    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • fredo6F
      @eyffel65girl said:
      Fredo your plugin is awesome, but I can't use it! I run Skethcup Pro 7 on my Mac Book Pro. I've installed your plugin (LibFredo6 first, and then RoundCorner) following your detailed instructions; I thought it were an easy things to do, but they don't work! 😒
      Can you please help me?? I'll always be graitfull !!
      It might come from the Unzip operation, which is a frequent problem, especially on Mac.
      Please make sure that in the SU Plugins directory you have the right footprint, that is:
      • LibFredo6.rb
      • LIBFREDO6_Dir_43 folder
      • ROUNDCORNER_Dir_23 folder
        rjjvirusx
        hooooory
        • T
          tspco
          Is the LibFredo6-34 supposed to stay in the di
          rectory after extracting?
          SU make 2017, /Twilight Render Hobby
          Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
            You should have a folder called "LIBFREDO6_Dir_43" and a file called "LibFredo6.rb" If you installed the current version you shouldn't have "LibFredo6-34" at all.
            • T
              tspco
              Well it was there, not now now it just shows 4.3
              • gullfoG
                gullfo
                not sure if it is the LibFredo 4.3b or the BezierSpline 1.4f plugin, but if the LibFredo 4.3b is enabled, the BezierSpline 1.4f does not work. i get a Ruby console error for line 592 cannot convert nil to float.
                Error: #<TypeError: no implicit conversion to float from nil>
                C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in -' C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in onMouseMove'
                Fredo tools works regardless of BezierSplines being enabled or not.
                NOTE: I only encountered this error since updating to 4.3b and prior to that it was working correctly.
                Glenn
                http://www.runnel.com
                • W
                  wt00320371
                  I can't download?
                    @wt00320371 said:
                    I can't download?
                    What file?
                    What problem/error messages?
                    More information, please...
                    πŸ˜•
                      supercylon
                      I think that I've installed LibFredo6 v.4.3 and the Round corner plugins correctly. But when I launch SketchUp (I'm using Version 7 on Mac OS 10.4.11) is get this error message: Error Loading File LibFredo6.rb
                      can't convert nil into String
                      What does this mean and how can I fix it? Can someone assist me.
                        supercylon
                        I'm running SketchUp 7 on Mac OS 10.4.11. I've downloaded and installed both LibFredo6 v4.3 and Round Corner plugin and both are not working. When I start up SU7 I get the error message: "Error Loading File LibFredo6.rb
                        can't convert nil into String". I have no idea what this means. Can someone help?
                        Thanks a million!
                        Here is a screen shot of my plugins folder
                        My plugins folder
                        • fredo6F
                          @supercylon
                          Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
                            I use
                            tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
                            πŸ˜•
                              This is what I use to detect temp path:
                              TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
                              • fredo6F
                                @tig said:
                                I use
                                πŸ˜•
                                TIG,
                                Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
                                @supercylon
                                Can you type ENV["TMPDIR"] in the Ruby console
                                Fred
                                  supercylon
                                  @supercylon
                                  Hello Fredo,
                                  Thanks for your assistance. I did what you asked and here is a screenshot of the result.
                                  ![Results of ENV["TEMP"] in Ruby Console](/uploads/imported_attachments/iUOu_Picture2.png "Results of ENV["TEMP"] in Ruby Console")
                                  Thanks Supercylon
                                    supercylon
                                    @tig said:
                                    I use
                                    πŸ˜•
                                    TIG,
                                    @supercylon
                                    Fred
                                    I didn't notice this message, here is the screen shot of the result of your second request.
                                    Thanks,
                                    Supercylon
                                      And ENV['TMP'] ?
                                        supercylon
                                        @supercylon
                                        Can you try withe attached file to see if your error disappear and SU starts OK.
                                        [attachment=0:2f69w8lx]<!-- ia0 -->LibFredo6.rb<!-- ia0 -->[/attachment:2f69w8lx]
                                        Fredo,
                                        Thank you!Thank you! It works!
                                        Supercylon
                                        • fredo6F
                                          Supercylon
                                          I will release the change tomorrow as v4.3c
                                          It is strange however that on your Mac, the TMPDIR Environment variable is not defined.
                                          @TIG, Thomthom: I just use /tmp when TMPDIR is not defined.
                                          • fredo6F
                                            @supercylon
                                            EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 115
                                            • 116
                                            • 18 / 116
