    [Plugin] Drop Vertices
    54 Posts 18 Posters 155.1k Views 18 Watching
      Sorry, but it's not available. Maybe in the future?
        rv1974
        And practically, what one could model with this ruby?
        What's the aim?
        • Bob JamesB
          Bob James
          What's the aim?
          This:
          http://forums.sketchucation.com/viewtopic.php?f=15&t=39224
            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
            Several additional features added - please read first post...
            • EarthMoverE
              EarthMover
              TIG, would it be possible to add an option which is drop verts to =Z /to intersect. Meaning if you had the subdivided plane above, let's say a smaller box, then all verts would drop to the specified Z, except where they intersected with the box. Perhaps adding a "Drape Verts" choice to the submenu. It would essentially do what drape Cpoints and triangulate does, but with a predefined mesh.
              Thanks for your work on this again. The new features are great. πŸ‘
              Content Creator at Skapeup
                I'll look at adding 'To Nearest + Z = ?' too... It should be too difficult...
                  Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
                  'To Nearest+Z=?' option added for 'draping' whole mesh over objects.
                  • EarthMoverE
                    EarthMover
                    Wow, that was fast! I'll give it whirl and let you know how it works.
                    • EarthMoverE
                      EarthMover
                      A quick play. Works great! Thanks again. πŸ‘ This will be great for retopology of high poly terrain data or terrains made with From Contours!
                      [flash=800,600:3go1iq6p]http://www.youtube.com/v/cWgJeIonBhU[/flash:3go1iq6p]
                      • JClementsJ
                        JClements
                        Thanks, TIG! This should remedy some problem issues with the Smooth Tool in Sandbox where the boundary edges can't be anchored to their existing Z location.
                        1- Wondering about having functions similar to DropVert that would need to be in a different script called, MoveVertsTo.
                        After selecting edges, user would be asked to select a TARGET SURFACE and then choose "OK" to validate the target surface.
                        2- Perhaps additional mode (chekbox) for DropVerts and MoveVerts would be "SHOW ME" where the average, %, lowest, Highest, Z-value, etc., would temporarily be displayed (as plane) before the vertices are moved; the user could then: a) cancel the choice and choose another option or b) execute the move.
                        • EarthMoverE
                          EarthMover
                          Additionally I wonder if it would be possible to implement a Vert Memory option, where you could select all border edges and choose "Remember Vertex Positions", then once you are finished sculpting a terrain, you could "Restore Vertex Positions". This would essentially allow a user to freeze all border edges from being affected by manipulation. This way, if I had, say a flower bed on a hillside that I wanted to add undulation to, I could store the perimeter verts to memory, sculpt to my leisure, then restore the border perfectly. 😎 Just a thought.
                          • bac9-flclB
                            bac9-flcl
                            I am sorry to interrupt the thread, but as you seem to very experienced in working with SketchUp model vertex structure, I've wanted to ask a simple question: is it possible to write a small plugin that can display the total vertex count of a model? It is a very important parameter to keep an eye on, for example, if developing Google Earth targeted model, but it's nowhere to be found in standart SketchUp stats. 😞
                              This will do it
                              v=[];t=0;m=Sketchup.active_model;m.entities.each{|e|v<<e.vertices if e.class==Sketchup;;Edge};v.flatten!;v.uniq!;p t=v.length;tt=0;m.definitions.each{|d|v=[];d.entities.each{|e|v<<e.vertices if e.class==Sketchup;;Edge};v.flatten!;v.uniq!;tt=tt+(v.length*d.instances.length)};p tt;p gt=t+tt;puts
                              Copy+Paste this one-liner into the Ruby Console + <Enter> it prints the total of all unique vertices in the model AND then those vertices inside groups/instance [multiplied by the number of instances of each] and then the grand total of the two.
                              • W
                                wyatt
                                I think this will be a very useful plugin. I can't get Lowest, Highest, Average, or Middle to work though. No matter which ones I pick, all the vertices go to zero. First I created a surface with undulating edges, selected the outer edges, and ran the plugin. I thought that's what I saw in the videos, and that process works for the other tools. Did I miss something, or is there a bug in the .2 release that wasn't there in .1?
                                  MartinK
                                  Thanks for another great plugin. I may be missing something, but is there a way to specify, by picking a point, where the selected vertices drop/raise to?
                                    • Lowest/Highest/Middle should adjust the vertices' z-value to match the z-value of the vertex in the selection that is lowest/highest/midway-between ??? Can you post and example of a SKP where it fails...
                                    • You can't 'pick a point' - depending on the tool you've selected you can specify a 'Z value' or it drops/lifts to objects etc...
                                      MartinK
                                      Thanks for the answer.
                                        MartinK
                                        I seem to be having the same problem as Wyatt, vertices only move to Z=0 no matter what method I use. I can't post the SKP as it is a large site model. Just wondering if anyone else has had this issue with Version 1.2.
                                          I have checked and there is 'a rabbit away' !
                                          Watch out for fixed code soon πŸ˜’
                                            Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
                                            It fixes a last minute typo in my code that affected Lowest/Highest/Middle results - it should now work as advertised - feedback please...dvs.PNG
                                            • 2 / 3
