    [Plugin] Drop Vertices
    54 Posts 18 Posters 153.9k Views 18 Watching
      I have checked and there is 'a rabbit away' !
      Watch out for fixed code soon 😒
        Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
        It fixes a last minute typo in my code that affected Lowest/Highest/Middle results - it should now work as advertised - feedback please...dvs.PNG
        • W Offline
          wyatt
          The high/low/middle work correctly now. Thank you for this script.
            MartinK
            That seems to have done the trick. Many thanks. 👍
            • simon le bonS Offline
              simon le bon
              Thank you so much Dear TIG for this brand new tool.
              ("to middle" and "to average" options don't work for me with su6_free and su7_pro)
              Coming back to the thread which had (re)initiated the need for such a tool: What's the best way to flatten some geometry lines
              I'm trying the old problem (not solved by SandboxTools/stamp)to achieve to drop vertices of a 3d path onto a 3d terrain. (I would like start with a path "melted up an down", "included" with/into the terrain)
              I have made my road/path triangulated (with Sandboxtools/from contour)
              Tip: I use [Plugin] Select Outer Edges v1.0 by Chris Fullmer to select outer edges 😒
              But Whatever the option I choose with Drop Vertices I got aberrant result 😕
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_001.jpg
              to nearest object , to nearest below..
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_002.jpg
              Any Idea ??
              (Alternatively, I have tried "Drape CPoints" + "Triangulate Points" and also "Artisan"€ and this one gives the better results for me from now, using "Crease Selection" Edges+vertices on the total path face .
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_003.jpg
              Cheers
              simon.
              Re: thank you dear Tig for your [Plugin] Work Plane v2.3 by TIG on Sat Sep 25, 2010 I'm using for long >>referencing to "this"
                Simon
                  simon le bon
                  Bonjour TIG 😄
                  OK, I was confused on the concepts Drape/Drope.
                  I have discovered that the kind of subdivision is important. Until now I was trying to drape with some classical triangulated shapes and that's why the result wasn't working.
                  As I have seen with your example above it was possible, I have discovered that shapes must be subdivided by real tin subdivision.(as far)
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_005.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_006.jpg
                  (I see we can't obtain this way something like we can do with sandboxtool/Stamptool but with a 3D path.)
                  Anyway This DropVertices brings so much !!!!+++ Thank you one more time and bravo!! TIG
                  simon.
                  • EarthMoverE Offline
                    EarthMover
                    Here is another method to do what you are looking for Simon.
                    [flash=800,600:1yx2pldf]http://www.youtube.com/v/hzN5n2UB7Ao[/flash:1yx2pldf]
                    Content Creator at Skapeup
                      simon le bon
                      Dear Adam,
                      your videos are invaluable to understand easily how things work and as reminders.
                      I have watched your previous a number of times.
                      I'm studying your propositions (soapskin&buble _ instant road (which makes the deal 👍 👍 ) and I'm thinking to others. It's for tomorrow now.
                      Cheers,
                         simon.
                        Maybe use of Ferrari can also gives some cool results 😉
                          ktslambieng
                          oh .thank u verry much
                          but ruby SplitUp I can find where, who can help me, please
                          i saw on Youtube
                          http://www.youtu.be/watch?v=kAUx4AHVbOU&feature=related
                            i saw on Youtube
                            Like 'On Screen Rolling Reel' - 'SplitUp' has never been published.
                            It's in beta testing with a select group [Rich O'B].
                            The bugs are now ironed out... I'll speak with the other[s] to see what we should do next...
                              Don't forget my NURBS plugin that's fairly stable. Just too powerful for mere mortals.
                              • peter_shawP Offline
                                peter_shaw
                                great plugin, used it to fix a f-ed up model
                                • cottyC Offline
                                  cotty
                                  What did I wrong here?
                                  klick image
                                  my SketchUp gallery
                                    Scant on what you've tried...
                                    arcs/curves do not drop unless they are exploded first...
                                    but see this example...
                                      Here is v2.0 http://sketchucation.com/pluginstore?pln=dropverts It now overcomes the curve issue.
                                      All edges in a dropped curve are now treated as separate edges.
                                      • cottyC Offline
                                        cotty
                                        Thank you, nice update!
                                        my SketchUp gallery
                                          Does it possible to imagine a "drop" on X or Y direction ?
                                          (sure I can rotate all before but...)
                                          • mariochaM Offline
                                            mariocha
                                            Hi TIG,
                                            I found that To Middle and To average do not work.
                                            Console indicates that line 93 z=z.to_s.to_l if z is faulty; cannot convert to length.
                                            I changed it to z=z.to_f if z . (float) They now work.
                                            Is this right ?
                                            %(#008000)[Mario C.
                                            • 2 / 3
