    [Plugin] Drop Vertices
    54 Posts 18 Posters 153.9k Views 18 Watching
      This will do it
      v=[];t=0;m=Sketchup.active_model;m.entities.each{|e|v<<e.vertices if e.class==Sketchup;;Edge};v.flatten!;v.uniq!;p t=v.length;tt=0;m.definitions.each{|d|v=[];d.entities.each{|e|v<<e.vertices if e.class==Sketchup;;Edge};v.flatten!;v.uniq!;tt=tt+(v.length*d.instances.length)};p tt;p gt=t+tt;puts
      Copy+Paste this one-liner into the Ruby Console + <Enter> it prints the total of all unique vertices in the model AND then those vertices inside groups/instance [multiplied by the number of instances of each] and then the grand total of the two.
      • W Offline
        wyatt
        I think this will be a very useful plugin. I can't get Lowest, Highest, Average, or Middle to work though. No matter which ones I pick, all the vertices go to zero. First I created a surface with undulating edges, selected the outer edges, and ran the plugin. I thought that's what I saw in the videos, and that process works for the other tools. Did I miss something, or is there a bug in the .2 release that wasn't there in .1?
          MartinK
          Thanks for another great plugin. I may be missing something, but is there a way to specify, by picking a point, where the selected vertices drop/raise to?
            • Lowest/Highest/Middle should adjust the vertices' z-value to match the z-value of the vertex in the selection that is lowest/highest/midway-between ??? Can you post and example of a SKP where it fails...
            • You can't 'pick a point' - depending on the tool you've selected you can specify a 'Z value' or it drops/lifts to objects etc...
              MartinK
              Thanks for the answer.
                MartinK
                I seem to be having the same problem as Wyatt, vertices only move to Z=0 no matter what method I use. I can't post the SKP as it is a large site model. Just wondering if anyone else has had this issue with Version 1.2.
                  I have checked and there is 'a rabbit away' !
                  Watch out for fixed code soon 😒
                    Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
                    It fixes a last minute typo in my code that affected Lowest/Highest/Middle results - it should now work as advertised - feedback please...dvs.PNG
                    • W Offline
                      wyatt
                      The high/low/middle work correctly now. Thank you for this script.
                        MartinK
                        That seems to have done the trick. Many thanks. 👍
                        • simon le bonS Offline
                          simon le bon
                          Thank you so much Dear TIG for this brand new tool.
                          ("to middle" and "to average" options don't work for me with su6_free and su7_pro)
                          Coming back to the thread which had (re)initiated the need for such a tool: What's the best way to flatten some geometry lines
                          I'm trying the old problem (not solved by SandboxTools/stamp)to achieve to drop vertices of a 3d path onto a 3d terrain. (I would like start with a path "melted up an down", "included" with/into the terrain)
                          I have made my road/path triangulated (with Sandboxtools/from contour)
                          Tip: I use [Plugin] Select Outer Edges v1.0 by Chris Fullmer to select outer edges 😒
                          But Whatever the option I choose with Drop Vertices I got aberrant result 😕
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_001.jpg
                          to nearest object , to nearest below..
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_002.jpg
                          Any Idea ??
                          (Alternatively, I have tried "Drape CPoints" + "Triangulate Points" and also "Artisan"€ and this one gives the better results for me from now, using "Crease Selection" Edges+vertices on the total path face .
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_003.jpg
                          Cheers
                          simon.
                          Re: thank you dear Tig for your [Plugin] Work Plane v2.3 by TIG on Sat Sep 25, 2010 I'm using for long >>referencing to "this"
                            Simon
                              simon le bon
                              Bonjour TIG 😄
                              OK, I was confused on the concepts Drape/Drope.
                              I have discovered that the kind of subdivision is important. Until now I was trying to drape with some classical triangulated shapes and that's why the result wasn't working.
                              As I have seen with your example above it was possible, I have discovered that shapes must be subdivided by real tin subdivision.(as far)
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_005.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_006.jpg
                              (I see we can't obtain this way something like we can do with sandboxtool/Stamptool but with a 3D path.)
                              Anyway This DropVertices brings so much !!!!+++ Thank you one more time and bravo!! TIG
                              simon.
                              • EarthMoverE Offline
                                EarthMover
                                Here is another method to do what you are looking for Simon.
                                [flash=800,600:1yx2pldf]http://www.youtube.com/v/hzN5n2UB7Ao[/flash:1yx2pldf]
                                Content Creator at Skapeup
                                  simon le bon
                                  Dear Adam,
                                  your videos are invaluable to understand easily how things work and as reminders.
                                  I have watched your previous a number of times.
                                  I'm studying your propositions (soapskin&buble _ instant road (which makes the deal 👍 👍 ) and I'm thinking to others. It's for tomorrow now.
                                  Cheers,
                                     simon.
                                    Maybe use of Ferrari can also gives some cool results 😉
                                      ktslambieng
                                      oh .thank u verry much
                                      but ruby SplitUp I can find where, who can help me, please
                                      i saw on Youtube
                                      http://www.youtu.be/watch?v=kAUx4AHVbOU&feature=related
                                        i saw on Youtube
                                        Like 'On Screen Rolling Reel' - 'SplitUp' has never been published.
                                        It's in beta testing with a select group [Rich O'B].
                                        The bugs are now ironed out... I'll speak with the other[s] to see what we should do next...
                                          Don't forget my NURBS plugin that's fairly stable. Just too powerful for mere mortals.
                                          • peter_shawP Offline
                                            peter_shaw
                                            great plugin, used it to fix a f-ed up model
                                            • 2 / 3
