    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 98.9k Views 43 Watching
      I opened the wall group and deleted the copy of the circle. Then I closed the group. I selected the tool, the wall and then the circle. Hole punched just fine. Do you have the most recent version of the plugin?
      example001.skp
      • E Offline
        Enachi
        For some reason this plugin is not working with my SU v8. I've installed latest version of bst and hos 1.6.1. Even so, when I activate the plugin, then the tool and then I go for the wall, this is simple selected in blue color (not orange as I've seen on tutorial) and doesn't let me to select the circle, that would make the hole.
        Any suggestion?
        Thank you.
          tak2hata
          Any suggestion?
          Thank you.
          Hi,enachi.
          The face and solid must be in same Group or Component or Model.
          It is rule of this plugin.
          If this is not solution for your trouble,Please show ruby console from 'menu' -> 'Window' -> 'Ruby console'
          And work some with this plugin,the error message will show when error is happened.
          or Download the example.skp that Dave R uploaded in this topics.and test it.
          Please reply the result.
          Thanks.
          by TAK2HATA
          • E Offline
            Enachi
            Tnx tak2hata , it is working fine now. My mistake was that I had both of the items, the wall and the circle made as components, not only the wall, in my case.
            • irwanwrI Offline
              irwanwr
              Thanks.
              thank you in advance for this plugin.
              i still didn't get it though.
              say, if i have a window as component and a wall as a group, i can't make a hole on the wall with the shape of the window component?
                Thanks.
                This tool is a general hole punching tool using 'solids' to make holes in forms. If you want a window or door component to punch a hole in wall that has two faces, I suggest that you use a normal 'cutting-component' which will glue onto the front face and cut a hole, then use my context-menu tool 'Hole Punching Tool...' to punch the wall with a matching hole - this also has the advantage that the 'hole' is linked to the component and moves/copies with it etc...
                • irwanwrI Offline
                  irwanwr
                  where can i find that context-menu tool, sir?
                  [edit] never mind, sir. i already found your Hole Punching Tool. thank you very much. πŸ˜„
                  • guanjinG Offline
                    guanjin
                    Great, thank you such a good tool
                      durrroy
                      I could never get it to work
                        Are you asking for help or just making a statement?
                        Since the plugin does work for others, it probably has to do with the way you've installed it. You could post a screen shot of your Plugins folder so someone could help you.
                          Or they way he's using it. Not possible to know until we have further information to what exactly doesn't work.
                          • irwanwrI Offline
                            irwanwr
                            it works for me
                              tak2hata
                              I update this to v1.62.
                              Add new function: Multiple hole punching.
                              Enjoy!
                              Hi,durrroy.
                              And ComponentInstance for hole must have hole option.
                              Thanks.
                              by TAK2HATA
                                cocotier
                                it doesn't work
                                  @cocotier said:
                                  it doesn't work
                                  Sorry but your post goes into the 'most useless' category !
                                  Please explain 'how' it doesn't work...
                                  Any Error messages ?
                                  Doesn't it do what you expect ?
                                  If you have the Ruby Console open are there any messages etc etc...
                                  Does your PC explode... or what ?
                                  Help us to help you πŸ˜’
                                  • simon le bonS Offline
                                    simon le bon
                                    Update in Jan 03,2012
                                    :Add new function,Punching multiple holes.
                                    It would be very interesting to drill holes by lot in case of large number of windows for exemple...
                                    this new enhancement is working very fine πŸ‘
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/HoleonSolidtool_tak2hata_010.jpg
                                    Congratulations dear tak2hata πŸ‘ πŸ‘ You've mastered herein a pretty good tool β˜€
                                    @cocotier
                                    Please remember that
                                    This tool is intended to make holes on "solids" -> closed volumes set as group or component. This is not completely true since the following enhancement:
                                    Update in Dec 14 ,2011:
                                    Hole on unoccluded faces group(Tentative)
                                    The group or component walls we want to pierce don't have to be solid anymore πŸ‘
                                    simon
                                    • irwanwrI Offline
                                      irwanwr
                                      πŸ‘ the new feature works well for me too. thank you.
                                        boilingsnow
                                        Hi,tak2hata.
                                        Your Multi Hole Tool is very interesting and useful. But with Multi Hole I can only make holes into a solid using faces as definition of the form for the holes, with a component or group it fails to make holes into any solid...I can see in your video that you are using a group or component. Can you tell me how you can make it?
                                          jorge2011
                                          excellent and thank you very much.
                                          Two requests for future versions.
                                          You can add a function: projecting faces in a solid?
                                          You can add a function to hole or project a face, in multiple solid?
                                            tak2hata
                                            Hi,I did not change title of topic in Jan 03,2012.I modeified title.
                                            Hi,boilingsnow.
                                            hole of component
                                            The componet for hole must have cut openning option.
                                            Reference about component here. http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114526
                                            Hi,jorge2011.
                                            I will consider your Proposal.
                                            Thanks.
                                            by TAK2HATA
                                            • 4 / 7
