    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 86.3k Views 43 Watching
      @irwanwr said:
      @tak2hata said:
      The face and solid must be in same Group or Component or Model.
      It is rule of this plugin.
      Thanks.
      thank you in advance for this plugin.
      i still didn't get it though.
      say, if i have a window as component and a wall as a group, i can't make a hole on the wall with the shape of the window component?
      This tool is a general hole punching tool using 'solids' to make holes in forms. If you want a window or door component to punch a hole in wall that has two faces, I suggest that you use a normal 'cutting-component' which will glue onto the front face and cut a hole, then use my context-menu tool 'Hole Punching Tool...' to punch the wall with a matching hole - this also has the advantage that the 'hole' is linked to the component and moves/copies with it etc...
      • irwanwrI Offline
        irwanwr
        where can i find that context-menu tool, sir?
        [edit] never mind, sir. i already found your Hole Punching Tool. thank you very much. ๐Ÿ˜„
        • guanjinG Offline
          guanjin
          Great, thank you such a good tool
            durrroy
            I could never get it to work
              Are you asking for help or just making a statement?
              Since the plugin does work for others, it probably has to do with the way you've installed it. You could post a screen shot of your Plugins folder so someone could help you.
                Or they way he's using it. Not possible to know until we have further information to what exactly doesn't work.
                • irwanwrI Offline
                  irwanwr
                  it works for me
                    tak2hata
                    I update this to v1.62.
                    Add new function: Multiple hole punching.
                    Enjoy!
                    Hi,durrroy.
                    And ComponentInstance for hole must have hole option.
                    If this is not solution for your trouble,Please show ruby console from 'menu' -> 'Window' -> 'Ruby console'
                    And work some with this plugin,the error message will show when error is happened.
                    or Download the example.skp that Dave R uploaded in this topics.and test it.
                    Please reply the result.
                    Thanks.
                    by TAK2HATA
                      cocotier
                      it doesn't work
                        @cocotier said:
                        it doesn't work
                        Sorry but your post goes into the 'most useless' category !
                        Please explain 'how' it doesn't work...
                        Any Error messages ?
                        Doesn't it do what you expect ?
                        If you have the Ruby Console open are there any messages etc etc...
                        Does your PC explode... or what ?
                        Help us to help you ๐Ÿ˜’
                        • simon le bonS Offline
                          simon le bon
                          Update in Jan 03,2012
                          :Add new function,Punching multiple holes.
                          It would be very interesting to drill holes by lot in case of large number of windows for exemple...
                          this new enhancement is working very fine ๐Ÿ‘
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/HoleonSolidtool_tak2hata_010.jpg
                          Congratulations dear tak2hata ๐Ÿ‘ ๐Ÿ‘ You've mastered herein a pretty good tool โ˜€
                          @cocotier
                          Please remember that
                          This tool is intended to make holes on "solids" -> closed volumes set as group or component. This is not completely true since the following enhancement:
                          Update in Dec 14 ,2011:
                          Hole on unoccluded faces group(Tentative)
                          The group or component walls we want to pierce don't have to be solid anymore ๐Ÿ‘
                          simon
                          • irwanwrI Offline
                            irwanwr
                            ๐Ÿ‘ the new feature works well for me too. thank you.
                              boilingsnow
                              Hi,tak2hata.
                              Your Multi Hole Tool is very interesting and useful. But with Multi Hole I can only make holes into a solid using faces as definition of the form for the holes, with a component or group it fails to make holes into any solid...I can see in your video that you are using a group or component. Can you tell me how you can make it?
                                jorge2011
                                excellent and thank you very much.
                                Two requests for future versions.
                                You can add a function: projecting faces in a solid?
                                You can add a function to hole or project a face, in multiple solid?
                                  tak2hata
                                  Hi,I did not change title of topic in Jan 03,2012.I modeified title.
                                  Hi,boilingsnow.
                                  hole of component
                                  The componet for hole must have cut openning option.
                                  Reference about component here. http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114526
                                  Hi,jorge2011.
                                  I will consider your Proposal.
                                  Thanks.
                                  by TAK2HATA
                                  • guanjinG Offline
                                    guanjin
                                    Creating the Component Selection cutting openings, holes can not be achieved? ? ?
                                      tak2hata
                                      [attachment=1:1jixhd7j]<!-- ia1 -->rrrrrrrr.gif<!-- ia1 -->[/attachment:1jixhd7j]
                                      Hi,XIAOLONG.
                                      Outline for cut openning must be drawn on X-Y Plane( Red and Green axis).
                                      When the component is already existed,You rotate axis in that component.
                                      And outline must be placed in the root of that component.
                                      [attachment=0:1jixhd7j]<!-- ia0 -->outline_must_be_on_xyplane.jpg<!-- ia0 -->[/attachment:1jixhd7j]
                                      Watch for reference to create cut openning option.
                                      http://youtu.be/0g6irIj---w
                                      [flash=640,480:1jixhd7j]http://www.youtube.com/v/0g6irIj---w[/flash:1jixhd7j]
                                      Thanks.
                                      outline must be on xy-plane
                                      by TAK2HATA
                                      • guanjinG Offline
                                        guanjin
                                        @tak2hata said:
                                        [attachment=2:24c8pe63]<!-- ia2 -->rrrrrrrr.gif<!-- ia2 -->[/attachment:24c8pe63]
                                        Hi,XIAOLONG.
                                        [attachment=1:24c8pe63]<!-- ia1 -->outline_must_be_on_xyplane.jpg<!-- ia1 -->[/attachment:24c8pe63]
                                        Thanks.
                                        Thank you! Have learned to see demo:
                                        [attachment=0:24c8pe63]<!-- ia0 -->LLLLL.gif<!-- ia0 -->[/attachment:24c8pe63]
                                        ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                        • charly2008C Offline
                                          charly2008
                                          Hello tak2hata,
                                          Your tool is impressive. I've done some experiments with it. It works really well. One question I have is it possible a component that contains some single solids to cut completely into the wall.
                                          Charly
                                          example001-1.skp
                                            tak2hata
                                            Hi,everyone.
                                            I update in jan 09,2012.
                                            Its version is 1.63.
                                            Bug fix.The hole from polygon mades smoothed side faces. it's improved.
                                            I found from dave's post,and irwanwr's message.
                                            Thanks. Dave and irwanwr.
                                            Hi,Charly2008.
                                            That problem is not solved yet.
                                            I will improve it,when I find the solution in future.
                                            Thanks.
                                            by TAK2HATA
                                            • 5 / 7
