    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 105.2k Views 43 Watching
      @cocotier said:
      it doesn't work
      Sorry but your post goes into the 'most useless' category !
      Please explain 'how' it doesn't work...
      Any Error messages ?
      Doesn't it do what you expect ?
      If you have the Ruby Console open are there any messages etc etc...
      Does your PC explode... or what ?
      Help us to help you ๐Ÿ˜’
      • simon le bonS
        simon le bon
        Update in Jan 03,2012
        :Add new function,Punching multiple holes.
        It would be very interesting to drill holes by lot in case of large number of windows for exemple...
        this new enhancement is working very fine ๐Ÿ‘
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/HoleonSolidtool_tak2hata_010.jpg
        Congratulations dear tak2hata ๐Ÿ‘ ๐Ÿ‘ You've mastered herein a pretty good tool โ˜€
        @cocotier
        Please remember that
        This tool is intended to make holes on "solids" -> closed volumes set as group or component. This is not completely true since the following enhancement:
        Update in Dec 14 ,2011:
        Hole on unoccluded faces group(Tentative)
        The group or component walls we want to pierce don't have to be solid anymore ๐Ÿ‘
        simon
        • irwanwrI
          irwanwr
          ๐Ÿ‘ the new feature works well for me too. thank you.
          • B
            boilingsnow
            Hi,tak2hata.
            Your Multi Hole Tool is very interesting and useful. But with Multi Hole I can only make holes into a solid using faces as definition of the form for the holes, with a component or group it fails to make holes into any solid...I can see in your video that you are using a group or component. Can you tell me how you can make it?
              jorge2011
              excellent and thank you very much.
              Two requests for future versions.
              You can add a function: projecting faces in a solid?
              You can add a function to hole or project a face, in multiple solid?
              • T
                tak2hata
                Hi,I did not change title of topic in Jan 03,2012.I modeified title.
                Hi,boilingsnow.
                hole of component
                The componet for hole must have cut openning option.
                Reference about component here. http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114526
                Hi,jorge2011.
                I will consider your Proposal.
                Thanks.
                by TAK2HATA
                • guanjinG
                  guanjin
                  Creating the Component Selection cutting openings, holes can not be achieved? ? ?
                  • T
                    tak2hata
                    [attachment=1:1jixhd7j]<!-- ia1 -->rrrrrrrr.gif<!-- ia1 -->[/attachment:1jixhd7j]
                    Hi,XIAOLONG.
                    Outline for cut openning must be drawn on X-Y Plane( Red and Green axis).
                    When the component is already existed,You rotate axis in that component.
                    And outline must be placed in the root of that component.
                    [attachment=0:1jixhd7j]<!-- ia0 -->outline_must_be_on_xyplane.jpg<!-- ia0 -->[/attachment:1jixhd7j]
                    Watch for reference to create cut openning option.
                    http://youtu.be/0g6irIj---w
                    [flash=640,480:1jixhd7j]http://www.youtube.com/v/0g6irIj---w[/flash:1jixhd7j]
                    Thanks.
                    outline must be on xy-plane
                    by TAK2HATA
                    • guanjinG
                      guanjin
                      @tak2hata said:
                      [attachment=2:24c8pe63]<!-- ia2 -->rrrrrrrr.gif<!-- ia2 -->[/attachment:24c8pe63]
                      Hi,XIAOLONG.
                      [attachment=1:24c8pe63]<!-- ia1 -->outline_must_be_on_xyplane.jpg<!-- ia1 -->[/attachment:24c8pe63]
                      Thanks.
                      Thank you! Have learned to see demo:
                      [attachment=0:24c8pe63]<!-- ia0 -->LLLLL.gif<!-- ia0 -->[/attachment:24c8pe63]
                      ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                      • charly2008C
                        charly2008
                        Hello tak2hata,
                        Your tool is impressive. I've done some experiments with it. It works really well. One question I have is it possible a component that contains some single solids to cut completely into the wall.
                        Charly
                        example001-1.skp
                        • T
                          tak2hata
                          Hi,everyone.
                          I update in jan 09,2012.
                          Its version is 1.63.
                          Bug fix.The hole from polygon mades smoothed side faces. it's improved.
                          I found from dave's post,and irwanwr's message.
                          Thanks. Dave and irwanwr.
                          Hi,Charly2008.
                          That problem is not solved yet.
                          I will improve it,when I find the solution in future.
                          Thanks.
                          by TAK2HATA
                          • irwanwrI
                            irwanwr
                            hi tak2hata,
                            ๐Ÿ˜ thank you thank you very much for your generosity
                            • charly2008C
                              charly2008
                              @tak2hata said:
                              Hi,Charly2008.
                              Thanks.
                              thank you very much for your answer
                              Charly
                                jorge2011
                                Thank you. Excellency update.
                                Only a small error.
                                It does not work the command "Ctrl + Z". deleted one by one holes
                                • U
                                  urs0815
                                  Great plug in ๐Ÿ‘
                                  an option to set the depth of the hole would be great...
                                    jorge2011
                                    tak2hata
                                    See litle fix.you can fix that?
                                    Thank you very much
                                    01.skp
                                    • T
                                      tak2hata
                                      @jorge2011 said:
                                      tak2hata
                                      Thank you very much
                                      jorge2011.....
                                      I try your model.
                                      And I move the face for hole to very small distance.It succeed.
                                      The hidden line in the curved face is intersected with the hole on touch.
                                      I will inquire about it.
                                      Thanks.
                                      by TAK2HATA
                                      • C
                                        carlm
                                        Hi-
                                        I've installed the 1.6.3 plugin, but when I first re-opened SU the little Hole on Solid toolbox was "in my way" so I closed it -- now I can't figure out how to get it back. I can choose the plugin from the Plugin menu and it works to make single holes, but I've no menu access to the Multi-Hole variant of the tool, and no obvious way to re-open the toolbox...
                                        Any ideas?
                                        Thanks, -carl-
                                        (SU8 amateur, MacOS 10.5.8)
                                          Menu > View > Toolbars > the_Tool's_Name
                                          On a MAC it might be called something like 'Tool-Palettes' ?
                                          • C
                                            carlm
                                            Doh!
                                            View>Tool Palettes
                                            And there's your 2D tools palette as well.
                                            Thanks, -carl-
                                            • 5 / 7
