    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.2m Views 150 Watching
      Yea - I use to tweak it myself. But for each update I need to do it all over again.
      • P
        paihwai
        Oh!!!
        • gtalaricoG
          gtalarico
          I keep getting an error when trying to extrude a few curved letters...
          "General Error: cannot complete the transformation"
          Can someone give it try it a try and see if maybe it is something on my end?
          Steps to reproduce:
          1. Open groud
          2. Select All.
            3.Click on JPP (J)
            [ Erase Original, border on all, make group, 30 deg]
            4.Click on edge, pull, type 2", Enter
          Error.
          letters.skp
          -Gui
          http://www.gtalarico.com
            driven
            try booleenhelper.rb or scale X 1000 enter 2000" and it works here
              Interesting. I could do one letter at a time at the current size. I selected about half of them and tried it and got a Bug Splat. 😞
              I tried doing limited groups of letters. The center row went fine as did the first two thirds of the top row. When I tried to do the last batch of letters in the top row, Splat!
                I got splats on the 'r 'in 'marian' and 'heart'.
                  At original size it Bugsplats big time! [probably a 'tiny facets issue' on the small curved edges in the R - but why not the P or & ?]
                  But Scale x100 and then JPP 200" [on the whole thing at once], then Scale back down x0.01m to get this good/swift outcome Capture.PNG
                  • gtalaricoG
                    gtalarico
                    Scaling helped. Thanks! 😉
                    Never thought it make a difference... is because SU doesn't like expressions with number like 0.00000000000000000000000000000000002003 ? 😒
                    -Gui
                    • ayan13A
                      ayan13
                      great plugins ! I use it a lot! Thank you !!!
                      • H
                        helios
                        My apologies if this was answered before, but is it possible to use this plugin to uniformly add thickness to a cylinder-like object? I created it by pulling a circle (and then scaling it at several points) and now would like to add some thickness to the currently hollow object, as it is going to be 3D printed. I am, in essence, trying to pull all the outside surfaces at a perpendicular angles.
                        Many thanks!
                        • jgbJ
                          jgb
                          Yes. Use the Joint Push/Pull (not the Vector). Select the surface of the cylinder and using the JPP tool, click on any face in the selection. It will outline in red. Pull it up as thick as you want, or more accurately, pull up a short distance and type the thickness to the Measurements box. Press <Enter> to get a preview, then <enter> again to complete the thickening.
                          Depending on the defaults you have for JPP, it may or may not form a group of the thickened section.
                          You can explode the group if you want.
                          jgb
                          • jgbJ
                            jgb
                            I just got that "transformation" error as well. 😮
                            While the attached SKP is documented, here's what happened.
                            There are 2 errors depicted in the attached model.
                            1 - I tried to thicken (using JPP preset at 90 deg) the housing by .1 inch. Error.
                            I read this thread and scaled up 10X, same result.
                            If I do the hub and flanges separately, it works, but there is a mess to clean up.
                            2 - When I thicken any pair (or more) faces that are at an angle to each other, and any face has a hole in it, the hole thickens at some median angle, not perpendicular to its face. The circle on the thickened face is also distorted into an oval/ellipse.
                            There is one other transformation error I've noticed as well, but seems to happen in specific repeatable cases where the transformation logic is simply stumped for a good solution.
                            Ya kant code for every case.... bin-der dundat. 😆 (Well respected Indian explorer)
                            I'll post a separate model of that problem if wanted.
                            So now in those cases I know where to look and do a quick and simple fix.
                            Believe me, JPP is a Golden Ruby I cannot live without.
                            Apologies... First post I forgot the SKP file. 😳
                            As above.
                            jgb
                            • mitcorbM
                              mitcorb
                              @helios: Not to disparage such a fine tool as Joint Push/Pull, but a possible alternative is Pipe Along Path. Slightly different methodology, but similar result.
                              • jgbJ
                                jgb
                                Yes, but PAP is not a tool for this problem. I use PAP a lot and its main advantage is making a tube or pipe along an arbitrary path.
                                There are a few other solutions available to thicken the surface of a cylinder, or any shape, either in a straight line or a path. Follow-me is a so-so useful tool for a non-linear path. Making a circle with both inner and outer diameters then extruding the outer ring is probably best, but linear paths only.
                                However, JPP is the only tool I know of that will equally thicken all surfaces, linear or not, and even bent/wavy surfaces, which was the case indicated by @helios. Think of an hour-glass. ❗
                                jgb
                                • H
                                  helios
                                  Thank you for the quick replies! It looks like this plugin is what I am after.
                                    ar_max
                                    Thank you very much.
                                    Used to feel very good.
                                    Sorry.
                                    Not good at English. 😄
                                    • dereiD
                                      derei
                                      Is it JPP polygon-limited ?
                                      I have a curved face and I wanted to add thickness to it. Unfortunately, JPP only affected a part of entire mesh.
                                      See below.
                                      DESIGNER AND ARTIST DEREI.UK
                                      • mitcorbM
                                        mitcorb
                                        Could it be that the faces were pulled internally because of the direction of your pull and the inference engine trying to snap to a vertex? I don't know, just asking.
                                        • dereiD
                                          derei
                                          I'm not sure what you are asking...but if is what I think it is, it should be valid only for small distances and only for mouse movement. Or, I moved the mouse to avoid snapping and I input a value in VCB.
                                          • fredo6F
                                            See below.
                                            JPP has a limit for displaying the feedback wireframe (5000 faces) but I don'th think I put one for the processing.
                                            I'll check that and come back.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 18
                                            • 19
                                            • 13 / 19
