    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 93.1k Views 43 Watching
      @durrroy said:
      I could never get it to work
      Are you asking for help or just making a statement?
      Since the plugin does work for others, it probably has to do with the way you've installed it. You could post a screen shot of your Plugins folder so someone could help you.
        Or they way he's using it. Not possible to know until we have further information to what exactly doesn't work.
        • irwanwrI Offline
          irwanwr
          it works for me
            tak2hata
            I update this to v1.62.
            Add new function: Multiple hole punching.
            Enjoy!
            Hi,durrroy.
            The face and solid must be in same Group or Component or Model.
            And ComponentInstance for hole must have hole option.
            It is rule of this plugin.
            If this is not solution for your trouble,Please show ruby console from 'menu' -> 'Window' -> 'Ruby console'
            And work some with this plugin,the error message will show when error is happened.
            or Download the example.skp that Dave R uploaded in this topics.and test it.
            Please reply the result.
            Thanks.
            by TAK2HATA
              cocotier
              it doesn't work
              • TIGT Online
                @cocotier said:
                it doesn't work
                Sorry but your post goes into the 'most useless' category !
                Please explain 'how' it doesn't work...
                Any Error messages ?
                Doesn't it do what you expect ?
                If you have the Ruby Console open are there any messages etc etc...
                Does your PC explode... or what ?
                Help us to help you ๐Ÿ˜’
                • simon le bonS Offline
                  simon le bon
                  Update in Jan 03,2012
                  :Add new function,Punching multiple holes.
                  It would be very interesting to drill holes by lot in case of large number of windows for exemple...
                  this new enhancement is working very fine ๐Ÿ‘
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/HoleonSolidtool_tak2hata_010.jpg
                  Congratulations dear tak2hata ๐Ÿ‘ ๐Ÿ‘ You've mastered herein a pretty good tool โ˜€
                  @cocotier
                  Please remember that
                  This tool is intended to make holes on "solids" -> closed volumes set as group or component. This is not completely true since the following enhancement:
                  Update in Dec 14 ,2011:
                  Hole on unoccluded faces group(Tentative)
                  The group or component walls we want to pierce don't have to be solid anymore ๐Ÿ‘
                  simon
                  • irwanwrI Offline
                    irwanwr
                    ๐Ÿ‘ the new feature works well for me too. thank you.
                      boilingsnow
                      Hi,tak2hata.
                      Your Multi Hole Tool is very interesting and useful. But with Multi Hole I can only make holes into a solid using faces as definition of the form for the holes, with a component or group it fails to make holes into any solid...I can see in your video that you are using a group or component. Can you tell me how you can make it?
                        jorge2011
                        excellent and thank you very much.
                        Two requests for future versions.
                        You can add a function: projecting faces in a solid?
                        You can add a function to hole or project a face, in multiple solid?
                          tak2hata
                          Hi,I did not change title of topic in Jan 03,2012.I modeified title.
                          Hi,boilingsnow.
                          hole of component
                          The componet for hole must have cut openning option.
                          Reference about component here. http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114526
                          Hi,jorge2011.
                          I will consider your Proposal.
                          Thanks.
                          by TAK2HATA
                          • guanjinG Offline
                            guanjin
                            Creating the Component Selection cutting openings, holes can not be achieved? ? ?
                              tak2hata
                              [attachment=1:1jixhd7j]<!-- ia1 -->rrrrrrrr.gif<!-- ia1 -->[/attachment:1jixhd7j]
                              Hi,XIAOLONG.
                              Outline for cut openning must be drawn on X-Y Plane( Red and Green axis).
                              When the component is already existed,You rotate axis in that component.
                              And outline must be placed in the root of that component.
                              [attachment=0:1jixhd7j]<!-- ia0 -->outline_must_be_on_xyplane.jpg<!-- ia0 -->[/attachment:1jixhd7j]
                              Watch for reference to create cut openning option.
                              http://youtu.be/0g6irIj---w
                              [flash=640,480:1jixhd7j]http://www.youtube.com/v/0g6irIj---w[/flash:1jixhd7j]
                              Thanks.
                              outline must be on xy-plane
                              by TAK2HATA
                              • guanjinG Offline
                                guanjin
                                @tak2hata said:
                                [attachment=2:24c8pe63]<!-- ia2 -->rrrrrrrr.gif<!-- ia2 -->[/attachment:24c8pe63]
                                Hi,XIAOLONG.
                                [attachment=1:24c8pe63]<!-- ia1 -->outline_must_be_on_xyplane.jpg<!-- ia1 -->[/attachment:24c8pe63]
                                Thanks.
                                Thank you! Have learned to see demo:
                                [attachment=0:24c8pe63]<!-- ia0 -->LLLLL.gif<!-- ia0 -->[/attachment:24c8pe63]
                                ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                • charly2008C Offline
                                  charly2008
                                  Hello tak2hata,
                                  Your tool is impressive. I've done some experiments with it. It works really well. One question I have is it possible a component that contains some single solids to cut completely into the wall.
                                  Charly
                                  example001-1.skp
                                    tak2hata
                                    Hi,everyone.
                                    I update in jan 09,2012.
                                    Its version is 1.63.
                                    Bug fix.The hole from polygon mades smoothed side faces. it's improved.
                                    I found from dave's post,and irwanwr's message.
                                    Thanks. Dave and irwanwr.
                                    Hi,Charly2008.
                                    That problem is not solved yet.
                                    I will improve it,when I find the solution in future.
                                    Thanks.
                                    by TAK2HATA
                                    • irwanwrI Offline
                                      irwanwr
                                      hi tak2hata,
                                      ๐Ÿ˜ thank you thank you very much for your generosity
                                        charly2008
                                        @tak2hata said:
                                        Hi,Charly2008.
                                        Thanks.
                                        thank you very much for your answer
                                        Charly
                                          jorge2011
                                          Thank you. Excellency update.
                                          Only a small error.
                                          It does not work the command "Ctrl + Z". deleted one by one holes
                                          • U Offline
                                            urs0815
                                            Great plug in ๐Ÿ‘
                                            an option to set the depth of the hole would be great...
                                            • 4 / 7
