    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 295.6k Views 135 Watching
      πŸ’š
      	100001
      	11000
      	1110
      	100011
      	1100
      	10001
      	100100
      	11110
        Found a cool one today.
        Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
        What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
        However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
        -Brodie
        Duh!
        That is sweet!
        The manual doesn't even mention this!
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
        • H Offline
          Heaps
          It even works with circular arrays - just type in the angle in degrees
          • brodieB Offline
            brodie
            However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
            -Brodie
            • broomstickB Offline
              broomstick
              -Brodie
              This, sir, just made my day!
              • Bob JamesB Offline
                Bob James
                • jgbJ Offline
                  jgb
                  Found a cool one today. πŸ˜’
                  -Brodie
                  I just wish you found this last week, when I needed it. πŸ˜†
                  jgb
                    d12dozr
                    -Brodie
                    I learned that just a couple months ago from Dave R at a local meetup πŸ‘
                    http://goo.gl/f7ooYh
                    • aarondietzenA Offline
                      aarondietzen
                      Shift + Eraser to smooth...
                      I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
                      Ah... feels good to share my stupidity!
                      "Imagination is more important than knowledge..."
                      - Albert Einstein
                      • massimoM Offline
                        massimo Moderator
                        Ctrl+ eraser is to smooth. Shift+eraser is to hide. πŸ˜‰
                          aarondietzen
                          Stupidity x2! πŸ˜†
                          - Albert Einstein
                            Ctrl+Erase = Soft+Smooth
                            Shift+Erase = Hide
                            Ctrl+Shift+Erase = Un-soft+Smooth (But not Unhide!)
                              Shift+Erase = Hide
                              Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']...
                                aarondietzen
                                @tig said:
                                Shift+Erase = Hide
                                "Learn something new everyday!"
                                In this case... several new things.
                                - Albert Einstein
                                  -Brodie
                                  Duh!
                                  That is sweet!
                                  Seems that is more missing here πŸ˜‰
                                  http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867&topic=2458142&ctx=topic
                                  • emerald15E Offline
                                    emerald15
                                    You've lost me now...I usually type in x(number) not *(number). But how do I get back to degrees... how does one type 'degrees'! ACAD is 'dd%d' but what is SU?
                                      Typing an 'x' or '*' is the same - so you can type x2, *2 , 2x etc for 'times'.
                                      To 'divide' the copies use /2...
                                      You never need to use a 'degree' symbol with Rotate, any typed in +ve or -ve numbers that don't contain an x, * or / are taken as degrees anyway... In Move [and tools like Line] it's taken as 'current units', unless you add a units suffix, so typing 1000 while using mm Moves the object 1000mm, but to move it a specific distance in feet+inches can be done even while the model's current-units is mm - e.g. typing 3'4" will Move that exact amount [1016mm] etc...
                                      Incidentally, if you want to type 'special characters' in Sketchup Text - like degrees [Β°] - there are OS specific key-strokes, on a PC it's Alt0176, on a MAC I think it's OptionShift8. There are lots, so if you use some regularly have a crib sheet handy...
                                      • jgbJ Offline
                                        jgb
                                        This is also a question, based on the above.
                                        Using SCALE, you can just type a percentage value in the VCB. This is handy to set a specific scale factor like 92%. It is also handy to set a scale factor that is between SCALE's preset snap tolerance of .1% so just type 90.15 in the VCB where SCALE snaps only to 90.1% or 90.2% and you need the precision.
                                        OK, my question, How do I set scale to a dimensional value?
                                        ie: my object is 12 inches, and I want it to be 13 inches, without doing the percentage math. AND I am holding the CTRL and SHIFT keys down to scale all and from the center. When I release the mouse button to type, my position is lost.
                                        jgb
                                          Just scale roughly first - then use the VCB to adjust with accuracy afterwards - typing in the length.
                                            Just draw a 13 inch segment from a vertex from your object and Scale your object by the line! πŸ˜‰
                                            Alas this just work only with "cubic" objects! πŸ€“
                                            If you have inclined faces you must don't use the native Scale tool!!!
                                            • 34
                                            • 35
                                            • 5 / 35
