    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.0m Views 585 Watching
    • T
      tspco
      Don't know if this is a problem or not, just installed the 20dec11 update of fredo 6
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • fredo6F
        These are binary files.
        It is strange that your unzip utility (I guess 7-zip) tries to open them. It should not.
        • fredo6F
          NEW RELEASE: LibFredo6 v4.3b - 22 Dec 11
          LibFredo6 4.3 is a new release which essentially support the publishing of FredoTools suite of Plugins
          Release 4.3b includes (on top of 4.3a)
          • a fix to the numeric buttons in Palettes (not visible in Curviloft)
          • the updated Spanish translation (thanks to Defisto)
          • E
            eyffel65girl
            Fredo your plugin is awesome, but I can't use it! I run Skethcup Pro 7 on my Mac Book Pro. I've installed your plugin (LibFredo6 first, and then RoundCorner) following your detailed instructions; I thought it were an easy things to do, but they don't work! 😒
            Can you please help me?? I'll always be graitfull !!
            • O
              oldswinger
              Dear Fredo
              I have downloaded the first 4 plugins from your Plugin Library list "Libfredo6 v4.3b - 22Dec11 but cannot get any toolbar icons appearing when I open my SU8Pro programme.
              I note your Important Paragraph about the downloading of LibFredo6 in respect of the appearance of the plugin toolbars but inspite of following the download instructions precisely I can only access the 4 plugins via the entry "Fredo6 Collection" in the Tools menu.
              I have ticked off the plugins Fredo Scale & Tools on Surface in the VIEW/TOOLBAR menu but Curiloft & Roundcorner are not shown in the dropdown menu.
              I would be extremely gratefull if you could suggest where I am going wrong as without the plugin icons showing in the main toolbar it becomes rather difficult to use the plugins to their best advantage.
              Best regards
              OldSwinger
              • fredo6F
                It might come from the Unzip operation, which is a frequent problem, especially on Mac.
                Please make sure that in the SU Plugins directory you have the right footprint, that is:
                • LibFredo6.rb
                • LIBFREDO6_Dir_43 folder
                • ROUNDCORNER_Dir_23 folder
                  rjjvirusx
                  hooooory
                  • T
                    tspco
                    Is the LibFredo6-34 supposed to stay in the di
                    rectory after extracting?
                      You should have a folder called "LIBFREDO6_Dir_43" and a file called "LibFredo6.rb" If you installed the current version you shouldn't have "LibFredo6-34" at all.
                      • T
                        tspco
                        Well it was there, not now now it just shows 4.3
                        • gullfoG
                          gullfo
                          not sure if it is the LibFredo 4.3b or the BezierSpline 1.4f plugin, but if the LibFredo 4.3b is enabled, the BezierSpline 1.4f does not work. i get a Ruby console error for line 592 cannot convert nil to float.
                          Error: #<TypeError: no implicit conversion to float from nil>
                          C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in -' C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in onMouseMove'
                          Fredo tools works regardless of BezierSplines being enabled or not.
                          NOTE: I only encountered this error since updating to 4.3b and prior to that it was working correctly.
                          Glenn
                          http://www.runnel.com
                          • W
                            wt00320371
                            I can't download?
                              @wt00320371 said:
                              I can't download?
                              What file?
                              What problem/error messages?
                              More information, please...
                              πŸ˜•
                                supercylon
                                I think that I've installed LibFredo6 v.4.3 and the Round corner plugins correctly. But when I launch SketchUp (I'm using Version 7 on Mac OS 10.4.11) is get this error message: Error Loading File LibFredo6.rb
                                can't convert nil into String
                                What does this mean and how can I fix it? Can someone assist me.
                                  supercylon
                                  I'm running SketchUp 7 on Mac OS 10.4.11. I've downloaded and installed both LibFredo6 v4.3 and Round Corner plugin and both are not working. When I start up SU7 I get the error message: "Error Loading File LibFredo6.rb
                                  can't convert nil into String". I have no idea what this means. Can someone help?
                                  Thanks a million!
                                  Here is a screen shot of my plugins folder
                                  My plugins folder
                                  • fredo6F
                                    @supercylon
                                    Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
                                      I use
                                      tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
                                      πŸ˜•
                                        This is what I use to detect temp path:
                                        TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
                                        • fredo6F
                                          @tig said:
                                          I use
                                          πŸ˜•
                                          TIG,
                                          Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
                                          @supercylon
                                          Can you type ENV["TMPDIR"] in the Ruby console
                                          Fred
                                            supercylon
                                            @supercylon
                                            Hello Fredo,
                                            Thanks for your assistance. I did what you asked and here is a screenshot of the result.
                                            ![Results of ENV["TEMP"] in Ruby Console](/uploads/imported_attachments/iUOu_Picture2.png "Results of ENV["TEMP"] in Ruby Console")
                                            Thanks Supercylon
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 112
                                            • 113
                                            • 18 / 113
