    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
    • n000bieN Offline
      n000bie
      My greatful thnx to you and your quick respond, problem solved πŸ˜„ . Looks like I have to update my Fredo Scale.
      Thnx again, Fredo, you're the one. πŸ‘
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v4.3a - 19 Dec 11
        LibFredo6 4.3 is a new release which essentially support the publishing of FredoTools suite of Plugins
          tspco
          Don't know if this is a problem or not, just installed the 20dec11 update of fredo 6
          SU make 2017, /Twilight Render Hobby
          Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
          • fredo6F Offline
            These are binary files.
            It is strange that your unzip utility (I guess 7-zip) tries to open them. It should not.
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v4.3b - 22 Dec 11
              Release 4.3b includes (on top of 4.3a)
              • a fix to the numeric buttons in Palettes (not visible in Curviloft)
              • the updated Spanish translation (thanks to Defisto)
              • E Offline
                eyffel65girl
                Fredo your plugin is awesome, but I can't use it! I run Skethcup Pro 7 on my Mac Book Pro. I've installed your plugin (LibFredo6 first, and then RoundCorner) following your detailed instructions; I thought it were an easy things to do, but they don't work! 😒
                Can you please help me?? I'll always be graitfull !!
                • O Offline
                  oldswinger
                  Dear Fredo
                  I have downloaded the first 4 plugins from your Plugin Library list "Libfredo6 v4.3b - 22Dec11 but cannot get any toolbar icons appearing when I open my SU8Pro programme.
                  I note your Important Paragraph about the downloading of LibFredo6 in respect of the appearance of the plugin toolbars but inspite of following the download instructions precisely I can only access the 4 plugins via the entry "Fredo6 Collection" in the Tools menu.
                  I have ticked off the plugins Fredo Scale & Tools on Surface in the VIEW/TOOLBAR menu but Curiloft & Roundcorner are not shown in the dropdown menu.
                  I would be extremely gratefull if you could suggest where I am going wrong as without the plugin icons showing in the main toolbar it becomes rather difficult to use the plugins to their best advantage.
                  Best regards
                  OldSwinger
                  • fredo6F Offline
                    It might come from the Unzip operation, which is a frequent problem, especially on Mac.
                    Please make sure that in the SU Plugins directory you have the right footprint, that is:
                    • LibFredo6.rb
                    • LIBFREDO6_Dir_43 folder
                    • ROUNDCORNER_Dir_23 folder
                      rjjvirusx
                      hooooory
                        tspco
                        Is the LibFredo6-34 supposed to stay in the di
                        rectory after extracting?
                          You should have a folder called "LIBFREDO6_Dir_43" and a file called "LibFredo6.rb" If you installed the current version you shouldn't have "LibFredo6-34" at all.
                            tspco
                            Well it was there, not now now it just shows 4.3
                            • gullfoG Offline
                              gullfo
                              not sure if it is the LibFredo 4.3b or the BezierSpline 1.4f plugin, but if the LibFredo 4.3b is enabled, the BezierSpline 1.4f does not work. i get a Ruby console error for line 592 cannot convert nil to float.
                              Error: #<TypeError: no implicit conversion to float from nil>
                              C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in -' C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in onMouseMove'
                              Fredo tools works regardless of BezierSplines being enabled or not.
                              NOTE: I only encountered this error since updating to 4.3b and prior to that it was working correctly.
                              Glenn
                              http://www.runnel.com
                              • W Offline
                                wt00320371
                                I can't download?
                                  @wt00320371 said:
                                  I can't download?
                                  What file?
                                  What problem/error messages?
                                  More information, please...
                                  πŸ˜•
                                    supercylon
                                    I think that I've installed LibFredo6 v.4.3 and the Round corner plugins correctly. But when I launch SketchUp (I'm using Version 7 on Mac OS 10.4.11) is get this error message: Error Loading File LibFredo6.rb
                                    can't convert nil into String
                                    What does this mean and how can I fix it? Can someone assist me.
                                      supercylon
                                      I'm running SketchUp 7 on Mac OS 10.4.11. I've downloaded and installed both LibFredo6 v4.3 and Round Corner plugin and both are not working. When I start up SU7 I get the error message: "Error Loading File LibFredo6.rb
                                      can't convert nil into String". I have no idea what this means. Can someone help?
                                      Thanks a million!
                                      Here is a screen shot of my plugins folder
                                      My plugins folder
                                      • fredo6F Offline
                                        @supercylon
                                        Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
                                          I use
                                          tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
                                          πŸ˜•
                                            This is what I use to detect temp path:
                                            TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 111
                                            • 112
                                            • 18 / 112
