out a credit card from any of my friend.
                  Sketchup 14.0.4900
                    We'll both accept PayPal donations.
                    You can link those to a Bank-Account without any Credit-Card being needed... 😕
                    • F
                      fantoosh420
                      @ TIG.. i tried that.... i guess direct debit by paypal from bank account is not supported here in India. My bank account is connected to paypal but even then it asks for a credit card. it says bank account is to credit money into your account but for debit you need a card. may be i need to figure out a credit card only...
                      Sketchup 14.0.4900
                        Ruf85
                        sorry I have this problem with the last version.
                        Why?
                        When I use the Round push pull
                        Date: 07-Mar-14 16:10:03
                        An error occured in Round Push Pull
                        Error in generation of the geometry
                        undefined method `line_vec=' for nil:NilClass
                        JointPushPullGeometry.rb: 1450 -- geometry_rounding_mesh
                        JointPushPullGeometry.rb: 1275 -- geometry_create_roundings
                        JointPushPullGeometry.rb: 1274 -- each
                        JointPushPullGeometry.rb: 1274 -- geometry_create_roundings
                        JointPushPullGeometry.rb: 262 -- geometry_robot_prepare_mesh
                        JointPushPullGeometry.rb: 206 -- robot_call_action
                        JointPushPullGeometry.rb: 177 -- geometry_robot_exec
                        JointPushPullGeometry.rb: 160 -- geometry_robot
                        JointPushPullGeometry.rb: 75 -- geometry_execute
                        Lib6Operation.rb: 317 -- call
                        Lib6Operation.rb: 317 -- step_geometry
                        Lib6Operation.rb: 358 -- start_execution
                        JointPushPullTool.rb: 879 -- go_preview_or_geom
                        JointPushPullTool.rb: 690 -- dragging_stop
                        JointPushPullTool.rb: 1303 -- onLButtonUp
                        • fredo6F
                          @ruf65,
                          Could you post or PM me the model. I found the problem but would like to check that this is cured.
                            Ruf85
                            Sorry for the delay.
                            It's an element of the roof tile. I would model the front side.
                            Just for teach I use your plugins but I had the error
                            sorry for my bad english. I hope you understand me.
                            SKUpro8
                            • brodieB
                              brodie
                              I'm used to the old JPP so I'm not used to all of the options with the new one which may be causing my issue here. When I use JPP on a cone instead of basically making a bigger cone it pushes the point off to one side and does some weird stuff at the base.
                              What am I doing wrong here?
                              -Brodie
                              • mitcorbM
                                mitcorb
                                Hi, Brodie:
                                I was trying this out and managed to generate a ruby error:
                                Date: 11-Mar-14 19:30:04
                                An error occured in Vector Push Pull
                                Not a valid argument type
                                JointPushPullGeometry.rb: 434 -- *
                                JointPushPullGeometry.rb: 434 -- block in geometry_create_top_face
                                JointPushPullGeometry.rb: 432 -- collect
                                JointPushPullGeometry.rb: 432 -- geometry_create_top_face
                                JointPushPullGeometry.rb: 251 -- block in geometry_robot_prepare_mesh
                                JointPushPullGeometry.rb: 250 -- each
                                JointPushPullGeometry.rb: 250 -- each_with_index
                                JointPushPullGeometry.rb: 250 -- geometry_robot_prepare_mesh
                                JointPushPullGeometry.rb: 75 -- block in geometry_execute
                                But I was trying them all. I did get the double shell once and the slanted one with the dropped bottom. Try jpp on whole selection with smooth surfaces.
                                • mitcorbM
                                  mitcorb
                                  Here's a bit of what I did. xray view.
                                  I think it also depends where on the face you trigger the jpp.
                                  • brodieB
                                    brodie
                                    Here's what I'm getting...
                                    Dropbox - Error - Simplify your life
                                    (www.dropbox.com)
                                    • mitcorbM
                                      mitcorb
                                      Hi, Brodie:
                                      I can't deal with the swf, sorry. Maybe someone else?
                                      • xiombargX
                                        xiombarg
                                        I seem to be having problems with the option of toggling axes from world to local. It doesn't recognize local, only world. I've tried it on both working models and new file. Any clues on this?
                                        • fredo6F
                                          NEW RELEASE: JointPush Pull Interactive v3.2b - 17 Mar 14
                                          JointPushPull Interactive 3.2b fixes a number of bugs related to the modes of forced planar direction, which basically did not work.
                                          Thanks to xiombarg for signaling this problem.
                                          See main post of this thread for Download of JointPushPull.
                                          • xiombargX
                                            xiombarg
                                            I've updated everything, but it still doesn't respond to the local toggle. I've tried to go through and get rid of any unused plugin files and I've used your 'purge obsolete files' utility but to no effect.
                                            I guess I could just re-install everything and see what happens.
                                            • 30
                                            • 31
                                            • 4 / 31
