    [Plugin] Drop Vertices
    51 Posts 17 Posters 150.8k Views 17 Watching
      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
      Several additional features added - please read first post...
      • EarthMoverE Offline
        EarthMover
        TIG, would it be possible to add an option which is drop verts to =Z /to intersect. Meaning if you had the subdivided plane above, let's say a smaller box, then all verts would drop to the specified Z, except where they intersected with the box. Perhaps adding a "Drape Verts" choice to the submenu. It would essentially do what drape Cpoints and triangulate does, but with a predefined mesh.
        Thanks for your work on this again. The new features are great. πŸ‘
        Content Creator at Skapeup
          I'll look at adding 'To Nearest + Z = ?' too... It should be too difficult...
            Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
            'To Nearest+Z=?' option added for 'draping' whole mesh over objects.
              EarthMover
              Wow, that was fast! I'll give it whirl and let you know how it works.
                EarthMover
                A quick play. Works great! Thanks again. πŸ‘ This will be great for retopology of high poly terrain data or terrains made with From Contours!
                [flash=800,600:3go1iq6p]http://www.youtube.com/v/cWgJeIonBhU[/flash:3go1iq6p]
                • JClementsJ Offline
                  JClements
                  Thanks, TIG! This should remedy some problem issues with the Smooth Tool in Sandbox where the boundary edges can't be anchored to their existing Z location.
                  1- Wondering about having functions similar to DropVert that would need to be in a different script called, MoveVertsTo.
                  After selecting edges, user would be asked to select a TARGET SURFACE and then choose "OK" to validate the target surface.
                  2- Perhaps additional mode (chekbox) for DropVerts and MoveVerts would be "SHOW ME" where the average, %, lowest, Highest, Z-value, etc., would temporarily be displayed (as plane) before the vertices are moved; the user could then: a) cancel the choice and choose another option or b) execute the move.
                    EarthMover
                    Additionally I wonder if it would be possible to implement a Vert Memory option, where you could select all border edges and choose "Remember Vertex Positions", then once you are finished sculpting a terrain, you could "Restore Vertex Positions". This would essentially allow a user to freeze all border edges from being affected by manipulation. This way, if I had, say a flower bed on a hillside that I wanted to add undulation to, I could store the perimeter verts to memory, sculpt to my leisure, then restore the border perfectly. 😎 Just a thought.
                    • bac9-flclB Offline
                      bac9-flcl
                      I am sorry to interrupt the thread, but as you seem to very experienced in working with SketchUp model vertex structure, I've wanted to ask a simple question: is it possible to write a small plugin that can display the total vertex count of a model? It is a very important parameter to keep an eye on, for example, if developing Google Earth targeted model, but it's nowhere to be found in standart SketchUp stats. 😞
                        This will do it
                        v=[];t=0;m=Sketchup.active_model;m.entities.each{|e|v<<e.vertices if e.class==Sketchup;;Edge};v.flatten!;v.uniq!;p t=v.length;tt=0;m.definitions.each{|d|v=[];d.entities.each{|e|v<<e.vertices if e.class==Sketchup;;Edge};v.flatten!;v.uniq!;tt=tt+(v.length*d.instances.length)};p tt;p gt=t+tt;puts
                        Copy+Paste this one-liner into the Ruby Console + <Enter> it prints the total of all unique vertices in the model AND then those vertices inside groups/instance [multiplied by the number of instances of each] and then the grand total of the two.
                        • W Offline
                          wyatt
                          I think this will be a very useful plugin. I can't get Lowest, Highest, Average, or Middle to work though. No matter which ones I pick, all the vertices go to zero. First I created a surface with undulating edges, selected the outer edges, and ran the plugin. I thought that's what I saw in the videos, and that process works for the other tools. Did I miss something, or is there a bug in the .2 release that wasn't there in .1?
                            MartinK
                            Thanks for another great plugin. I may be missing something, but is there a way to specify, by picking a point, where the selected vertices drop/raise to?
                              • Lowest/Highest/Middle should adjust the vertices' z-value to match the z-value of the vertex in the selection that is lowest/highest/midway-between ??? Can you post and example of a SKP where it fails...
                              • You can't 'pick a point' - depending on the tool you've selected you can specify a 'Z value' or it drops/lifts to objects etc...
                                MartinK
                                Thanks for the answer.
                                  MartinK
                                  I seem to be having the same problem as Wyatt, vertices only move to Z=0 no matter what method I use. I can't post the SKP as it is a large site model. Just wondering if anyone else has had this issue with Version 1.2.
                                    I have checked and there is 'a rabbit away' !
                                    Watch out for fixed code soon πŸ˜’
                                      Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
                                      It fixes a last minute typo in my code that affected Lowest/Highest/Middle results - it should now work as advertised - feedback please...dvs.PNG
                                      • W Offline
                                        wyatt
                                        The high/low/middle work correctly now. Thank you for this script.
                                          MartinK
                                          That seems to have done the trick. Many thanks. πŸ‘
                                          • simon le bonS Offline
                                            simon le bon
                                            Thank you so much Dear TIG for this brand new tool.
                                            ("to middle" and "to average" options don't work for me with su6_free and su7_pro)
                                            Coming back to the thread which had (re)initiated the need for such a tool: What's the best way to flatten some geometry lines
                                            I'm trying the old problem (not solved by SandboxTools/stamp)to achieve to drop vertices of a 3d path onto a 3d terrain. (I would like start with a path "melted up an down", "included" with/into the terrain)
                                            I have made my road/path triangulated (with Sandboxtools/from contour)
                                            Tip: I use [Plugin] Select Outer Edges v1.0 by Chris Fullmer to select outer edges πŸ˜’
                                            But Whatever the option I choose with Drop Vertices I got aberrant result πŸ˜•
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_001.jpg
                                            to nearest object , to nearest below..
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_002.jpg
                                            Any Idea ??
                                            (Alternatively, I have tried "Drape CPoints" + "Triangulate Points" and also "Artisan"€ and this one gives the better results for me from now, using "Crease Selection" Edges+vertices on the total path face .
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thdropverts_003.jpg
                                            Cheers
                                            simon.
                                            Re: thank you dear Tig for your [Plugin] Work Plane v2.3 by TIG on Sat Sep 25, 2010 I'm using for long >>referencing to "this"
                                            • 2 / 3
