    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 526.6k Views 102 Watching
    • OxerO Offline
      Oxer
      Oxer,
      Did it work in previous versions?
      Or other Mac OS versions?
      No, it doesn't work in previous version.
      I haven't probed other Mac OS versions.
        Pherim
        This is really great, thank you for fulfilling my request!
        It works great, just how I wanted it to. [[Just one small thing: It would be perfect to me if the "sample material" tool could also adopt the scale of the sampled material.
        I hope I don't bother you with my daydreams... πŸ˜’]] edit: never mind, it works perfectly! πŸ‘
        • fredo6F Offline
          Oxer,
          Strange because it works for some other Mac users
          Could you type in the Ruby Console
          • VK_DOWN
          • VK_UP
          • VK_LEFT
          • VK_RIGHT
          • OxerO Offline
            Oxer
            This is the result in the Ruby Console:
              moghamdi
              Thank you Fredo for this nice Plugin.
              I have a problem
              I have a Mac 10.6.8 and I cannot transform the texture. I tried all 3 ways you mentioned but they did not work.
              • fredo6F Offline
                I have a problem
                Could you open the Ruby console and see if something is displayed.
                It seems that the Arrows don't work on all Mac, but the VCB and Visual Editor should normally function correctly.
                • fredo6F Offline
                  [attachment=0:23qhhc8q]<!-- ia0 -->Ruby Console.jpg<!-- ia0 -->[/attachment:23qhhc8q]
                  Oxer,
                  Thanks. Interesting to see that the value may be different depending on the Mac versions (on the Mac I have access to, VK_DOWN = 63233
                  Anyway, ThruPaint only use the symbolic constant value VK_DOWN and therefore should not be impacted by the internal value of the Arrows constants.
                  It seems also that several Mac users don't have any problem with the Arrows on Mac.
                  Just in case, could you type in the Ruby Console Traductor.new_check_key(VK_DOWN, 0, 0).
                  Also, when you try to exercise transformation by arrows on texture, could you leave the Ruby console open to see if an error message is displayed. Also, make sure that the focus is on the Sketchup window when typing the arrows.
                  • TIGT Online
                    In my scripts that use arrows keys I use this
                    if RUBY_PLATFORM=~/mswin32/ ### PC
                      KALXMINUS = 37          # Arrow Left Key
                      KARXPLUS  = 39          # Arrow Right Key
                      KAUYPLUS  = 38          # Arrow Up Key
                      KADYMINUS = 40          # Arrow Down Key
                      KSHIFT    = 16          # Shift Key
                    else### MAC
                      KALXMINUS = 63234       # Arrow Left Key
                      KARXPLUS  = 63235       # Arrow Right Key
                      KAUYPLUS  = 63232       # Arrow Up Key
                      KADYMINUS = 63233       # Arrow Down Key
                      KSHIFT    = 131072      # Shift Key
                    end#if
                    and then test key-down events etc against these 'constants'
                      > else### MAC
                      > end#if
                      Why don't you use the built in constants? They should be reflecting the correct value based on the current OS. When you do it manually you have to keep updating it....
                      • fredo6F Offline
                        @Thomthom: I agree with you and my scripts do use the built-in constants for Arrow (and Shift, Ctrl). This is why I don't understand why it does not work. I was just wondering why the VK_constants for Oxer where in the range 123-126 whereas on the Mac I can have access to there are in the range of 63232... One possibility is that another script redefines the constants VK_.... because as far as I know, there is only a single Mac release of Sketchup, and therefore of the Ruby API (unless the Ruby API check itself the version of Mac OS).
                        @TIG: the values you show are correct for the Mac, as far as I knew them.
                          I assumed that SketchUp got the key code values from the system when it initialized the Ruby interpreter and abstracted them into these system-safe constants...
                            redog
                            for me u are a genius in sketchup you can now manage the textures in an intelligent way. thanks fridoooooo. grazie 😍 πŸ‘ πŸ‘ 😍
                              moghamdi
                              I have Sketchup 8 Pro
                              • fredo6F Offline
                                NEW RELEASE: ThruPaint v1.2a - 08 May 12
                                This update fixes some bugs and introduces 2 functional evolutions
                                1) Painting of components / groups, text labels and dimensions
                                This is a new option in the palette, very similar to the native SU Paint tool. Originally, ThruPaint was painting faces within the boundaries of containers. There are however cases where you wish to assign a material to the component or group itself. This material becomes then the default material for the faces of the component
                                2) Modifier for Sampler
                                If you press Shift key, the cursor changes to sampling instead of painting. In the native SU Paint tool, this feature is covered by the Alt key (on Windows), but this is not possible in Ruby.
                                See main post of this thread for more information on ThruPaint.
                                See main post of FredoTools thread for download of FredoTools, which includes the ThruPaint script.
                                • fredo6F Offline
                                  NEW RELEASE: ThruPaint v1.0n - 21 Apr 12
                                  This update introduces 2 functional evolutions
                                  1) Painting of a preselection of faces or edges
                                  If you select faces or edges before launching ThruPaint, the painted faces or edges will be those of the preselection whenever you mouse over them (regardless of the face selection settings in the palette).
                                  • When the material is a color or for edge painting, the painting applies to the whole pre-selection
                                  • When the material is a texture, you have to paint by groups of faces in the preselection
                                  2) Remembering of last scaling and rotation factors by material.
                                  This is inspired from a request by Pherim
                                  If you apply a textured material to a face and then scale it and/or rotate it, the scaling and rotation factors will be remembered the next time you apply this material.
                                  Likewise, the sampling of material within the model also copy the scaling and rotation factors.
                                  See main post of FredoTools thread for download of FredoTools, which includes the script.
                                    tomislavm
                                    Thank You.
                                    • N Offline
                                      numerobis
                                      Really a fantastic plugin! I have to say it again! Thanks a lot!
                                      But i have noticed a problem with exporting textured object for rendering, maxwell in my case...
                                      The problem is that the exporter writes a seperated material and texture for each face! So with a complex gepmetry this results in thousands of textures and materials.
                                      My question is now, is it possible to avoid this behavior? I'm painting as QuadMesh.
                                      Or is this problem maxwell related? I noticed the same thing when i use photomatch for texturing.
                                      Can anyone say how this works with vray?
                                      edit: ok, problem solved... disabling texture distortions in maxwell uv export options did it. I thought this would result in distorted mapping but for now it works.
                                      Thanks again for this incredible tool, Fredo!!!
                                      Trimble should buy this from you as standart mapping method! 😎
                                        shri
                                        many many thanks for your great tool.. πŸ‘
                                        • majidM Offline
                                          majid
                                          unique genius Fredeo!!!!! many many thank you, this is greaaat
                                          • pietervP Offline
                                            pieterv
                                            Hey Fredo,
                                            Thanks a lot for the great plugin! You are a hero.
                                            I have a slight problem tho. I used your plugin and in sketchup it looks like this
                                            http://www.citypixels.be/wp-content/uploads/2012/10/sketchup-thrupaint-01.png
                                            but when I render it in Maxwell Render it looks like this:
                                            http://www.citypixels.be/wp-content/uploads/2012/10/simpel-huis-render-017.jpg
                                            The yellow stones in the little wall have become much smaller and the middle part of the street has become darker. Do you have an idea what the problem could be?
                                            Pieter
                                            This is my website:
                                            Citypixels - 3d Visualisatie Architectuur
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
