[Plugin Library] LibFredo6 - v14.4d - 20 May 24
Is the LibFredo6-34 supposed to stay in the di
rectory after extracting? -
You should have a folder called "LIBFREDO6_Dir_43" and a file called "LibFredo6.rb" If you installed the current version you shouldn't have "LibFredo6-34" at all.
Well it was there, not now now it just shows 4.3
not sure if it is the LibFredo 4.3b or the BezierSpline 1.4f plugin, but if the LibFredo 4.3b is enabled, the BezierSpline 1.4f does not work. i get a Ruby console error for line 592 cannot convert nil to float.
Error: #<TypeError: no implicit conversion to float from nil>
C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in-' C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in
onMouseMove'Fredo tools works regardless of BezierSplines being enabled or not.
NOTE: I only encountered this error since updating to 4.3b and prior to that it was working correctly. -
I can't download?
@wt00320371 said:
I can't download?
What file?
What problem/error messages?
More information, please...
I think that I've installed LibFredo6 v.4.3 and the Round corner plugins correctly. But when I launch SketchUp (I'm using Version 7 on Mac OS 10.4.11) is get this error message: Error Loading File LibFredo6.rb
can't convert nil into StringWhat does this mean and how can I fix it? Can someone assist me.
I'm running SketchUp 7 on Mac OS 10.4.11. I've downloaded and installed both LibFredo6 v4.3 and Round Corner plugin and both are not working. When I start up SU7 I get the error message: "Error Loading File LibFredo6.rb
can't convert nil into String". I have no idea what this means. Can someone help?Thanks a million!
Here is a screen shot of my plugins folder
Just in case, can you type
ENV["TEMP"]
in the Ruby Console and tell me what you see.Thanks
I use
tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
This is what I use to detect temp path:
TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
@tig said:
I use
TIG,
Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
@supercylon
Can you typeENV["TMPDIR"]
in the Ruby consoleFred
ENV["TEMP"]
Hello Fredo,
Thanks for your assistance. I did what you asked and here is a screenshot of the result.
![Results of ENV["TEMP"] in Ruby Console](/uploads/imported_attachments/iUOu_Picture2.png "Results of ENV["TEMP"] in Ruby Console")
Thanks Supercylon
@tig said:
I use
TIG,
@supercylon
I didn't notice this message, here is the screen shot of the result of your second request.
Thanks,
Supercylon -
And
ENV['TMP']
Can you try withe attached file to see if your error disappear and SU starts OK.
[attachment=0:2f69w8lx]<!-- ia0 -->LibFredo6.rb<!-- ia0 -->[/attachment:2f69w8lx]Thanks
Fredo,
Thank you!Thank you! It works!
Supercylon
Supercylon
I will release the change tomorrow as v4.3c
It is strange however that on your Mac, the TMPDIR Environment variable is not defined.
@TIG, Thomthom: I just use
/tmp
when TMPDIR is not defined.Fredo
EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
Under Ubuntu makes SU to crach on startup
It's difficult for me to diagnose on this platform which I don't have.
I think there are a few users running Sketchup on Linux flavors, and they may help you to troubleshoot.Fredo
