    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
      supercylon
      I'm running SketchUp 7 on Mac OS 10.4.11. I've downloaded and installed both LibFredo6 v4.3 and Round Corner plugin and both are not working. When I start up SU7 I get the error message: "Error Loading File LibFredo6.rb
      can't convert nil into String". I have no idea what this means. Can someone help?
      Thanks a million!
      Here is a screen shot of my plugins folder
      My plugins folder
      • fredo6F Offline
        @supercylon
        Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
          I use
          tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
          πŸ˜•
            This is what I use to detect temp path:
            TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
            • fredo6F Offline
              @tig said:
              I use
              πŸ˜•
              TIG,
              Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
              @supercylon
              Can you type ENV["TMPDIR"] in the Ruby console
              Fred
                supercylon
                @supercylon
                Hello Fredo,
                Thanks for your assistance. I did what you asked and here is a screenshot of the result.
                ![Results of ENV["TEMP"] in Ruby Console](/uploads/imported_attachments/iUOu_Picture2.png "Results of ENV["TEMP"] in Ruby Console")
                Thanks Supercylon
                  supercylon
                  @tig said:
                  I use
                  πŸ˜•
                  TIG,
                  @supercylon
                  Fred
                  I didn't notice this message, here is the screen shot of the result of your second request.
                  Thanks,
                  Supercylon
                    And ENV['TMP'] ?
                      supercylon
                      @supercylon
                      Can you try withe attached file to see if your error disappear and SU starts OK.
                      [attachment=0:2f69w8lx]<!-- ia0 -->LibFredo6.rb<!-- ia0 -->[/attachment:2f69w8lx]
                      Fredo,
                      Thank you!Thank you! It works!
                      Supercylon
                      • fredo6F Offline
                        Supercylon
                        I will release the change tomorrow as v4.3c
                        It is strange however that on your Mac, the TMPDIR Environment variable is not defined.
                        @TIG, Thomthom: I just use /tmp when TMPDIR is not defined.
                        • fredo6F Offline
                          @supercylon
                          EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
                            baranya
                            Under Ubuntu makes SU to crach on startup
                            • fredo6F Offline
                              It's difficult for me to diagnose on this platform which I don't have.
                              I think there are a few users running Sketchup on Linux flavors, and they may help you to troubleshoot.
                              • Y Offline
                                yogaseeker
                                I ran into some trouble when I placed this plugin in the SU plugin folder. I thought this solution might help others.
                                "LibFredo6 4.3c - 31 Jan 12" is the name of the folder that I unzipped and I placed in my plugins folder. But that didn't work. You have to drag the contents of the "LibFredo6 4.3c - 31 Jan 12" folder (LIBFREDO6_Dir_43 and LibFredo6) out of that folder and put it in the plugins folder.
                                THanks so much for this wonderful plugin!!!
                                  mingjae
                                  Hello Mr.LibFredo..
                                  I have a diifficulty to install curviloft using libfredo in my SU8,
                                  it wont load and something wrong with the fredo, this is the picture :
                                  http://img594.imageshack.us/img594/7065/99471562.jpg
                                  I dont have lib tranductor.rb in Libfredo6 package neither on curviloft,
                                  how to solve this Mr?
                                  I also trying to copy the lib_tranductor.rb in my SU7 to SU8 plugins folder but it always crash after copying it... 😒
                                  • fredo6F Offline
                                    I would suggest you redo a clean installation and make sure you overwrite all existing files.
                                    Just in case, can you type in the Ruby Console and report what you get:
                                    Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                                      mingjae
                                      Hi, thank for your reply
                                      my SU8 in plugin folder have not installed by LibFredo and curviloft before,
                                      so I just put all unzipped libfredo and curviloft in my plugins folder,
                                      after I redo to overwrite it, it result the same, it not load "lib traductor.rb
                                      and here is I copy paste after I enter it on ruby console:
                                      "Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                                      C:/Program Files/Google/Plugins/LibTraductor.rb"
                                      edit: perhaps the lib traductor.rb crashes in the Google/Plugins folder?
                                      I copy the "Plugins" folder from my friend notebooks and place it there.
                                      I cut the lib traductor there and place it in SU8 plugins folder and the curviloft success to load...
                                      but, where can I get "lib traductor.rb", there's no in lib fredo zip and curviloft zipped file installer right?
                                      • fredo6F Offline
                                        Actually you do not need LibTraductor.rb for Curviloft (it's only for backward compatibility that it is checked).
                                          mingjae
                                          really?? 😳
                                          lol..i'm sorry, but thanks my SU8 now loading without any error notification..
                                          • fredo6F Offline
                                            By the way, you seem to have a non-standard installation of SU8.
                                            Normally, Sketchup folders are located in C:/Program Files/Google/**Google SketchUp 8**.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 111
                                            • 112
                                            • 18 / 112
