    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • T
      tspco
      Well it was there, not now now it just shows 4.3
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • gullfoG
        gullfo
        not sure if it is the LibFredo 4.3b or the BezierSpline 1.4f plugin, but if the LibFredo 4.3b is enabled, the BezierSpline 1.4f does not work. i get a Ruby console error for line 592 cannot convert nil to float.
        Error: #<TypeError: no implicit conversion to float from nil>
        C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in -' C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in onMouseMove'
        Fredo tools works regardless of BezierSplines being enabled or not.
        NOTE: I only encountered this error since updating to 4.3b and prior to that it was working correctly.
        Glenn
        http://www.runnel.com
        • W
          wt00320371
          I can't download?
            @wt00320371 said:
            I can't download?
            What file?
            What problem/error messages?
            More information, please...
            πŸ˜•
              supercylon
              I think that I've installed LibFredo6 v.4.3 and the Round corner plugins correctly. But when I launch SketchUp (I'm using Version 7 on Mac OS 10.4.11) is get this error message: Error Loading File LibFredo6.rb
              can't convert nil into String
              What does this mean and how can I fix it? Can someone assist me.
                supercylon
                I'm running SketchUp 7 on Mac OS 10.4.11. I've downloaded and installed both LibFredo6 v4.3 and Round Corner plugin and both are not working. When I start up SU7 I get the error message: "Error Loading File LibFredo6.rb
                can't convert nil into String". I have no idea what this means. Can someone help?
                Thanks a million!
                Here is a screen shot of my plugins folder
                My plugins folder
                • fredo6F
                  @supercylon
                  Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
                    I use
                    tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
                    πŸ˜•
                      This is what I use to detect temp path:
                      TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
                      • fredo6F
                        @tig said:
                        I use
                        πŸ˜•
                        TIG,
                        Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
                        @supercylon
                        Can you type ENV["TMPDIR"] in the Ruby console
                        Fred
                          supercylon
                          @supercylon
                          Hello Fredo,
                          Thanks for your assistance. I did what you asked and here is a screenshot of the result.
                          ![Results of ENV["TEMP"] in Ruby Console](/uploads/imported_attachments/iUOu_Picture2.png "Results of ENV["TEMP"] in Ruby Console")
                          Thanks Supercylon
                            supercylon
                            @tig said:
                            I use
                            πŸ˜•
                            TIG,
                            @supercylon
                            Fred
                            I didn't notice this message, here is the screen shot of the result of your second request.
                            Thanks,
                            Supercylon
                              And ENV['TMP'] ?
                                supercylon
                                @supercylon
                                Can you try withe attached file to see if your error disappear and SU starts OK.
                                [attachment=0:2f69w8lx]<!-- ia0 -->LibFredo6.rb<!-- ia0 -->[/attachment:2f69w8lx]
                                Fredo,
                                Thank you!Thank you! It works!
                                Supercylon
                                • fredo6F
                                  Supercylon
                                  I will release the change tomorrow as v4.3c
                                  It is strange however that on your Mac, the TMPDIR Environment variable is not defined.
                                  @TIG, Thomthom: I just use /tmp when TMPDIR is not defined.
                                  • fredo6F
                                    @supercylon
                                    EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
                                    • B
                                      baranya
                                      Under Ubuntu makes SU to crach on startup
                                      • fredo6F
                                        It's difficult for me to diagnose on this platform which I don't have.
                                        I think there are a few users running Sketchup on Linux flavors, and they may help you to troubleshoot.
                                        • Y
                                          yogaseeker
                                          I ran into some trouble when I placed this plugin in the SU plugin folder. I thought this solution might help others.
                                          "LibFredo6 4.3c - 31 Jan 12" is the name of the folder that I unzipped and I placed in my plugins folder. But that didn't work. You have to drag the contents of the "LibFredo6 4.3c - 31 Jan 12" folder (LIBFREDO6_Dir_43 and LibFredo6) out of that folder and put it in the plugins folder.
                                          THanks so much for this wonderful plugin!!!
                                            mingjae
                                            Hello Mr.LibFredo..
                                            I have a diifficulty to install curviloft using libfredo in my SU8,
                                            it wont load and something wrong with the fredo, this is the picture :
                                            http://img594.imageshack.us/img594/7065/99471562.jpg
                                            I dont have lib tranductor.rb in Libfredo6 package neither on curviloft,
                                            how to solve this Mr?
                                            I also trying to copy the lib_tranductor.rb in my SU7 to SU8 plugins folder but it always crash after copying it... 😒
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 115
                                            • 116
                                            • 18 / 116
