    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 98.9k Views 43 Watching
    • E Offline
      Enachi
      Tnx tak2hata , it is working fine now. My mistake was that I had both of the items, the wall and the circle made as components, not only the wall, in my case.
      • irwanwrI Offline
        irwanwr
        @tak2hata said:
        The face and solid must be in same Group or Component or Model.
        It is rule of this plugin.
        Thanks.
        thank you in advance for this plugin.
        i still didn't get it though.
        say, if i have a window as component and a wall as a group, i can't make a hole on the wall with the shape of the window component?
          Thanks.
          This tool is a general hole punching tool using 'solids' to make holes in forms. If you want a window or door component to punch a hole in wall that has two faces, I suggest that you use a normal 'cutting-component' which will glue onto the front face and cut a hole, then use my context-menu tool 'Hole Punching Tool...' to punch the wall with a matching hole - this also has the advantage that the 'hole' is linked to the component and moves/copies with it etc...
          • irwanwrI Offline
            irwanwr
            where can i find that context-menu tool, sir?
            [edit] never mind, sir. i already found your Hole Punching Tool. thank you very much. πŸ˜„
            • guanjinG Offline
              guanjin
              Great, thank you such a good tool
                durrroy
                I could never get it to work
                  Are you asking for help or just making a statement?
                  Since the plugin does work for others, it probably has to do with the way you've installed it. You could post a screen shot of your Plugins folder so someone could help you.
                    Or they way he's using it. Not possible to know until we have further information to what exactly doesn't work.
                    • irwanwrI Offline
                      irwanwr
                      it works for me
                        tak2hata
                        I update this to v1.62.
                        Add new function: Multiple hole punching.
                        Enjoy!
                        Hi,durrroy.
                        And ComponentInstance for hole must have hole option.
                        If this is not solution for your trouble,Please show ruby console from 'menu' -> 'Window' -> 'Ruby console'
                        And work some with this plugin,the error message will show when error is happened.
                        or Download the example.skp that Dave R uploaded in this topics.and test it.
                        Please reply the result.
                        Thanks.
                        by TAK2HATA
                          cocotier
                          it doesn't work
                            @cocotier said:
                            it doesn't work
                            Sorry but your post goes into the 'most useless' category !
                            Please explain 'how' it doesn't work...
                            Any Error messages ?
                            Doesn't it do what you expect ?
                            If you have the Ruby Console open are there any messages etc etc...
                            Does your PC explode... or what ?
                            Help us to help you πŸ˜’
                            • simon le bonS Offline
                              simon le bon
                              Update in Jan 03,2012
                              :Add new function,Punching multiple holes.
                              It would be very interesting to drill holes by lot in case of large number of windows for exemple...
                              this new enhancement is working very fine πŸ‘
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/HoleonSolidtool_tak2hata_010.jpg
                              Congratulations dear tak2hata πŸ‘ πŸ‘ You've mastered herein a pretty good tool β˜€
                              @cocotier
                              Please remember that
                              This tool is intended to make holes on "solids" -> closed volumes set as group or component. This is not completely true since the following enhancement:
                              Update in Dec 14 ,2011:
                              Hole on unoccluded faces group(Tentative)
                              The group or component walls we want to pierce don't have to be solid anymore πŸ‘
                              simon
                              • irwanwrI Offline
                                irwanwr
                                πŸ‘ the new feature works well for me too. thank you.
                                  boilingsnow
                                  Hi,tak2hata.
                                  Your Multi Hole Tool is very interesting and useful. But with Multi Hole I can only make holes into a solid using faces as definition of the form for the holes, with a component or group it fails to make holes into any solid...I can see in your video that you are using a group or component. Can you tell me how you can make it?
                                    jorge2011
                                    excellent and thank you very much.
                                    Two requests for future versions.
                                    You can add a function: projecting faces in a solid?
                                    You can add a function to hole or project a face, in multiple solid?
                                      tak2hata
                                      Hi,I did not change title of topic in Jan 03,2012.I modeified title.
                                      Hi,boilingsnow.
                                      hole of component
                                      The componet for hole must have cut openning option.
                                      Reference about component here. http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114526
                                      Hi,jorge2011.
                                      I will consider your Proposal.
                                      Thanks.
                                      by TAK2HATA
                                      • guanjinG Offline
                                        guanjin
                                        Creating the Component Selection cutting openings, holes can not be achieved? ? ?
                                          tak2hata
                                          [attachment=1:1jixhd7j]<!-- ia1 -->rrrrrrrr.gif<!-- ia1 -->[/attachment:1jixhd7j]
                                          Hi,XIAOLONG.
                                          Outline for cut openning must be drawn on X-Y Plane( Red and Green axis).
                                          When the component is already existed,You rotate axis in that component.
                                          And outline must be placed in the root of that component.
                                          [attachment=0:1jixhd7j]<!-- ia0 -->outline_must_be_on_xyplane.jpg<!-- ia0 -->[/attachment:1jixhd7j]
                                          Watch for reference to create cut openning option.
                                          http://youtu.be/0g6irIj---w
                                          [flash=640,480:1jixhd7j]http://www.youtube.com/v/0g6irIj---w[/flash:1jixhd7j]
                                          Thanks.
                                          outline must be on xy-plane
                                          by TAK2HATA
                                          • guanjinG Offline
                                            guanjin
                                            @tak2hata said:
                                            [attachment=2:24c8pe63]<!-- ia2 -->rrrrrrrr.gif<!-- ia2 -->[/attachment:24c8pe63]
                                            Hi,XIAOLONG.
                                            [attachment=1:24c8pe63]<!-- ia1 -->outline_must_be_on_xyplane.jpg<!-- ia1 -->[/attachment:24c8pe63]
                                            Thanks.
                                            Thank you! Have learned to see demo:
                                            [attachment=0:24c8pe63]<!-- ia0 -->LLLLL.gif<!-- ia0 -->[/attachment:24c8pe63]
                                            πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                            • 4 / 7
