    [Plugin] Drop Vertices
    51 Posts 17 Posters 151.0k Views 17 Watching
      MartinK
      Thanks for the answer.
        MartinK
        I seem to be having the same problem as Wyatt, vertices only move to Z=0 no matter what method I use. I can't post the SKP as it is a large site model. Just wondering if anyone else has had this issue with Version 1.2.
          I have checked and there is 'a rabbit away' !
          Watch out for fixed code soon 😒
            Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
            It fixes a last minute typo in my code that affected Lowest/Highest/Middle results - it should now work as advertised - feedback please...dvs.PNG
            • W Offline
              wyatt
              The high/low/middle work correctly now. Thank you for this script.
                MartinK
                That seems to have done the trick. Many thanks. 👍
                • simon le bonS Offline
                  simon le bon
                  Thank you so much Dear TIG for this brand new tool.
                  ("to middle" and "to average" options don't work for me with su6_free and su7_pro)
                  Coming back to the thread which had (re)initiated the need for such a tool: What's the best way to flatten some geometry lines
                  I'm trying the old problem (not solved by SandboxTools/stamp)to achieve to drop vertices of a 3d path onto a 3d terrain. (I would like start with a path "melted up an down", "included" with/into the terrain)
                  I have made my road/path triangulated (with Sandboxtools/from contour)
                  Tip: I use [Plugin] Select Outer Edges v1.0 by Chris Fullmer to select outer edges 😒
                  But Whatever the option I choose with Drop Vertices I got aberrant result 😕
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_001.jpg
                  to nearest object , to nearest below..
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_002.jpg
                  Any Idea ??
                  (Alternatively, I have tried "Drape CPoints" + "Triangulate Points" and also "Artisan"€ and this one gives the better results for me from now, using "Crease Selection" Edges+vertices on the total path face .
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_003.jpg
                  Cheers
                  simon.
                  Re: thank you dear Tig for your [Plugin] Work Plane v2.3 by TIG on Sat Sep 25, 2010 I'm using for long >>referencing to "this"
                    Simon
                      simon le bon
                      Bonjour TIG 😄
                      OK, I was confused on the concepts Drape/Drope.
                      I have discovered that the kind of subdivision is important. Until now I was trying to drape with some classical triangulated shapes and that's why the result wasn't working.
                      As I have seen with your example above it was possible, I have discovered that shapes must be subdivided by real tin subdivision.(as far)
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_005.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_006.jpg
                      (I see we can't obtain this way something like we can do with sandboxtool/Stamptool but with a 3D path.)
                      Anyway This DropVertices brings so much !!!!+++ Thank you one more time and bravo!! TIG
                      simon.
                      • EarthMoverE Offline
                        EarthMover
                        Here is another method to do what you are looking for Simon.
                        [flash=800,600:1yx2pldf]http://www.youtube.com/v/hzN5n2UB7Ao[/flash:1yx2pldf]
                        Content Creator at Skapeup
                          simon le bon
                          Dear Adam,
                          your videos are invaluable to understand easily how things work and as reminders.
                          I have watched your previous a number of times.
                          I'm studying your propositions (soapskin&buble _ instant road (which makes the deal 👍 👍 ) and I'm thinking to others. It's for tomorrow now.
                          Cheers,
                             simon.
                            Maybe use of Ferrari can also gives some cool results 😉
                              ktslambieng
                              oh .thank u verry much
                              but ruby SplitUp I can find where, who can help me, please
                              i saw on Youtube
                              http://www.youtu.be/watch?v=kAUx4AHVbOU&feature=related
                                i saw on Youtube
                                Like 'On Screen Rolling Reel' - 'SplitUp' has never been published.
                                It's in beta testing with a select group [Rich O'B].
                                The bugs are now ironed out... I'll speak with the other[s] to see what we should do next...
                                  Don't forget my NURBS plugin that's fairly stable. Just too powerful for mere mortals.
                                  • peter_shawP Offline
                                    peter_shaw
                                    great plugin, used it to fix a f-ed up model
                                    • cottyC Offline
                                      cotty
                                      What did I wrong here?
                                      klick image
                                      my SketchUp gallery
                                        Scant on what you've tried...
                                        arcs/curves do not drop unless they are exploded first...
                                        but see this example...
                                          Here is v2.0 http://sketchucation.com/pluginstore?pln=dropverts It now overcomes the curve issue.
                                          All edges in a dropped curve are now treated as separate edges.
                                          • cottyC Offline
                                            cotty
                                            Thank you, nice update!
                                            my SketchUp gallery
                                            • 2 / 3
