    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.0k Views 102 Watching
    • fredo6F
      @Thomthom: I agree with you and my scripts do use the built-in constants for Arrow (and Shift, Ctrl). This is why I don't understand why it does not work. I was just wondering why the VK_constants for Oxer where in the range 123-126 whereas on the Mac I can have access to there are in the range of 63232... One possibility is that another script redefines the constants VK_.... because as far as I know, there is only a single Mac release of Sketchup, and therefore of the Ruby API (unless the Ruby API check itself the version of Mac OS).
      @TIG: the values you show are correct for the Mac, as far as I knew them.
        I assumed that SketchUp got the key code values from the system when it initialized the Ruby interpreter and abstracted them into these system-safe constants...
          redog
          for me u are a genius in sketchup you can now manage the textures in an intelligent way. thanks fridoooooo. grazie 😍 πŸ‘ πŸ‘ 😍
            moghamdi
            This is the result in the Ruby Console:
            I have Sketchup 8 Pro
            • fredo6F
              NEW RELEASE: ThruPaint v1.2a - 08 May 12
              This update fixes some bugs and introduces 2 functional evolutions
              1) Painting of components / groups, text labels and dimensions
              This is a new option in the palette, very similar to the native SU Paint tool. Originally, ThruPaint was painting faces within the boundaries of containers. There are however cases where you wish to assign a material to the component or group itself. This material becomes then the default material for the faces of the component
              2) Modifier for Sampler
              If you press Shift key, the cursor changes to sampling instead of painting. In the native SU Paint tool, this feature is covered by the Alt key (on Windows), but this is not possible in Ruby.
              See main post of this thread for more information on ThruPaint.
              See main post of FredoTools thread for download of FredoTools, which includes the ThruPaint script.
              • fredo6F
                NEW RELEASE: ThruPaint v1.0n - 21 Apr 12
                This update introduces 2 functional evolutions
                1) Painting of a preselection of faces or edges
                If you select faces or edges before launching ThruPaint, the painted faces or edges will be those of the preselection whenever you mouse over them (regardless of the face selection settings in the palette).
                • When the material is a color or for edge painting, the painting applies to the whole pre-selection
                • When the material is a texture, you have to paint by groups of faces in the preselection
                2) Remembering of last scaling and rotation factors by material.
                This is inspired from a request by Pherim
                If you apply a textured material to a face and then scale it and/or rotate it, the scaling and rotation factors will be remembered the next time you apply this material.
                Likewise, the sampling of material within the model also copy the scaling and rotation factors.
                See main post of FredoTools thread for download of FredoTools, which includes the script.
                • T
                  tomislavm
                  Thank You.
                  • N
                    numerobis
                    Really a fantastic plugin! I have to say it again! Thanks a lot!
                    But i have noticed a problem with exporting textured object for rendering, maxwell in my case...
                    The problem is that the exporter writes a seperated material and texture for each face! So with a complex gepmetry this results in thousands of textures and materials.
                    My question is now, is it possible to avoid this behavior? I'm painting as QuadMesh.
                    Or is this problem maxwell related? I noticed the same thing when i use photomatch for texturing.
                    Can anyone say how this works with vray?
                    edit: ok, problem solved... disabling texture distortions in maxwell uv export options did it. I thought this would result in distorted mapping but for now it works.
                    Thanks again for this incredible tool, Fredo!!!
                    Trimble should buy this from you as standart mapping method! 😎
                      shri
                      many many thanks for your great tool.. πŸ‘
                      • majidM
                        majid
                        unique genius Fredeo!!!!! many many thank you, this is greaaat
                        • pietervP
                          pieterv
                          Hey Fredo,
                          Thanks a lot for the great plugin! You are a hero.
                          I have a slight problem tho. I used your plugin and in sketchup it looks like this
                          http://www.citypixels.be/wp-content/uploads/2012/10/sketchup-thrupaint-01.png
                          but when I render it in Maxwell Render it looks like this:
                          http://www.citypixels.be/wp-content/uploads/2012/10/simpel-huis-render-017.jpg
                          The yellow stones in the little wall have become much smaller and the middle part of the street has become darker. Do you have an idea what the problem could be?
                          Pieter
                          This is my website:
                          Citypixels - 3d Visualisatie Architectuur
                            Check if the two surfaces have the material applied in a different way.
                            I suspect that one has the material applied to the face itself while the other has the material applied to the 'container' [group/component-instance] - check this by using 'Entity Info' and selecting the actual faces in each case - the 'mapping' cannot persist into exported formats when applied to a container rather than the face itself... Of course it might be a Maxwell issue with it mis-handing the UVmapping ?
                              Contact Maxwell support - as this is their render engine that doesn't properly process the UV mapping.
                              • pietervP
                                pieterv
                                I have checked, and the two materials are axactly the same. I have the free version of Maxwell Render, so I'll repost this under "extensions & applications". Thanks for answering!
                                This is my website:
                                  I'd still recommend you contact Maxwell - as this would then be something that presumably affects all users. Reporting issues to the developers is important - otherwise it'll never get fixed.
                                  • C
                                    cadmunkey
                                    Is this plugin for premium members only? If I click the download icon I get a banner.png.
                                    • massimoM
                                      massimo Moderator
                                      ThruPaint is installed as part of FredoTools.. It requires LibFredo6 4.4 or above.
                                      See the main post for this plugin for Installation of FredoTools
                                      So you have to go to Fredo tools thread to download the plugin. Scroll down the page and you'll find it below the "download" icon.
                                      • C
                                        cadmunkey
                                        Cheers!
                                        • masterpaulM
                                          masterpaul
                                          I cant seem to texture this irregular surface, it just wont do it, textures wont align no matter what, and they also rotated differently everywhere.
                                          Edit: Uploaded the file also.
                                          Trickeywall.skp
                                          • fredo6F
                                            The surafce is very 'irregular' actually. Unless it is made of Quads (with Thomthom's convention), I am afraid it cannot be properly mapped with ThruPaint.
                                            I would recommend you try with SketchUV plugin, which is more specialized in UV-mapping any kind of surface.
                                            • 16
                                            • 17
                                            • 5 / 17
