    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 94.6k Views 43 Watching
    • simon le bonS Offline
      simon le bon
      Update in Jan 03,2012
      :Add new function,Punching multiple holes.
      It would be very interesting to drill holes by lot in case of large number of windows for exemple...
      this new enhancement is working very fine ๐Ÿ‘
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/HoleonSolidtool_tak2hata_010.jpg
      Congratulations dear tak2hata ๐Ÿ‘ ๐Ÿ‘ You've mastered herein a pretty good tool โ˜€
      @cocotier
      Please remember that
      This tool is intended to make holes on "solids" -> closed volumes set as group or component. This is not completely true since the following enhancement:
      Update in Dec 14 ,2011:
      Hole on unoccluded faces group(Tentative)
      The group or component walls we want to pierce don't have to be solid anymore ๐Ÿ‘
      simon
      • irwanwrI Offline
        irwanwr
        ๐Ÿ‘ the new feature works well for me too. thank you.
          boilingsnow
          Hi,tak2hata.
          Your Multi Hole Tool is very interesting and useful. But with Multi Hole I can only make holes into a solid using faces as definition of the form for the holes, with a component or group it fails to make holes into any solid...I can see in your video that you are using a group or component. Can you tell me how you can make it?
            jorge2011
            excellent and thank you very much.
            Two requests for future versions.
            You can add a function: projecting faces in a solid?
            You can add a function to hole or project a face, in multiple solid?
              tak2hata
              Hi,I did not change title of topic in Jan 03,2012.I modeified title.
              Hi,boilingsnow.
              hole of component
              The componet for hole must have cut openning option.
              Reference about component here. http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114526
              Hi,jorge2011.
              I will consider your Proposal.
              Thanks.
              by TAK2HATA
              • guanjinG Offline
                guanjin
                Creating the Component Selection cutting openings, holes can not be achieved? ? ?
                  tak2hata
                  [attachment=1:1jixhd7j]<!-- ia1 -->rrrrrrrr.gif<!-- ia1 -->[/attachment:1jixhd7j]
                  Hi,XIAOLONG.
                  Outline for cut openning must be drawn on X-Y Plane( Red and Green axis).
                  When the component is already existed,You rotate axis in that component.
                  And outline must be placed in the root of that component.
                  [attachment=0:1jixhd7j]<!-- ia0 -->outline_must_be_on_xyplane.jpg<!-- ia0 -->[/attachment:1jixhd7j]
                  Watch for reference to create cut openning option.
                  http://youtu.be/0g6irIj---w
                  [flash=640,480:1jixhd7j]http://www.youtube.com/v/0g6irIj---w[/flash:1jixhd7j]
                  Thanks.
                  outline must be on xy-plane
                  by TAK2HATA
                  • guanjinG Offline
                    guanjin
                    @tak2hata said:
                    [attachment=2:24c8pe63]<!-- ia2 -->rrrrrrrr.gif<!-- ia2 -->[/attachment:24c8pe63]
                    Hi,XIAOLONG.
                    [attachment=1:24c8pe63]<!-- ia1 -->outline_must_be_on_xyplane.jpg<!-- ia1 -->[/attachment:24c8pe63]
                    Thanks.
                    Thank you! Have learned to see demo:
                    [attachment=0:24c8pe63]<!-- ia0 -->LLLLL.gif<!-- ia0 -->[/attachment:24c8pe63]
                    ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    • charly2008C Offline
                      charly2008
                      Hello tak2hata,
                      Your tool is impressive. I've done some experiments with it. It works really well. One question I have is it possible a component that contains some single solids to cut completely into the wall.
                      Charly
                      example001-1.skp
                        tak2hata
                        Hi,everyone.
                        I update in jan 09,2012.
                        Its version is 1.63.
                        Bug fix.The hole from polygon mades smoothed side faces. it's improved.
                        I found from dave's post,and irwanwr's message.
                        Thanks. Dave and irwanwr.
                        Hi,Charly2008.
                        That problem is not solved yet.
                        I will improve it,when I find the solution in future.
                        Thanks.
                        by TAK2HATA
                        • irwanwrI Offline
                          irwanwr
                          hi tak2hata,
                          ๐Ÿ˜ thank you thank you very much for your generosity
                            charly2008
                            @tak2hata said:
                            Hi,Charly2008.
                            Thanks.
                            thank you very much for your answer
                            Charly
                              jorge2011
                              Thank you. Excellency update.
                              Only a small error.
                              It does not work the command "Ctrl + Z". deleted one by one holes
                              • U Offline
                                urs0815
                                Great plug in ๐Ÿ‘
                                an option to set the depth of the hole would be great...
                                  jorge2011
                                  tak2hata
                                  See litle fix.you can fix that?
                                  Thank you very much
                                  01.skp
                                    tak2hata
                                    @jorge2011 said:
                                    tak2hata
                                    Thank you very much
                                    jorge2011.....
                                    I try your model.
                                    And I move the face for hole to very small distance.It succeed.
                                    The hidden line in the curved face is intersected with the hole on touch.
                                    I will inquire about it.
                                    Thanks.
                                    by TAK2HATA
                                      carlm
                                      Hi-
                                      I've installed the 1.6.3 plugin, but when I first re-opened SU the little Hole on Solid toolbox was "in my way" so I closed it -- now I can't figure out how to get it back. I can choose the plugin from the Plugin menu and it works to make single holes, but I've no menu access to the Multi-Hole variant of the tool, and no obvious way to re-open the toolbox...
                                      Any ideas?
                                      Thanks, -carl-
                                      (SU8 amateur, MacOS 10.5.8)
                                        Menu > View > Toolbars > the_Tool's_Name
                                        On a MAC it might be called something like 'Tool-Palettes' ?
                                          carlm
                                          Doh!
                                          View>Tool Palettes
                                          And there's your 2D tools palette as well.
                                          Thanks, -carl-
                                            jgt1942
                                            @tak2hata said:
                                            The face and solid must be in same Group or Component or Model.
                                            And ComponentInstance for hole must have hole option.
                                            It is rule of this plugin.
                                            Sorry newbie question - It took me a few hours (OK I'm really slow) to realize that the face could NOT be part of the solid. I'm having a couple of problems (1) creating the face - every-time I attempt to create the face it becomes part of the solid (2) I copied in a test object for the face but I cannot get it accurately positioned. Example I'm drawing a woodworking object and I need to have the hold precisely positioned and sized.
                                            I've got to study a bit more to fully understand your statement in the above quote. If you have a reference video to explain what you have in the quote, for me that would be super helpful.
                                            The concept is super and in the example file I downloaded it works GREAT! I'm using SU 8.
                                            jgt
                                            • 5 / 7
